内核启动时卡住,然后提示 nvme nvme0: I/O 401 QID 4 timeout, completion polled,硬盘型号为:致态 PC005 Active 512GB
kernel log
U-Boot SPL 2021.10 (Dec 25 2022 - 20:59:18 +0800)
DDR version: dc2e84f0.
Trying to boot from SPI
OpenSBI v1.0
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform Reboot Device : ---
Firmware Base : 0x40000000
Firmware Size : 360 KB
Runtime SBI Version : 0.3
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Region01 : 0x0000000040000000-0x000000004007ffff ()
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Dec 25 2022 - 20:59:18 +0800), Build: jenkins-github_visionfive2-4
CPU: rv64imacu
Model: StarFive VisionFive V2
DRAM: 4 GiB
Product full SN: VF7110A1-2249-D004E000-00000808
PCB revision: 0xa1
Ethernet MAC0 address: 6c:cf:39:00:19:ad
Ethernet MAC1 address: 6c:cf:39:00:19:ae
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
switch to partitions #0, OK
mmc1 is current device
found device 1
bootmode flash device 1
** Invalid partition 3 **
Couldn't find partition mmc 1:3
Can't set block device
## Info: input data size = 39526 = 0x9A66
** Invalid partition 2 **
Couldn't find partition mmc 1:2
## Error: "boot2" not defined
Scanning mmc 1:1...
Found /boot/extlinux/extlinux.conf
383 bytes read in 5 ms (74.2 KiB/s)
1: Armbian
Retrieving file: /boot/uInitrd
12042358 bytes read in 507 ms (22.7 MiB/s)
Retrieving file: /boot/Image
22053888 bytes read in 925 ms (22.7 MiB/s)
append: root=UUID=94b4a2a8-b3fc-4953-9eac-b966a56df7dd console=ttyS0,115200n8 console=tty0 earlycon=sbi rootflags=data=writeback stmmaceth=chain_mode:1 rw rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles
Retrieving file: /boot/dtb/starfive/jh7110-visionfive-v2.dtb
48025 bytes read in 9 ms (5.1 MiB/s)
## Loading init Ramdisk from Legacy Image at 46100000 ...
Image Name: uInitrd
Image Type: RISC-V Linux RAMDisk Image (gzip compressed)
Data Size: 12042294 Bytes = 11.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 46000000
Booting using the fdt blob at 0x46000000
Using Device Tree in place at 0000000046000000, end 000000004600eb98
Starting kernel ...
[ 0.000000] Linux version 5.15.0-starfive2 (armbian@next) (riscv64-linux-gnu-gcc (Ubuntu 11.3.0-1ubuntu1~22.04) 11.3.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP Mon Feb 20 02:51:35 UTC 2023
[ 0.000000] OF: fdt: Ignoring memory range 0x40000000 - 0x40200000
[ 0.000000] earlycon: sbi0 at I/O port 0x0 (options '')
[ 0.000000] printk: bootconsole [sbi0] enabled
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040200000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000013fffffff]
[ 0.000000] node 0: [mem 0x0000000040200000-0x00000000c010ffff]
[ 0.000000] node 0: [mem 0x00000000c0200000-0x000000013fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040200000-0x000000013fffffff]
[ 0.000000] SBI specification v0.3 detected
[ 0.000000] SBI implementation ID=0x1 Version=0x10000
[ 0.000000] SBI v0.2 HSM extension detected
[ 0.000000] riscv: base ISA extensions acdfim
[ 0.000000] percpu: Embedded 17 pages/cpu s32552 r8192 d28888 u69632
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1033735
[ 0.000000] Kernel command line: root=UUID=94b4a2a8-b3fc-4953-9eac-b966a56df7dd console=ttyS0,115200n8 console=tty0 earlycon=sbi rootflags=data=writeback stmmaceth=chain_mode:1 rw rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles
[ 0.000000] Unknown command line parameters: splash stmmaceth=chain_mode:1
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 3449060K/4192256K available (10127K kernel code, 5004K rwdata, 4096K rodata, 2196K init, 411K bss, 218908K reserved, 524288K cma-reserved)
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] random: get_random_bytes called from start_kernel+0x4c4/0x6d6 with crng_init=0
[ 0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [1]
[ 0.008242] clocksource: timer@13050000.ch0: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.018466] clocksource: timer@13050000.ch1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.028779] clocksource: timer@13050000.ch2: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.039094] clocksource: timer@13050000.ch3: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.049574] Console: colour dummy device 80x25
[ 0.053944] printk: console [tty0] enabled
[ 0.058100] printk: bootconsole [sbi0] disabled
[ 0.062741] Calibrating delay loop (skipped), value calculated using timer frequency.. 8.00 BogoMIPS (lpj=40000)
[ 0.062792] pid_max: default: 32768 minimum: 301
[ 0.062983] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.063098] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.064581] ASID allocator disabled
[ 0.064700] rcu: Hierarchical SRCU implementation.
[ 0.064903] EFI services will not be available.
[ 0.065317] smp: Bringing up secondary CPUs ...
[ 0.066982] smp: Brought up 1 node, 4 CPUs
[ 0.068156] devtmpfs: initialized
[ 0.076380] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.076439] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.089676] pinctrl core: initialized pinctrl subsystem
[ 0.090607] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.091413] cpuidle: using governor menu
[ 0.114053] platform soc:dsi-output: Fixing up cyclic dependency with 29400000.dc8200
[ 0.114637] platform 295d0000.mipi: Fixing up cyclic dependency with soc:dsi-output
[ 0.115109] platform 29590000.hdmi: Fixing up cyclic dependency with 29400000.dc8200
[ 0.127822] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.127864] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.131059] vgaarb: loaded
[ 0.131326] SCSI subsystem initialized
[ 0.131681] usbcore: registered new interface driver usbfs
[ 0.131755] usbcore: registered new interface driver hub
[ 0.131813] usbcore: registered new device driver usb
[ 0.132122] mc: Linux media interface: v0.10
[ 0.132171] videodev: Linux video capture interface: v2.00
[ 0.132408] Advanced Linux Sound Architecture Driver Initialized.
[ 0.132826] Bluetooth: Core ver 2.22
[ 0.132915] NET: Registered PF_BLUETOOTH protocol family
[ 0.132944] Bluetooth: HCI device and connection manager initialized
[ 0.132982] Bluetooth: HCI socket layer initialized
[ 0.133016] Bluetooth: L2CAP socket layer initialized
[ 0.133057] Bluetooth: SCO socket layer initialized
[ 0.133443] clocksource: Switched to clocksource riscv_clocksource
[ 0.140789] NET: Registered PF_INET protocol family
[ 0.141485] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.145518] tcp_listen_portaddr_hash hash table entries: 2048 (order: 4, 81920 bytes, linear)
[ 0.145691] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.146150] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 0.147400] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.147723] UDP hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 0.147964] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes, linear)
[ 0.148433] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.149221] RPC: Registered named UNIX socket transport module.
[ 0.149264] RPC: Registered udp transport module.
[ 0.149289] RPC: Registered tcp transport module.
[ 0.149314] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.150033] PCI: CLS 0 bytes, default 64
[ 0.150878] Initialise system trusted keyrings
[ 0.151070] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 0.153715] Unpacking initramfs...
[ 0.157735] NFS: Registering the id_resolver key type
[ 0.157792] Key type id_resolver registered
[ 0.157820] Key type id_legacy registered
[ 0.157940] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.157977] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.158042] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.158279] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[ 0.158667] fuse: init (API version 7.34)
[ 0.197337] NET: Registered PF_ALG protocol family
[ 0.197398] Key type asymmetric registered
[ 0.197426] Asymmetric key parser 'x509' registered
[ 0.197537] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.197582] io scheduler mq-deadline registered
[ 0.197611] io scheduler kyber registered
[ 0.302534] clk-starfive-jh7110 13020000.clock-controller: starfive JH7110 clkgen init successfully.
[ 0.303782] L2CACHE: DataError @ 0x00000000.080400F0
[ 0.303868] L2CACHE: DataFail @ 0x00000000.0804005B
[ 0.303972] L2CACHE: No. of Banks in the cache: 8
[ 0.304007] L2CACHE: No. of ways per bank: 16
[ 0.304039] L2CACHE: Sets per bank: 256
[ 0.304071] L2CACHE: Bytes per cache block: 64
[ 0.304108] L2CACHE: Index of the largest way enabled: 15
[ 0.304392] jh7110-pmu 17030000.power-controller: registered 8 power domains
[ 0.364783] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[ 0.368062] @@#########################@@
[ 0.406174] @@ dev ptr:ffffffe0bfede000/1500/1
[ 0.406470] PVR_K: 1: Read BVNC 36.50.54.182 from HW device registers
[ 0.406574] PVR_K: 1: RGX Device registered BVNC 36.50.54.182 with 1 core in the system
[ 0.707636] Freeing initrd memory: 11756K
[ 0.708123] pvrsrvkm 18000000.gpu: Direct firmware load for rgx.fw.36.50.54.182 failed with error -2
[ 0.708267] pvrsrvkm 18000000.gpu: Direct firmware load for rgx.fw.36.50p.54.182 failed with error -2
[ 0.708403] pvrsrvkm 18000000.gpu: Direct firmware load for rgx.fw failed with error -2
[ 0.708475] PVR_K:(Fatal): 1: All RGX Firmware image loads failed for 'rgx.fw.36.50.54.182' (PVRSRV_ERROR_NOT_FOUND) [1599]
[ 0.708572] PVR_K:(Error): 1: RGXInit: InitFirmware failed (275) [1556]
[ 0.708632] PVR_K:(Error): 1: RGXInit() failed (PVRSRV_ERROR_NOT_FOUND) in PVRSRVCommonDeviceInitialise() [2156]
[ 0.708730] PVR_K:(Error): 1: PVRSRVDeviceFinalise() failed (PVRSRV_ERROR_NOT_INITIALISED) in PVRSRVCommonDeviceInitialise() [2170]
[ 0.708833] [drm:pvr_drm_load] *ERROR* device (____ptrval____) initialisation failed (err=-19)
[ 0.719056] loop: module loaded
[ 0.721627] spi-nor spi0.0: gd25lq128d (16384 Kbytes)
[ 0.734971] 3 fixed-partitions partitions found on MTD device 13010000.spi.0
[ 0.735035] Creating 3 MTD partitions on "13010000.spi.0":
[ 0.735085] 0x000000000000-0x000000020000 : "spl"
[ 0.736854] 0x000000100000-0x000000400000 : "uboot"
[ 0.738411] 0x000000f00000-0x000001000000 : "data"
[ 0.741185] libphy: Fixed MDIO Bus: probed
[ 0.742741] CAN device driver interface
[ 0.743352] starfive-eth-plat 16030000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.743786] starfive-eth-plat 16030000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 0.743850] starfive-eth-plat 16030000.ethernet: DWMAC4/5
[ 0.743892] starfive-eth-plat 16030000.ethernet: DMA HW capability register supported
[ 0.743939] starfive-eth-plat 16030000.ethernet: RX Checksum Offload Engine supported
[ 0.743985] starfive-eth-plat 16030000.ethernet: Wake-Up On Lan supported
[ 0.744088] starfive-eth-plat 16030000.ethernet: TSO supported
[ 0.744131] starfive-eth-plat 16030000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.744193] starfive-eth-plat 16030000.ethernet: Enabled Flow TC (entries=1)
[ 0.744231] starfive-eth-plat 16030000.ethernet: TSO feature enabled
[ 0.744266] starfive-eth-plat 16030000.ethernet: Using 40 bits DMA width
[ 0.985579] libphy: stmmac: probed
[ 0.985634] YT8531 Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[ 0.985693] YT8531 Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[ 0.987014] starfive-eth-plat 16040000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
[ 0.987429] starfive-eth-plat 16040000.ethernet: User ID: 0x41, Synopsys ID: 0x52
[ 0.987487] starfive-eth-plat 16040000.ethernet: DWMAC4/5
[ 0.987528] starfive-eth-plat 16040000.ethernet: DMA HW capability register supported
[ 0.987575] starfive-eth-plat 16040000.ethernet: RX Checksum Offload Engine supported
[ 0.987621] starfive-eth-plat 16040000.ethernet: Wake-Up On Lan supported
[ 0.987728] starfive-eth-plat 16040000.ethernet: TSO supported
[ 0.987771] starfive-eth-plat 16040000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.987833] starfive-eth-plat 16040000.ethernet: Enabled Flow TC (entries=1)
[ 0.987872] starfive-eth-plat 16040000.ethernet: TSO feature enabled
[ 0.987906] starfive-eth-plat 16040000.ethernet: Using 40 bits DMA width
[ 1.231410] libphy: stmmac: probed
[ 1.231462] YT8512B Ethernet stmmac-1:00: attached PHY driver (mii_bus:phy_addr=stmmac-1:00, irq=POLL)
[ 1.231533] YT8512B Ethernet stmmac-1:03: attached PHY driver (mii_bus:phy_addr=stmmac-1:03, irq=POLL)
[ 1.233212] Intel(R) Wireless WiFi driver for Linux
[ 1.235371] cdns3-starfive 10210000.usbdrd: usb mode 2 2.0 probe success
[ 1.236241] usbcore: registered new interface driver uas
[ 1.236335] usbcore: registered new interface driver usb-storage
[ 1.253919] starfive-rtc 17040000.rtc: registered as rtc0
[ 1.253975] starfive-rtc 17040000.rtc: setting system clock to 2001-01-01T00:00:00 UTC (978307200)
