My server was working fine, but at one moment I found that I cannot connect to it.Previously it was booting from SD card, but not anymore. Should I try different card?
U-Boot SPL 2021.10 (Dec 25 2022 - 20:59:18 +0800)
DDR version: dc2e84f0.
Trying to boot from SPI
OpenSBI v1.0
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform Reboot Device : ---
Firmware Base : 0x40000000
Firmware Size : 360 KB
Runtime SBI Version : 0.3
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Region01 : 0x0000000040000000-0x000000004007ffff ()
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Dec 25 2022 - 20:59:18 +0800), Build: jenkins-github_visionfive2-4
CPU: rv64imacu
Model: StarFive VisionFive V2
DRAM: 8 GiB
Product full SN: VF7110A1-2250-D008E000-00001435
PCB revision: 0xa1
Ethernet MAC0 address: 6c:cf:39:00:28:b7
Ethernet MAC1 address: 6c:cf:39:00:28:b8
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
switch to partitions #0, OK
mmc1 is current device
found device 1
bootmode flash device 1
Can't set block device
Failed to load '/boot/uEnv.txt'
385 bytes read in 4 ms (93.8 KiB/s)
## Error: "boot2" not defined
47546 bytes read in 7 ms (6.5 MiB/s)
47546 bytes written in 13 ms (3.5 MiB/s)
863 bytes read in 7 ms (120.1 KiB/s)
U-Boot menu
Enter choice: 1: Debian GNU/Linux bookworm/sid 5.15.0-starfive
9684944 bytes read in 802 ms (11.5 MiB/s)
Retrieving file: /boot/vmlinuz-5.15.0-starfive
8015160 bytes read in 343 ms (22.3 MiB/s)
append: root=/dev/mmcblk1p3 root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
Retrieving file: /boot/dtbs/starfive/jh7110-visionfive-v2.dtb
47546 bytes read in 8 ms (5.7 MiB/s)
Uncompressing Kernel Image
Moving Image from 0x44000000 to 0x40200000, end=41767000
Using Device Tree in place at 0000000048000000, end 000000004800e9b9
Starting kernel ...
[ 0.000000] Linux version 5.15.0-starfive (sw_buildbot@mdcsw02) (riscv64-unknown-linux-gnu-gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35) #1 SMP Wed Dec 21 03:56:12 EST 2022
[ 0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
[ 0.000000] earlycon: uart0 at MMIO32 0x0000000010000000 (options '115200')
[ 0.000000] printk: bootconsole [uart0] enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000023fffffff]
[ 0.000000] node 0: [mem 0x0000000040200000-0x00000000c010ffff]
[ 0.000000] node 0: [mem 0x00000000c0200000-0x000000023fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x000000023fffffff]
[ 0.000000] SBI specification v0.3 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x10000
[ 0.000000] SBI v0.2 HSM extension detected
[ 0.000000] riscv: ISA extensions acdfim
[ 0.000000] percpu: Embedded 17 pages/cpu s31528 r8192 d29912 u69632
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2067975
[ 0.000000] Kernel command line: root=/dev/mmcblk1p3 root=/dev/mmcblk1p3 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
[ 0.000000] Unknown command line parameters: stmmaceth=chain_mode:1 selinux=0
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 7582168K/8386560K available (9884K kernel code, 4982K rwdata, 4096K rodata, 2191K init, 401K bss, 280104K reserved, 524288K cma-reserved)
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] random: get_random_bytes called from start_kernel+0x4d0/0x6e2 with crng_init=0
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1]
[ 0.009004] clocksource: timer@13050000.ch0: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.020328] clocksource: timer@13050000.ch1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.031661] clocksource: timer@13050000.ch2: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.042986] clocksource: timer@13050000.ch3: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.054476] Console: colour dummy device 80x25
[ 0.060670] printk: console [tty0] enabled
[ 0.065225] Calibrating delay loop (skipped), value calculated using timer frequency.. 8.00 BogoMIPS (lpj=40000)
[ 0.076448] pid_max: default: 32768 minimum: 301
[ 0.081731] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.090246] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.100542] ASID allocator disabled
[ 0.104480] rcu: Hierarchical SRCU implementation.
[ 0.109933] EFI services will not be available.
[ 0.115317] smp: Bringing up secondary CPUs ...
[ 0.121955] smp: Brought up 1 node, 4 CPUs
[ 0.128397] devtmpfs: initialized
[ 0.139628] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.150490] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.171808] pinctrl core: initialized pinctrl subsystem
[ 0.178466] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.185692] cpuidle: using governor menu
[ 0.211974] platform soc:dsi-output: Fixing up cyclic dependency with 29400000.dc8200
[ 0.221151] platform 295d0000.mipi: Fixing up cyclic dependency with soc:dsi-output
[ 0.229989] platform 29590000.hdmi: Fixing up cyclic dependency with 29400000.dc8200
[ 0.250448] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.257832] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.268387] vgaarb: loaded
[ 0.271614] SCSI subsystem initialized
[ 0.276157] usbcore: registered new interface driver usbfs
[ 0.282230] usbcore: registered new interface driver hub
[ 0.288122] usbcore: registered new device driver usb
[ 0.293967] mc: Linux media interface: v0.10
[ 0.298718] videodev: Linux video capture interface: v2.00
[ 0.304943] Advanced Linux Sound Architecture Driver Initialized.
[ 0.312038] Bluetooth: Core ver 2.22
[ 0.316000] NET: Registered PF_BLUETOOTH protocol family
[ 0.321858] Bluetooth: HCI device and connection manager initialized
[ 0.328855] Bluetooth: HCI socket layer initialized
[ 0.334237] Bluetooth: L2CAP socket layer initialized
[ 0.339808] Bluetooth: SCO socket layer initialized
[ 0.345521] clocksource: Switched to clocksource riscv_clocksource
[ 0.359845] NET: Registered PF_INET protocol family
[ 0.366227] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.382048] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
[ 0.391803] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.401383] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.412073] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.419546] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 0.427447] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 0.436056] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.442961] RPC: Registered named UNIX socket transport module.
[ 0.449510] RPC: Registered udp transport module.
[ 0.454686] RPC: Registered tcp transport module.
[ 0.459872] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.467689] PCI: CLS 0 bytes, default 64
[ 0.472692] Initialise system trusted keyrings
[ 0.477833] workingset: timestamp_bits=62 max_order=21 bucket_order=0
[ 0.478029] Unpacking initramfs...
[ 0.490818] NFS: Registering the id_resolver key type
[ 0.496435] Key type id_resolver registered
[ 0.501051] Key type id_legacy registered
[ 0.505593] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.512986] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.521210] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.526308] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[ 0.533502] fuse: init (API version 7.34)
[ 0.576418] NET: Registered PF_ALG protocol family
[ 0.581729] Key type asymmetric registered
[ 0.586294] Asymmetric key parser 'x509' registered
[ 0.591774] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.599969] io scheduler mq-deadline registered
[ 0.604966] io scheduler kyber registered
[ 0.711921] clk-starfive-jh7110 13020000.clock-controller: starfive JH7110 clkgen init successfully.
[ 0.723187] L2CACHE: DataError @ 0x00000000.08040110
[ 0.728764] L2CACHE: DataFail @ 0x00000000.0804005B
[ 0.734231] L2CACHE: No. of Banks in the cache: 8
[ 0.739450] L2CACHE: No. of ways per bank: 16
[ 0.744255] L2CACHE: Sets per bank: 256
[ 0.748504] L2CACHE: Bytes per cache block: 64
[ 0.753415] L2CACHE: Index of the largest way enabled: 15
[ 0.759714] jh7110-pmu 17030000.power-controller: registered 8 power domains
[ 0.827678] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.837673] @@#########################@@
[ 0.880062] @@ dev ptr:ffffffe0bff00000/1500/1
[ 0.885213] PVR_K: 1: Read BVNC 36.50.54.182 from HW device registers
[ 0.892506] PVR_K: 1: RGX Device registered BVNC 36.50.54.182 with 1 core in the system
[ 0.902733] [drm] Initialized pvr 1.17.6210866 20170530 for 18000000.gpu on minor 0
[ 0.922807] loop: module loaded
[ 0.928807] spi-nor spi0.0: gd25lq128d (16384 Kbytes)
[ 1.188003] Freeing initrd memory: 9456K
[ 1.209018] 3 fixed-partitions partitions found on MTD device 13010000.spi.0
[ 1.216846] Creating 3 MTD partitions on "13010000.spi.0":
[ 1.222906] 0x000000000000-0x000000020000 : "spl"
[ 1.229879] 0x000000100000-0x000000400000 : "uboot"
[ 1.236827] 0x000000f00000-0x000001000000 : "data"
[ 1.244742] libphy: Fixed MDIO Bus: probed
[ 1.250757] CAN device driver interface
[ 1.255599] starfive-eth-plat 16030000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.266996] starfive-eth-plat 16030000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 1.275254] starfive-eth-plat 16030000.ethernet: DWMAC4/5
[ 1.281322] starfive-eth-plat 16030000.ethernet: DMA HW capability register supported
[ 1.289965] starfive-eth-plat 16030000.ethernet: RX Checksum Offload Engine supported
[ 1.298610] starfive-eth-plat 16030000.ethernet: Wake-Up On Lan supported
[ 1.306096] starfive-eth-plat 16030000.ethernet: TSO supported
[ 1.312526] starfive-eth-plat 16030000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.321752] starfive-eth-plat 16030000.ethernet: Enabled Flow TC (entries=1)
[ 1.329529] starfive-eth-plat 16030000.ethernet: TSO feature enabled
[ 1.336538] starfive-eth-plat 16030000.ethernet: Using 40 bits DMA width
[ 1.595628] libphy: stmmac: probed
[ 1.599405] YT8531 Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 1.610368] YT8531 Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 1.622525] starfive-eth-plat 16040000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 1.633935] starfive-eth-plat 16040000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 1.642214] starfive-eth-plat 16040000.ethernet: DWMAC4/5
[ 1.648282] starfive-eth-plat 16040000.ethernet: DMA HW capability register supported
[ 1.656927] starfive-eth-plat 16040000.ethernet: RX Checksum Offload Engine supported
[ 1.665568] starfive-eth-plat 16040000.ethernet: Wake-Up On Lan supported
[ 1.673042] starfive-eth-plat 16040000.ethernet: TSO supported
[ 1.679492] starfive-eth-plat 16040000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 1.688734] starfive-eth-plat 16040000.ethernet: Enabled Flow TC (entries=1)
[ 1.696514] starfive-eth-plat 16040000.ethernet: TSO feature enabled
[ 1.703513] starfive-eth-plat 16040000.ethernet: Using 40 bits DMA width
[ 1.961862] libphy: stmmac: probed
[ 1.965668] YT8512B Ethernet stmmac-1:00: attached PHY driver (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 1.975959] YT8512B Ethernet stmmac-1:03: attached PHY driver (mii_bus:phy_addr=stmmac-1:03, irq=POLL)
[ 1.987796] Intel(R) Wireless WiFi driver for Linux
[ 1.995115] cdns3-starfive 10210000.usbdrd: usb mode 2 2.0 probe success
[ 2.003325] usbcore: registered new interface driver uas
[ 2.009260] usbcore: registered new interface driver usb-storage
[ 2.035861] starfive-rtc 17040000.rtc: registered as rtc0
[ 2.041827] starfive-rtc 17040000.rtc: setting system clock to 2001-01-01T00:00:00 UTC (978307200)
[ 2.051877] i2c_dev: i2c /dev entries driver
[ 2.056846] usbcore: registered new interface driver uvcvideo
[ 2.064352] starfive-wdt 13070000.wdog: Heartbeat: timeout=15, count/2=180000000 (0aba9500)
[ 2.074106] Bluetooth: HCI UART driver ver 2.3
[ 2.079035] Bluetooth: HCI UART protocol H4 registered
[ 2.084911] starfive-cpufreq soc:starfive,jh7110-cpufreq: Failed to get regulator for cpu!
[ 2.094051] starfive-cpufreq soc:starfive,jh7110-cpufreq: Failed to init starfive cpu dvfs info
[ 2.104222] sdhci: Secure Digital Host Controller Interface driver
[ 2.111064] sdhci: Copyright(c) Pierre Ossman
[ 2.115909] Synopsys Designware Multimedia Card Interface Driver
[ 2.122831] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.129897] jh7110-sec 16000000.crypto: Unable to request sec_m dma channel in DMA channel
[ 2.139043] jh7110-sec 16000000.crypto: Cannot initial dma chan
[ 2.145872] usbcore: registered new interface driver usbhid
[ 2.152025] usbhid: USB HID core driver
[ 2.156517] usbcore: registered new interface driver snd-usb-audio
[ 2.171420] NET: Registered PF_PACKET protocol family
[ 2.177067] can: controller area network core
[ 2.181983] NET: Registered PF_CAN protocol family
[ 2.187294] can: raw protocol
[ 2.190568] can: broadcast manager protocol
[ 2.195188] can: netlink gateway - max_hops=1
[ 2.200352] Bluetooth: RFCOMM TTY layer initialized
[ 2.205775] Bluetooth: RFCOMM socket layer initialized
[ 2.211471] Bluetooth: RFCOMM ver 1.11
[ 2.215666] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.221523] Bluetooth: BNEP filters: protocol multicast
[ 2.227307] Bluetooth: BNEP socket layer initialized
[ 2.232965] 9pnet: Installing 9P2000 support
[ 2.237755] Key type dns_resolver registered
[ 2.243231] Loading compiled-in X.509 certificates
[ 2.284903] starfive_jh7110-pinctrl 13040000.gpio: SiFive GPIO chip registered 64 GPIOs
[ 2.294542] starfive_jh7110-pinctrl 17020000.gpio: SiFive GPIO chip registered 4 GPIOs
[ 2.303544] pl08xdmac 16008000.sec_dma: initialized 8 virtual memcpy channels
[ 2.311462] pl08xdmac 16008000.sec_dma: initialized 16 virtual slave channels
[ 2.320992] debugfs: Directory '16008000.sec_dma' with parent 'dmaengine' already present!
[ 2.330163] pl08xdmac 16008000.sec_dma: DMA: PL080 rev0 at 0x16008000 irq 23
[ 2.338214] ssp-pl022 10060000.spi: ARM PL022 driver for StarFive SoC platform, device ID: 0x00041022
[ 2.348436] ssp-pl022 10060000.spi: mapped registers from 0x0000000010060000 to (____ptrval____)
[ 2.358603] ssp-pl022 10060000.spi: Requested frequency: 10000000 Hz is unsupported,select by default 8250000 Hz
[ 2.370216] ssp-pl022 10060000.spi: will use autosuspend for runtime pm, delay 100ms
[ 2.380104] i2c 2-0045: Fixing up cyclic dependency with 295d0000.mipi
[ 2.387589] seeed_panel 2-0045: Unknown Atmel firmware revision: 0x00
[ 2.394896] i2c 2-0019: Fixing up cyclic dependency with 295d0000.mipi
[ 2.403558] at24 5-0050: supply vcc not found, using dummy regulator
[ 2.411378] at24 5-0050: 512 byte 24c04 EEPROM, writable, 16 bytes/write
[ 2.420733] axp15060-regulator 5-0036: Register mipi_0p9 done! vol range:900 ~ 900 mV
[ 2.430873] axp15060-regulator 5-0036: Register hdmi_1p8 done! vol range:1800 ~ 1800 mV
[ 2.441244] axp15060-regulator 5-0036: Register hdmi_0p9 done! vol range:900 ~ 900 mV
[ 2.451437] axp15060-regulator 5-0036: Register cpu_vdd done! vol range:500 ~ 1540 mV
[ 2.460866] i2c 6-0010: Fixing up cyclic dependency with 19800000.vin_sysctl
[ 2.469073] imx219 6-0010: supply VANA not found, using dummy regulator
[ 2.476503] imx219 6-0010: supply VDIG not found, using dummy regulator
[ 2.483848] imx219 6-0010: supply VDDL not found, using dummy regulator
[ 2.498675] imx219 6-0010: failed to read chip id 219
[ 2.504464] imx219: probe of 6-0010 failed with error -5
[ 2.512973] pcie_plda 2b000000.pcie: host bridge /soc/pcie@2B000000 ranges:
[ 2.520742] pcie_plda 2b000000.pcie: MEM 0x0030000000..0x0037ffffff -> 0x0030000000
[ 2.529695] pcie_plda 2b000000.pcie: MEM 0x0900000000..0x093fffffff -> 0x0900000000
[ 2.538684] ATR entry: 0x0940000000 -> 0x0000000000 [0x0010000000] (param: 0x000001)
[ 2.547252] ATR entry: 0x0030000000 -> 0x0030000000 [0x0008000000] (param: 0x000000)
[ 2.555818] ATR entry: 0x0900000000 -> 0x0900000000 [0x0040000000] (param: 0x000000)
[ 2.905622] pcie_plda 2b000000.pcie: Port link up.
[ 2.911068] pcie_plda 2b000000.pcie: PCI host bridge to bus 0000:00
[ 2.918006] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.924059] pci_bus 0000:00: root bus resource [mem 0x30000000-0x37ffffff]
[ 2.931662] pci_bus 0000:00: root bus resource [mem 0x900000000-0x93fffffff pref]
[ 2.939955] pci 0000:00:00.0: [1556:1111] type 01 class 0x060400
[ 2.946599] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0xffffffff 64bit pref]
[ 2.954625] pci 0000:00:00.0: supports D1 D2
[ 2.959343] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.970175] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.979164] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 2.985819] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 2.993383] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 3.002897] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.010234] pci 0000:00:00.0: BAR 0: no space for [mem size 0x100000000 64bit pref]
[ 3.018703] pci 0000:00:00.0: BAR 0: failed to assign [mem size 0x100000000 64bit pref]
[ 3.027554] pci 0000:00:00.0: BAR 8: assigned [mem 0x30000000-0x300fffff]
[ 3.035039] pci 0000:01:00.0: BAR 0: assigned [mem 0x30000000-0x30000fff 64bit]
[ 3.043134] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 3.048621] pci 0000:00:00.0: bridge window [mem 0x30000000-0x300fffff]
[ 3.056218] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 3.062460] pci 0000:01:00.0: enabling device (0000 -> 0002)
[ 3.068742] pci 0000:01:00.0: quirk_usb_early_handoff+0x0/0x9d4 took 12239 usecs
[ 3.077131] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 3.082919] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 3.091487] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000040000000890
[ 3.101647] pcie_plda 2b000000.pcie: msi#0 address_hi 0x0 address_lo 0x190
[ 3.109600] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 3.115375] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 3.123565] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 3.131216] hub 1-0:1.0: USB hub found
[ 3.135392] hub 1-0:1.0: 1 port detected
[ 3.140782] hub 2-0:1.0: USB hub found
[ 3.144957] hub 2-0:1.0: 4 ports detected
[ 3.152230] pcie_plda 2c000000.pcie: host bridge /soc/pcie@2C000000 ranges:
[ 3.159987] pcie_plda 2c000000.pcie: MEM 0x0038000000..0x003fffffff -> 0x0038000000
[ 3.168955] pcie_plda 2c000000.pcie: MEM 0x0980000000..0x09bfffffff -> 0x0980000000
[ 3.177947] ATR entry: 0x09c0000000 -> 0x0000000000 [0x0010000000] (param: 0x000001)
[ 3.186518] ATR entry: 0x0038000000 -> 0x0038000000 [0x0008000000] (param: 0x000000)
[ 3.195067] ATR entry: 0x0980000000 -> 0x0980000000 [0x0040000000] (param: 0x000000)
[ 3.355573] usb usb2-port2: over-current condition
[ 3.455600] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 3.515602] usb usb2-port4: over-current condition
[ 3.555649] pcie_plda 2c000000.pcie: Port link up.
[ 3.561124] pcie_plda 2c000000.pcie: PCI host bridge to bus 0001:00
[ 3.568083] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 3.574138] pci_bus 0001:00: root bus resource [mem 0x38000000-0x3fffffff]
[ 3.581740] pci_bus 0001:00: root bus resource [mem 0x980000000-0x9bfffffff pref]
[ 3.590032] pci 0001:00:00.0: [1556:1111] type 01 class 0x060400
[ 3.596679] pci 0001:00:00.0: reg 0x10: [mem 0x00000000-0xffffffff 64bit pref]
[ 3.604704] pci 0001:00:00.0: supports D1 D2
[ 3.609424] pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.620264] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 3.629249] pci 0001:01:00.0: [1987:5013] type 00 class 0x010802
[ 3.635911] pci 0001:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 3.638222] hub 1-1:1.0: USB hub found
[ 3.643536] pci 0001:01:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0001:00:00.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[ 3.648563] hub 1-1:1.0: 4 ports detected
[ 3.667405] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
[ 3.675796] pci 0001:00:00.0: BAR 0: no space for [mem size 0x100000000 64bit pref]
[ 3.684250] pci 0001:00:00.0: BAR 0: failed to assign [mem size 0x100000000 64bit pref]
[ 3.693098] pci 0001:00:00.0: BAR 8: assigned [mem 0x38000000-0x380fffff]
[ 3.700593] pci 0001:01:00.0: BAR 0: assigned [mem 0x38000000-0x38003fff 64bit]
[ 3.708688] pci 0001:00:00.0: PCI bridge to [bus 01]
[ 3.714160] pci 0001:00:00.0: bridge window [mem 0x38000000-0x380fffff]
[ 3.722096] nvme nvme0: pci function 0001:01:00.0
[ 3.727354] pci 0001:00:00.0: enabling device (0000 -> 0002)
[ 3.733602] nvme 0001:01:00.0: enabling device (0000 -> 0002)
[ 3.740064] pcie_plda 2c000000.pcie: msi#0 address_hi 0x0 address_lo 0x190
[ 3.741011] clk-starfive-jh7110-vout 295c0000.clock-controller: starfive JH7110 clk_vout init successfully.
[ 3.770042] clk-starfive-jh7110-isp 19810000.clock-controller: starfive JH7110 clk_isp init successfully.
[ 3.781256] dw_axi_dmac_platform 16050000.dma-controller: DesignWare AXI DMA Controller, 4 channels
[ 3.792313] printk: console [ttyS0] disabled
[ 3.817274] 10000000.serial: ttyS0 at MMIO 0x10000000 (irq = 17, base_baud = 1500000) is a 16550A
[ 3.827127] printk: console [ttyS0] enabled
[ 3.835934] printk: bootconsole [uart0] disabled
[ 3.846340] jh7110-vin 19800000.vin_sysctl: stfcamss probe enter!
[ 3.854816] jh7110-vin 19800000.vin_sysctl: stfcamss probe success!
[ 3.863702] dwmmc_starfive 16010000.sdio0: IDMAC supports 32-bit address mode.
[ 3.864261] jh7110-sec 16000000.crypto: will run requests pump with realtime priority
[ 3.871044] dwmmc_starfive 16010000.sdio0: Using internal DMA controller.
[ 3.879760] dwmmc_starfive 16020000.sdio1: IDMAC supports 32-bit address mode.
[ 3.882148] jh7110-sec 16000000.crypto: Initialized
[ 3.883235] starfive-i2s 120b0000.i2stx_4ch0: designware: play supported
[ 3.883245] starfive-i2s 120b0000.i2stx_4ch0: designware: i2s master mode supported
[ 3.883419] sf-mipi-dphy-tx 295e0000.mipi-dphy: sf_dphy_probe begin
[ 3.883428] sf-mipi-dphy-tx 295e0000.mipi-dphy: ===> sf_dphy_probe enter, 445
[ 3.883562] sf-mipi-dphy-tx 295e0000.mipi-dphy: control ECO
[ 3.883582] sf-mipi-dphy-tx 295e0000.mipi-dphy: supply mipi_1p8 not found, using dummy regulator
[ 3.883855] sf-mipi-dphy-tx 295e0000.mipi-dphy: sf_dphy_probe end
[ 3.884044] cdns-dsi 295d0000.mipi: dsi_sys_clk = 297000000
[ 3.884289] cdns-dsi 295d0000.mipi: starfive dsi bind end
[ 3.885729] dwmmc_starfive 16010000.sdio0: Version ID is 290a
1;-1fdone.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... done.
Warning: fsck not present, so skipping root file system
[ 7.546940] EXT4-fs (mmcblk1p3): recovery complete
[ 7.551824] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: disabled.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
[ 7.764568] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 7.772312] CPU: 3 PID: 1 Comm: init Not tainted 5.15.0-starfive #1
/sbin/init: error while loading shared libraries: /usr/lib/riscv64-linux-gnu/systemd/libsystemd-core-251.so: invalid ELF header
[ 7.789889] Hardware name: StarFive VisionFive V2 (DT)
[ 7.789895] Call Trace:
[ 7.789904] [<ffffffff8000488e>] dump_backtrace+0x1c/0x24
[ 7.789924] [<ffffffff809977c8>] dump_stack_lvl+0x40/0x58
[ 7.789943] [<ffffffff809977f4>] dump_stack+0x14/0x1c
[ 7.789956] [<ffffffff80994cc8>] panic+0xf4/0x29e
[ 7.789968] [<ffffffff8000e024>] do_exit+0x7da/0x7e0
[ 7.823063] [<ffffffff8000ed28>] do_group_exit+0x2a/0x7e
[ 7.823069] [<ffffffff8000ed94>] __wake_up_parent+0x0/0x20
[ 7.823076] [<ffffffff80003046>] ret_from_syscall+0x0/0x2
[ 7.839256] SMP: stopping secondary CPUs
[ 7.843190] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00 ]---
