Reboot重启总是卡住
Debian 202306版本
提示如下
[ OK ] Reached target final.target - Late Shutdown Services.
[ OK ] Finished systemd-reboot.service - System Reboot.
[ OK ] Reached target reboot.target - System Reboot.
[86244.507323] systemd-shutdown[1]: Using hardware watchdog ‘StarFive Watchdog’, version 0, device /dev/watchdog0
[86244.524692] systemd-shutdown[1]: Failed to set timeout to 10min: Invalid argument
[86244.578398] systemd-shutdown[1]: Syncing filesystems and block devices.
[86245.272035] systemd-shutdown[1]: Sending SIGTERM to remaining processes…
[86245.300713] systemd-journald[252]: Received SIGTERM from PID 1 (systemd-shutdow).
[86245.367178] systemd-shutdown[1]: Sending SIGKILL to remaining processes…
[86245.382202] systemd-shutdown[1]: Unmounting file systems.
[86245.389284] (sd-remount)[14853]: Remounting ‘/’ read-only with options ‘’.
[86245.515219] EXT4-fs (mmcblk1p4): re-mounted. Opts: (null). Quota mode: disabled.
[86245.585087] systemd-shutdown[1]: All filesystems unmounted.
[86245.590938] systemd-shutdown[1]: Deactivating swaps.
[86245.596336] systemd-shutdown[1]: All swaps deactivated.
[86245.602015] systemd-shutdown[1]: Detaching loop devices.
[86245.617066] systemd-shutdown[1]: All loop devices detached.
[86245.623130] systemd-shutdown[1]: Stopping MD devices.
[86245.628977] systemd-shutdown[1]: All MD devices stopped.
[86245.634694] systemd-shutdown[1]: Detaching DM devices.
[86245.640535] systemd-shutdown[1]: All DM devices detached.
[86245.646312] systemd-shutdown[1]: All filesystems, swaps, loop devices, MD devices and DM devices detached.
[86245.659191] systemd-shutdown[1]: Syncing filesystems and block devices.
[86245.666083] systemd-shutdown[1]: Rebooting.
[86245.717224] reboot: Restarting system
dwmci_s: Response Timeout.
BOOT fail, Error is 0xffffffff
reboot 10回能有一次能正常起来就是烧高香了。 我都是用树莓控制这个板子的电源,想重启了控制树莓派GPIO。 树莓派就在那静静的吃灰、稳定的一批
dwmci 是啥设备?我查了一下,是 mmc 的驱动?
你是不是用的 emmc 而不是 TF 卡?
是用的tf卡,除了接了HDMI显示器和TF卡没有接任何其他东西。按键重启可以启动,上电重启也可以启动。
换个 TF 卡试试?
按重启键应该是忽略各种设备操作而直接硬重启的,这东西能重启说明不了什么问题……
@qinyunti 可以尝试一下从QSPI Nor Flash启动试试。
