基本信息
U-Boot 2022.04-rc2-VisionFive-SDK_v2.3.3 (Jun 20 2022 - 07:25:30 +0000)StarFive
CPU: rv64imafdc
Model: StarFive VisionFive V1
DRAM: 8 GiB
Core: 13 devices, 9 uclasses, devicetree: separate
MMC: mmc@10000000: 0, mmc@10010000: 1
OK
StarFive EEPROM format v1
Product full SN: VF7100A1-2220-D008E000-00000731
data version: 0x1
PCB revision: 0x1
Ethernet MAC address: 6c:cf:39:00:07:30
环境
ethaddr=6c:cf:39:00:07:30
ipaddr=192.168.199.217
netmask=255.255.255.0
serverip=192.168.199.30
问题描述
ping 不通主机,输出信息如下:
VisionFive #ping 192.168.199.30
Speed: 100, full duplex
Using dwmac.10020000 device
ARP Retry count exceeded; starting again
ping failed; host 192.168.199.30 is not alive
julie
June 21, 2022, 6:54am
2
你可以将uboot更新到下面这个链接版本吗?同一个环境分析问题可以排除环境因素。
我的测试环境,Server: win10,路由器:HUAWEI AX3Pro, 路由器跟server和开发板均是有线连接。
bootloader version:211102-0b86f96
ddr 0x00000000, 1M test
ddr 0x00100000, 2M test
DDR clk 2133M,Version: 211102-d086aee
0 crc flash: 7816e82f, crc ddr: 7816e82f
crc check PASSED
bootloader.
OpenSBI v1.0
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
fdt_reset_driver_init: gpio-restart init failed, -1001
Platform Name : StarFive VisionFive V1
Platform Features : medeleg
Platform HART Count : 2
Platform Timer Device : aclint-mtimer @ 6250000Hz
Platform HSM Device : ---
Platform Reboot Device : ---
Firmware Base : 0x80000000
Firmware Size : 300 KB
Runtime SBI Version : 0.3
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 HARTs : 0*,1*
Domain0 Region01 : 0x0000000080000000-0x000000008007ffff ()
Domain0 Next Address : 0x0000000080200000
Domain0 Next Arg1 : 0x0000000082200000
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART ISA : rv64imafdcsux
Boot HART Features : scounteren,mcounteren
Boot HART PMP Count : 16
Boot HART PMP Address Bits: 36
Boot HART MHPM Count : 2
U-Boot 2022.04-rc2-VisionFive (Mar 07 2022 - 21:12:22 +0800)StarFive
CPU: rv64imafdc
DRAM: 8 GiB
Product full SN: VF7100A1-2206-D008E000-00000262
data version: 0x1
PCB revision: 0x1
Ethernet MAC address: 6c:cf:39:00:02:61
In: serial@12440000
Out: serial@12440000
Err: serial@12440000
Net: dwmac.10020000
MMC CD is 0x1, force to True.
VisionFive #setenv ipaddr 192.168.3.199;setenv serverip 192.168.3.99
VisionFive #ping 192.168.3.99
Speed: 1000, full duplex
host 192.168.3.99 is alive
VisionFive #
VisionFive #
VisionFive #
您好,感谢回复。
试了这一版 u-boot 依旧无法 ping 通主机。
ps:我测试过了网络环境肯定没问题。
julie
June 21, 2022, 7:24am
4
你有没有在板子上测试过Fedora系统,在系统下能联网吗?
julie
June 21, 2022, 7:31am
6
建议您可以在TF卡上刷个Fedora系统,看下fedora系统下是否能联网,这样可以排查下网络硬件方面的问题。
谢谢帮助,在 Fedora 系统下,网络是正常。
再次进入 u-boot 使用 ping 命令的报错和之前不一样了:
dwmac.10020000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
我当前的需求是在 u-boot 下面使用网络,请问我还能做点什么帮助排查问题。
julie
June 21, 2022, 8:52am
8
你的server是什么环境?是win还是ubuntu或是其它?
server的防火墙关了吗?
开发板跟server是网线直连还是通过路由器?
我试了下直连,结果如下:
server 网口是千兆,板子和 server 直连后协商为千兆连接,网络可以通。
host 192.168.199.30 is alive
但是通过路由器连接,路由器上的网口是百兆,虽然 u-boot 上显示协商成了百兆但是网络是不通的。
在 Fedora 系统里面,板子连接到路由器上也协商成了百兆,网络却是通的。
skyler
June 21, 2022, 9:14am
11
我之前用家里的tplink路由器也碰到过这个情况,ping不同,后来改成网线直连了 ,是不是路由器上需要设置啥
有可能是 u-boot 里面的驱动对百兆网络的支持不好。
julie
June 22, 2022, 6:23am
13
我们会看看能不能复现,查一下这个问题,您可以先用网线直连的方式。
arch=riscv
baudrate=115200
board=jh7100
board_name=jh7100
boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr}
boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootriscv64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r};else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi
boot_efi_bootmgr=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi
boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf}
boot_prefixes=/ /boot/
boot_script_dhcp=boot.scr.uimg
boot_scripts=boot.scr.uimg boot.scr
boot_syslinux_conf=extlinux/extlinux.conf
boot_targets=dhcp mmc0
bootcmd_dhcp=devtype=dhcp; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;setenv efi_fdtfile ${fdtfile}; setenv efi_old_vci ${bootp_vci};setenv efi_old_arch ${bootp_arch};setenv bootp_vci PXEClient:Arch:00027:UNDI:003000;setenv bootp_arch 0x1b;if dhcp ${kernel_addr_r}; then tftpboot ${fdt_addr_r} dtb/${efi_fdtfile};if fdt addr ${fdt_addr_r}; then bootefi ${kernel_addr_r} ${fdt_addr_r}; else bootefi ${kernel_addr_r} ${fdtcontroladdr};fi;fi;setenv bootp_vci ${efi_old_vci};setenv bootp_arch ${efi_old_arch};setenv efi_fdtfile;setenv efi_old_arch;setenv efi_old_vci;
bootcmd_mmc0=devnum=0; run mmc_boot
bootdelay=2
bootdir=/boot
bootenv=uEnv.txt
bootpart=0:3
cpu=fu740
distro_bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done
efi_dtb_prefixes=/ /dtb/ /dtb/current/
ethact=dwmac.10020000
ext4bootenv=ext4load mmc ${bootpart} ${loadaddr} ${bootdir}/${bootenv}
fatenv=fatload mmc ${testpart} ${loadaddr} ${testenv};env import -t ${loadaddr} ${filesize}
fdtcontroladdr=ff6ea560
fdtfile=starfive/jh7100-visionfive.dtb
fdtsetup=fdt addr ${fdtcontroladdr}
importbootenv=echo Importing environment from mmc${mmcdev} ...; env import -t ${loadaddr} ${filesize}
load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile}
loadaddr=0xa0000000
loadbootenv=fatload mmc ${mmcdev} ${loadaddr} ${bootenv}
mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi
mmcbootenv=setenv bootpart ${mmcdev}:${mmcpart}; mmc dev ${mmcdev}; if mmc rescan; then run loadbootenv && run importbootenv; run ext4bootenv && run importbootenv; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi; fi
mmcdev=0
mmcpart=3
mmcsetup=mmc part
preboot=run mmcbootenv
scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_dev_for_scripts; done;run scan_dev_for_efi;
scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist}; do if fstype ${devtype} ${devnum}:${distro_bootpart} bootfstype; then run scan_dev_for_boot; fi; done; setenv devplist
scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${efi_fdtfile}; then run load_efi_dtb; fi;done;run boot_efi_bootmgr;if test -e ${devtype} ${devnum}:${distro_bootpart} efi/boot/bootriscv64.efi; then echo Found EFI removable media binary efi/boot/bootriscv64.efi; run boot_efi_binary; echo EFI LOAD FAILED: continuing...; fi; setenv efi_fdtfile
scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_conf}; run boot_extlinux; echo SCRIPT FAILED: continuing...; fi
scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boot script ${prefix}${script}; run boot_a_script; echo SCRIPT FAILED: continuing...; fi; done
scan_sf_for_scripts=${devtype} read ${scriptaddr} ${script_offset_f} ${script_size_f}; source ${scriptaddr}; echo SCRIPT FAILED: continuing...
serial#=VF7100A1-2220-D008E000-00000731
sf_boot=if sf probe ${busnum}; then devtype=sf; run scan_sf_for_scripts; fi
soc=jh7100
stderr=serial@12440000
stdin=serial@12440000
stdout=serial@12440000
testenv=u74_uEnv.txt
testpart=0:1
vendor=starfive
ver=U-Boot 2022.04-rc2-VisionFive-SDK_v2.3.3 (Jun 20 2022 - 07:25:30 +0000)StarFive
Environment size: 4435/126972 bytes
VisionFive #
遇到同样问题。测试环境:路由器1个1G口,2个100M口。最终将开发板接入1G口(网线必须用标准的接法),正确配置u-boot网络参数,测试电脑用100M口接入,配置tftp服务,ping通网络,tftpboot可下载引导,wifi在启动后进行配置也通过测试。猜测是u-boot自适应百兆网络的原因。
