Repost: OpenWrt 24.10 released with Linux 6.6, TLS 1.3 by default
OpenWrt 24.10 highlights:
  • TLS 1.3 support in default images with MbedTLS 3.6
  • Activate POSIX Access Control Lists and file system security attributes for all file systems on devices with big flash sizes. Needed by docker. Note this is not enabled for all targets with the small_flash feature flag, including ath79/tiny, bcm47xx/legacy, lantiq/ase, lantiq/xrx200_legacy, lantiq/xway_legacy, ramips/mt76x8, ramips/rt288x, ramips/rt305x and ramips/rt3883 targets.
  • Activate kernel support for Multipath TCP on devices with big flash sizes.
  • Improved support for WiFi 6 (802.11ax) and initial support for WiFi 7 (802.11be)
  • Improved Link Layer Discovery Protocol (LLDP) support
  • OpenWrt 24.10 uses OPKG only, APK packages are NOT supported. Only the main branch was changed to APK.
  • Updated package versions
    • Linux kernel – 6.6.73 for all targets
    • Toolchain – musl libc 1.2.5, glibc 2.38,gcc 13.3.0, binutils 2.42
    • Network:
      • hostapd master snapshot from September 2024, dnsmasq 2.90, dropbear 2024.86
      • cfg80211/mac80211 from kernel 6.12.6
The following targets were added:
I have downloaded the latest openwrt 24.10,0 firmware for visionfive2 v1.3b and installed it on my SBC. It doesn’t boot leaving messages “broken atomics modeset disabled atomics” and mipi_0p9 disabled. the SBC runs the latest debian version and had updated uboot and payload. I have checked the sha256sum and used different sdcards
Did you take a look at this page The OpenWrt Firmware Selector - #1263 by daniarla - Release and security announcements - OpenWrt Forum ? It seems that you’re not the only one and it fixed by itself…
the references are about problems upgrading OpenWrt. I am trying to install the newest version 24.10.0. As I mentioned, I have checked the sha256sum of the download, have updated the uboot and payload packages and have use multiple sdcards without success. My VisionFive2 runs debian 202409 successfully from sdcard and from nvme.
I tried the openwrt 24.10.1 and 24.10.2 on my VF2 1.3b successfully. However, now I am stuck trying to boot openwrt 24.10.2 again with messages card didnot respond to voltage select: -110; failed autoconfig bar 10; Device 0: unknown device. I have checked the ssh256sum tried several sdcards without success. I have setenv default -f -a and other StarFive # commands. I want to get this board working as a router again.
I booted Debian 2409pro-20250418.img successfully after booting openwrt 24.10.2 and my current failure to boot openwrt 24.10.2 again. I have flashed sdcard.img, u-boot-spl.bin.normal.out and visionfive-fw-payload.img from March 2025 in attempt to fix the problem.
