Section mismatch while building the kernel
For those who compile your own kernel, did you ever saw this warnings? Are they something I should worry, or can be ignored?
I just searched for clk_starfive_jh7110_ and came across changes to clk-starfive-jh7110-vout.c and clk-starfive-jh7110-isp.c recorded at lore.kernel.org 8 days ago.
Add StarFive JH7110 Video-Output clock driver - Xingyu Wu
Add StarFive JH7110 Image-Signal-Process clock driver - Xingyu Wu
Can you confirm if this is the 5.15.0-starfive kernel source from git, or is there somewhere to get a later kernel?..
I’ve rolled the starfive sources I have forward to 5.15.94, but I really need 6.1+
@blueadept - do you have your forward rolled kernel or even better a patch for it against the vf2 v5.15.0 kernel somewhere on github etc.? i once tried it myself but gave up at some point, but was not that much to fix in the end … i guess v6.1 will take a bit of time - i assume you are aware of GitHub - starfive-tech/linux at JH7110_VisionFive2_upstream - right? i have no idea what is working with it and what not and if anything works at all …
best wishes - hexdump
Hope it’s of some use… I’m not really very experienced such obscure platforms, but well… I wanted BTRFS on my NVMe drive, and that got me looking at the kernel sources.
https://mail.fsck.co.uk/tmp/
Let me know if it works for you too!.. I wasn’t aware of the github you linked… my sources came from the entire image tree documented on starfive’s site:- git@github.com:starfive-tech/VisionFive2.git
I’ll upload my package for coccinelle also, as this blocked me for a while, and it’s a right pain to compile!
Edit: Oops, didn’t notice they had branches in there with 6.x kernels in… might give one of them a go at some stage.
