You can play PSP games on VisionFive 2 Now! The frame rate and performance of the game are constantly improving, and developers are welcome to try it out. Go to downloads to get it!
For graphics, currently you have to use GLES. As long as youâre using the Debian image, you should be able to just use the included driver. For Vulkan, thereâs an issue in the driver and itâs unusably slow. It may default to Vulkan still, in which case youâd need to change to GLES.
The IR is a custom IR - PPSSPPâs jit for RISC-V is now using that IR, and Iâve also written a new jit for x64 (~10% faster, depends on the game) and arm64 (about even, disappointingly, with the old jit) that use the IR as well. But itâs custom-designed for our purposes - debugging metadata, cycle tracking, and specific ops to match the PSPâs complex matrix-based SIMD coprocessor.
A note for performance on the VisionFive 2 - youâll likely want to turn on âlazy texture hashingâ. This can result in a few graphical glitches, but currently the texture hashing is very expensive. Also, the community has created a patch for God of War which reduces its internal FPS to 30 FPS, and this makes it far more playable on ARM and RISC-V devices of VisionFive 2âs performance class.
Iâm gonna try it on the ArchLinux image. Iâve been maintaining the PKGBUILD for mesa for Arch and recently got retroarch and a few SDL2 apps that use GLES working well.
I noticed itâs not in github actions or the release page. Do you need help with CI? I could try to set something up to run on âdocker on qemu riscv64â aka docker buildx. I did something similar with psptoolchain but never finished it end to end.
You can pick between clang and gcc, just use update-alternatives to set your preference beforehand. You can skip mold if you want, but I recommend it - it links much faster (youâll need apt-get install git build-essential cmake mold ninja-build.)
In the past I had to rebuild SDL for GLES to work. I just did it last time I updated the image, without checking if itâs still necessary. If it is still needed, I just used ./configure --disable-video-opengl for it.
I also had to run these, but again mightâve been a problem from a previous image only:
If anyone wants to contribute / maintain binaries, thatâs always appreciated. All the builds outside Windows and Android are contributed.
A RISC-V GitHub Actions setup would be convenient if it could slot in to running the normal build commands. It would actually be most convenient there to just directly cross compile - compiling within qemu doesnât seem all that useful, except a way to make builds take longer. Could run tests within qemu though.
I got it built and running on the VF2 ArchRiscv image but only on X11, when I tried wayland I got an EGL_BAD_NATIVE_WINDOW error any time I tried to interact with (hover mouse over) the ppsspp window. Any ideas about that @unknownbrackets ? It might be my fault as Iâm using best-guess flags with starfiveâs buildroot patches to build mesa. But thought I should mention it just in case.
