I’ve now written the image starfive-jh7110-202409-nvme-minimal-desktop-wayland.img with dd to a nvme disk and removed the SD card.
When the boot switches on the board are in SD mode I get this error message:
dwmci_s: Response Timeout.
BOOT fail,Error is 0xffffffff
With the boot switches in Flash mode I get this:
U-Boot SPL 2021.10 (Sep 28 2024 - 01:14:56 +0800)
Trying to boot from SPI
OpenSBI v1.2
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Firmware Base : 0x40000000
Firmware Size : 392 KB
Firmware RW Offset : 0x40000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Sep 28 2024 - 01:14:56 +0800), Build: jenkins-github_visionfive2_6.6-5
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 8 GiB
OK
Product full SN: VF7110B1-2253-D008E000-00005754
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:5f:f0
Ethernet MAC1 address: 6c:cf:39:00:5f:f3
In: serial
Out: serial
Err: serial
starting USB...
No working controllers found
starting USB...
USB is stopped. Please issue 'usb start' first.
PCI: Failed autoconfig bar 10
starfive_pcie pcie@2C000000: Port link up.
Device 1: unknown device
starting USB...
Bus xhci_pci: Register 5000420 NbrPorts 5
Starting the controller
USB XHCI 1.00
scanning bus xhci_pci for devices... 2 USB Device(s) found
I’m very sorry to ask this odd “the board does not boot from nvme” question again as it has been disussed here so often. But I was not able to find a straight forward and usable documentation how to get this damn U-Boot to boot from the nvme disk.
Could it be, that my U-Boot env is corrupted? The nvme is a Crucial P3 Plus 1TB disk. The same 500GB variant does boot just fine on another VisionFive2 board with Gentoo Linux. As it is executing my Home Assistant instance I don’t want to get it out of my working environment to test it in this non working board.
Power could not be an issue. The USB-C connection has plenty of power.
Here some more informations from the SPI console:
StarFive # pci
Scanning PCI devices on bus 0
BusDevFun VendorId DeviceId Device Class Sub-Class
_____________________________________________________________
00.00.00 0x1556 0x1111 Bridge device 0x04
StarFive # nvme device
IDE device 0: Vendor: 0x1344 Rev: P9CR413 Prod: 241247C5D913
Type: Hard Disk
Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512)
StarFive # nvme detail
Blk device 0: Optional Admin Command Support:
Namespace Management/Attachment: no
Firmware Commit/Image download: yes
Format NVM: yes
Security Send/Receive: yes
Blk device 0: Optional NVM Command Support:
Reservation: yes
Save/Select field in the Set/Get features: no
Write Zeroes: yes
Dataset Management: yes
Write Uncorrectable: yes
Blk device 0: Format NVM Attributes:
Support Cryptographic Erase: No
Support erase a particular namespace: Yes
Support format a particular namespace: Yes
Blk device 0: LBA Format Support:
LBA Foramt 0 Support: (current)
Metadata Size: 0
LBA Data Size: 512
Relative Performance: Better
Blk device 0: End-to-End DataProtect Capabilities:
As last eight bytes: No
As first eight bytes: No
Support Type3: No
Support Type2: No
Support Type1: No
Blk device 0: Metadata capabilities:
As part of a separate buffer: No
As part of an extended data LBA: No
StarFive # nvme part
Partition Map for NVMe device 0 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00001000 0x00001fff ""
attrs: 0x0000000000000000
type: 2e54b353-1271-4842-806f-e436d6af6985
guid: ecea2689-2ecf-433b-9ddb-67613400f779
2 0x00002000 0x00003fff ""
type: 5b193300-fc78-40cd-8002-e86c45580b47
guid: a010bbc0-b573-432d-a11a-57a2ac647f0a
3 0x00004000 0x00035fff ""
type: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
type: system
guid: c00fcbd2-e8d6-4c21-ba35-30fb815967d9
4 0x00036000 0x747067ff ""
type: 0fc63daf-8483-4772-8e79-3d69d8477de4
type: linux
guid: e2a4e09f-2dfb-421e-89aa-82c928d4b6b3
As I’m exited to get the official Debian port to boot from the nvme any help would be very welcome!
