Hello all
CPU temp is at 50° when idle.
Hardware:
VF2 1.2A 8GB
Waveshare VisionFive2 CPU Cooling Fan
Note: No thermal paste or the thermal pad yet applied.
As I do not have experience with those pads, so advise would be greatly appreciated
TIA
Hello all
Hardware:
VF2 1.2A 8GB
TIA
Without pad or paste, you create a tiny gap between the CPU and heatsink, which when the CPU was hot enough, the small gap become heat insulation.
In short, please put a pad or apply paste.
thanks for response. do u know, what is better?
Paste is better, but I prefer 2 mm thick pad with double side glue to maximize the contact area on the elevated center and also the rim area.
thanks for advising.
for the moment i used the pad, which came with the fan (need to order thermal paste for another try later) — temp is now down to ~38° — wow
