U-Boot v2026.04 and OpenSBI v1.8.1 issues
I have a strange behavior when trying to build the newly released OpenSBI v1.8.1 and U-Boot v2026.04. Used the build steps which are described in the U-Boot documentation.
Seems the build system from U-Boot v2026.04 doesn’t integrate OpenSBI into the binaries or since OpenSBI v1.8.1 there is no longer a starting banner and the board information after U-Boot’s SPL:
U-Boot SPL 2026.04 (Apr 16 2026 - 17:34:49 +0200)
DDR version: dc2e84f0.
Trying to boot from SPI
U-Boot 2026.04 (Apr 16 2026 - 17:34:49 +0200)
CPU:   sifive,u74-mc
Model: StarFive VisionFive 2 v1.3B
DRAM:  8 GiB
Core:  159 devices, 30 uclasses, devicetree: board
WDT:   Not starting watchdog@13070000
MMC:   mmc@16010000: 0, mmc@16020000: 1
Product full SN: VF7110B1-2318-D008E000-18003208
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:5d:7e
Ethernet MAC1 address: 6c:cf:39:00:5d:7f
In:    serial@10000000
Out:   serial@10000000
Err:   serial@10000000
starting USB...
USB XHCI 1.00
Bus xhci_pci: 2 USB Device(s) found
Working FDT set to ff6fc0c0
StarFive #
This issue didn’t exists with U-Boot v2025.10 and OpenSBI v1.7, there was always the start banner from OpenSBI via the serial interface shown:
U-Boot SPL 2025.10 (Nov 10 2025 - 05:03:26 +0100)
OpenSBI v1.7
Platform Name               : StarFive VisionFive 2 v1.3B
Platform Features           : medeleg
Platform HART Count         : 4
Platform IPI Device         : aclint-mswi
Platform Timer Device       : aclint-mtimer @ 4000000Hz
Platform Console Device     : uart8250
Platform HSM Device         : ---
Platform PMU Device         : ---
Platform Reboot Device      : pm-reset
Platform Shutdown Device    : pm-reset
Platform Suspend Device     : ---
Platform CPPC Device        : ---
Firmware Base               : 0x40000000
Firmware Size               : 353 KB
Firmware RW Offset          : 0x40000
Firmware RW Size            : 97 KB
Firmware Heap Offset        : 0x4c000
Firmware Heap Size          : 49 KB (total), 3 KB (reserved), 12 KB (used), 33 KB (free)
Firmware Scratch Size       : 4096 B (total), 400 B (used), 3696 B (free)
Runtime SBI Version         : 3.0
Standard SBI Extensions     : time,rfnc,ipi,base,hsm,srst,pmu,dbcn,fwft,legacy,dbtr,sse
Experimental SBI Extensions : none
Domain0 Name                : root
Domain0 Boot HART           : 2
Domain0 HARTs               : 1*,2*,3*,4*
Domain0 Region00            : 0x0000000010000000-0x0000000010000fff M: (I,R,W) S/U: (R,W)
Domain0 Region01            : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region02            : 0x0000000040040000-0x000000004005ffff M: (R,W) S/U: ()
Domain0 Region03            : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: ()
Domain0 Region04            : 0x000000000c000000-0x000000000fffffff M: (I,R,W) S/U: (R,W)
Domain0 Region05            : 0x0000000000000000-0xffffffffffffffff M: () S/U: (R,W,X)
Domain0 Next Address        : 0x0000000040200000
Domain0 Next Arg1           : 0x00000000402c1d28
Domain0 Next Mode           : S-mode
Domain0 SysReset            : yes
Domain0 SysSuspend          : yes
Boot HART ID                : 2
Boot HART Domain            : root
Boot HART Priv Version      : v1.11
Boot HART Base ISA          : rv64imafdcbx
Boot HART ISA Extensions    : zihpm,sdtrig
Boot HART PMP Count         : 8
Boot HART PMP Granularity   : 12 bits
Boot HART PMP Address Bits  : 34
Boot HART MHPM Info         : 2 (0x00000018)
Boot HART Debug Triggers    : 8 triggers
Boot HART MIDELEG           : 0x0000000000000222
Boot HART MEDELEG           : 0x000000000000b109
U-Boot 2025.10 (Nov 10 2025 - 05:03:26 +0100)
CPU:   sifive,u74-mc
DRAM:  8 GiB
Core:  159 devices, 29 uclasses, devicetree: board
PCB revision: 0xb2
starfive_7110_pcie pcie@940000000: Starfive PCIe bus probed.
starfive_7110_pcie pcie@9c0000000: Starfive PCIe bus probed.
In:    serial@10000000
starting USB...
Register 5000420 NbrPorts 5
Starting the controller
USB XHCI 1.00
Working FDT set to ff717740
StarFive #
Is there a way without Linux to test if OpenSBI v1.8.1 works? Need U-Boot and OpenSBI for bare-metal development on the VF2.
Okay, I have fixed the issue. I used the build steps described in the U-Boot documentation. But these build steps seems to be definitely wrong. Unfortunately I didn’t know anymore how I have built U-Boot v2025.10 with OpenSBI v1.7. So after some search I found the correct solution to build U-Boot v2026.04 and OpenSBI v1.8.1 and update the SPI flash with the actual firmware.
Here the working output:
U-Boot SPL 2026.04 (Apr 16 2026 - 19:33:14 +0200)
OpenSBI v1.8.1
Platform HART Protection    : pmp
Firmware Size               : 357 KB
Firmware RW Size            : 101 KB
Firmware Heap Offset        : 0x4d000
Firmware Heap Size          : 49 KB (total), 0 KB (reserved), 13 KB (used), 35 KB (free)
Firmware Scratch Size       : 4096 B (total), 416 B (used), 3680 B (free)
Domain0 Name                : root
Domain0 Boot HART           : 1
Domain0 Region00            : 0x0000000040040000-0x000000004005ffff M: (F,R,W) S/U: ()
Domain0 Region01            : 0x0000000040000000-0x000000004003ffff M: (F,R,X) S/U: ()
Domain0 Region02            : 0x0000000010000000-0x0000000010000fff M: (I,R,W) S/U: (R,W)
Domain0 Region03            : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Next Arg1           : 0x0000000042200000
Boot HART ID                : 1
U-Boot 2026.04 (Apr 16 2026 - 19:48:27 +0200)
CPU:   sifive,u74-mc
DRAM:  4 GiB
PCB revision: 0xb2
In:    serial@10000000
starting USB...
USB XHCI 1.00
Working FDT set to ff6fc140
StarFive #
Don’t know if I should post the correct build steps here, if another user runs into the same issue.
:+1: :clap:
Build steps to build OpenSBI v1.8.1 and U-Boot v2026.04 for VisionFive 2
NOTE:
The build steps are a little bit tricky currently. But they are working and tested on real hardware.
Prerequisites for Vision Five 2 8GiB DDR-RAM variant:
Currently the official sources from U-Boot only supports the 4GiB RAM variant from the board. For supporting of the 8GiB DDR-RAM variant of the board containing the RAM-IC BiWin BMWZCX32H2A-64G-X (soldered on my model), there is a modification in the device tree source required.
Just change the DDR RAM size from 4GiB to 8GiB in the device tree source dts/upstream/src/riscv/starfive/jh7110-common.dtsi from the U-Boot sources in the memory node:
4GiB DDR-RAM:
memory@40000000 {
		device_type = "memory";
		reg = <0x0 0x40000000 0x1 0x0>;
		bootph-pre-ram;
8GiB DDR-RAM:
memory@40000000 {
		reg = <0x0 0x40000000 0x2 0x0>;
		bootph-pre-ram;
Now the 8GiB should be supported by U-Boot and also returned from U-Boot’s EFI environment memory map query.
Build OpenSBI (first stage):
$ git clone https://github.com/riscv-software-src/opensbi.git
$ cd opensbi
$ git checkout v1.8.1
$ make distclean
$ export CROSS_COMPILE=riscv64-unknown-linux-gnu-
$ make PLATFORM=generic
After successful built, the following files should be created:
opensbi/build/platform/generic/firmware/fw_dynamic.bin
Build U-Boot:
$ git clone https://github.com/u-boot/u-boot.git
$ cd u-boot
$ git checkout v2026.04
$ make mrproper
$ export OPENSBI=/path/to/openspi/fw_dynamic.bin
$ make starfive_visionfive2_defconfig
$ make
u-boot/u-boot.bin
u-boot/dts/upstream/src/riscv/starfive/jh7110-starfive-visionfive-2-v1.3b.dtb
Build OpenSBI (second stage):
$ cd opensbi
$ make distclean
$ make PLATFORM=generic FW_PAYLOAD_PATH=/path/to/u-boot/u-boot.bin FW_FDT_PATH=/path/to/u-boot/jh7110-starfive-visionfive-2-v1.3b.dtb FW_TEXT_START=0x40000000
Create FIT image (with U-Boot’s mkimage):
  • Create the file visionfive2-uboot-fit-image.its with the following content:
/dts-v1/;
	description = "U-boot-spl FIT image for JH7110 VisionFive2";
	#address-cells = <2>;
	images {
		firmware {
			description = "u-boot";
			data = /incbin/("fw_payload.bin");
			type = "firmware";
			arch = "riscv";
			os = "u-boot";
			load = <0x0 0x40000000>;
			entry = <0x0 0x40000000>;
			compression = "none";
	configurations {
		default = "config-1";
		config-1 {
			description = "U-boot-spl FIT config for JH7110 VisionFive2";
			firmware = "firmware";
  • Copy the OpenSBI/U-Boot binary fw_payload.bin into the same directory as the file visionfive2-uboot-fit-image.its
  • Create the FIT image (firmware.itb):
$ cd u-boot
$ ./tools/mkimage -f /path/to/visionfive2-uboot-fit-image.its -A riscv -O u-boot -T firmware firmware.itb
The following files should be created which containing the final firmware images:
u-boot/spl/u-boot-spl.bin.normal.out
u-boot/firmware.itb
Prepare/Format SD card:
$ sudo sgdisk --clear --set-alignment=2 --new=1:4096:8191 --change-name=1:spl --typecode=1:2E54B353-1271-4842-806F-E436D6AF6985 --new=2:8192:16383 --change-name=2:uboot --typecode=2:BC13C2FF-59E6-4262-A352-B275FD6F7172 --new=3:16384:1654784 --change-name=3:system --typecode=3:EBD0A0A2-B9E5-4433-87C0-68B6B72699C7 /dev/sdx
Create FAT32 file system:
$ sudo mkfs.vfat -F 32 /dev/sdx3
Copy new built firmware onto SD card:
$ sudo dd if=u-boot-spl.bin.normal.out of=/dev/sdx1
$ sudo dd if=firmware.itb of=/dev/sdx2
To update the SPI flash is currently not described here. See U-Boot documentation for update the new firmware onto the SPI flash, or ask it here.
All this is done automatically when building opensbi and u-boot.
https://gitlab.com/sndwvs/images_build_kit/-/blob/arm/compilation.sh?ref_type=heads#L37
https://gitlab.com/sndwvs/images_build_kit/-/blob/arm/compilation.sh?ref_type=heads#L102
firmware for the SPI from the board itself
cat /proc/mtd
flashcp -v visionfive2_fw_payload.img  /dev/mtd2
irradium: u-boot-spl.bin.normal.out -> u-boot.bin and visionfive2_fw_payload.img -> u-boot.itb
firmware via UART
installed package: lrzsz
updating the SPI bootloader:
# lsz -X jh7110-recovery-<version>.bin < /dev/ttyUSB0 > /dev/ttyUSB0
  0: update 2ndboot/SPL in flash
  1: update 2ndboot/SPL in emmc
  2: update fw_verif/uboot in flash
  3: update fw_verif/uboot in emmc
  4: update otp, caution!!!!
  5: exit
select: 0
# lsz -X u-boot.bin < /dev/ttyUSB0 > /dev/ttyUSB0
select : 2
# lsz -X u-boot.itb < /dev/ttyUSB0 > /dev/ttyUSB0
select exit: 5
Yes, thanks.
But if using only OpenSBI/U-Boot for booting bare-metal targets (none-Linux or *BSD) it can be done also with U-Boot’s CLI with the sf command (both locally if a SD card contain the images or also can transferred via TFTP to U-Boot.
Here a small example if a SD card contains the images:
Starfive# sf probe
Starfive# fatload mmc 1:3 $loadaddr u-boot-spl.bin.normal.out $filesize
Starfive# sf update $loadaddr 0x0 $filesize
Starfive# fatload mmc 1:3 $loadaddr firmware.itb $filesize
Starfive# sf update $loadaddr 0x100000 $filesize
Oops…
Cannot edit my post anymore. Incorrect and might be fatal commands.
Should be:
Starfive# sf probe
