Not output to HDMI
Vision Five boards are working almost.
But only HDMI output doesn’t work.
I use EIZO E2415b(1280x1200)
Can you show me the boot log?
[ vmlinuz-5.15.10+  3.07MiB  30%  1.90MiB/s ]      [ vmlinuz-5.15.10+  9.13MiB  89%  3.31MiB/s ]      [ vmlinuz-5.15.10+  10.20MiB  100%  3.51MiB/s ]loader/efi/linux.c:75: UEFI stub kernel:
loader/efi/linux.c:76: PE/COFF header @ 00000040
loader/efi/linux.c:90: LoadFile2 initrd loading enabled
loader/efi/linux.c:439: kernel file size: 31792128
loader/efi/linux.c:441: kernel numpages: 7762
loader/efi/linux.c:458: kernel @ 0xce1ae000
loader/efi/fdt.c:63: allocating 22789 bytes for fdt
loader/efi/linux.c:177: linux command line: 'BOOT_IMAGE=/vmlinuz-5.15.10+ ro root=UUID=59fcd098-2f22-441a-ba45-4f7185baf23f rhgb console=tty0
console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0 LANG=en_US.UTF-8'
loader/efi/linux.c:192: starting image 0xff709ad0
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
loader/efi/linux.c:329: Providing initrd via LOAD_FILE2_PROTOCOL
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
[    0.000000] Linux version 5.15.10+ (fedora@soft04) (riscv64-linux-gnu-gcc (GCC) 11.2.1 20210728 (Red Hat Cross 11.2.1-1), GNU ld version 2.35.2-1.fc34) #1 SMP Fri Dec 24 14:24:27 CST 2021
[    0.000000] OF: fdt: Ignoring memory range 0x80000000 - 0x80200000
[    0.000000] Machine model: StarFive VisionFive V1
[    0.000000] earlycon: uart0 at MMIO32 0x0000000012440000 (options '115200n8')
[    0.000000] printk: bootconsole [uart0] enabled
[    0.000000] efi: EFI v2.90 by Das U-Boot
[    0.000000] efi: RTPROP=0xfe6d6040 MEMRESERVE=0xfe246040
[    0.000000] OF: fdt: Ignoring memory block 0x80000000 - 0x80080000
[    0.000000] OF: fdt: Ignoring memory range 0x80080000 - 0x80200000
[    0.000000] OF: reserved mem: failed to allocate memory for node 'linux,cma'
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000f9000000, size 16 MiB
[    0.000000] OF: reserved mem: initialized node framebuffer@f9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000fb000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node framebuffer@fb000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 32 MiB at 0x00000000ce000000
[    0.000000] Zone ranges:
[    0.000000]   DMA32    [mem 0x0000000080200000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000027fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080200000-0x00000000cfffffff]
[    0.000000]   node   0: [mem 0x00000000d0000000-0x00000000f7ffffff]
[    0.000000]   node   0: [mem 0x00000000f8000000-0x00000000f8ffffff]
[    0.000000]   node   0: [mem 0x00000000f9000000-0x00000000f9ffffff]
[    0.000000]   node   0: [mem 0x00000000fa000000-0x00000000faffffff]
[    0.000000]   node   0: [mem 0x00000000fb000000-0x00000000fcffffff]
[    0.000000]   node   0: [mem 0x00000000fd000000-0x00000000fe6d5fff]
[    0.000000]   node   0: [mem 0x00000000fe6d6000-0x00000000fe6d8fff]
[    0.000000]   node   0: [mem 0x00000000fe6d9000-0x00000000fe6d9fff]
[    0.000000]   node   0: [mem 0x00000000fe6da000-0x00000000fe6ddfff]
[    0.000000]   node   0: [mem 0x00000000fe6de000-0x00000000fff14fff]
[    0.000000]   node   0: [mem 0x00000000fff15000-0x00000000fff15fff]
[    0.000000]   node   0: [mem 0x00000000fff16000-0x000000027fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080200000-0x000000027fffffff]
[    0.000000] On node 0, zone DMA32: 512 pages in unavailable ranges
[    0.000000] SBI specification v0.3 detected
[    0.000000] SBI implementation ID=0x1 Version=0x10000
[    0.000000] SBI TIME extension detected
[    0.000000] SBI IPI extension detected
[    0.000000] SBI RFENCE extension detected
[    0.000000] SBI v0.2 HSM extension detected
[    0.000000] riscv: ISA extensions acdfim
[    0.000000] riscv: ELF capabilities acdfim
[    0.000000] percpu: Embedded 27 pages/cpu s71512 r8192 d30888 u110592
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2063880
[    0.000000] Kernel command line: BOOT_IMAGE=/vmlinuz-5.15.10+ ro root=UUID=59fcd098-2f22-441a-ba45-4f7185baf23f rhgb console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0 LANG=en_US.UTF-8
[    0.000000] Unknown kernel command line parameters "rhgb BOOT_IMAGE=/vmlinuz-5.15.10+ stmmaceth=chain_mode:1 LANG=en_US.UTF-8", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000c5000000-0x00000000c9000000] (64MB)
[    0.000000] Virtual kernel memory layout:
[    0.000000]       fixmap : 0xffffffcefee00000 - 0xffffffceff000000   (2048 kB)
[    0.000000]       pci io : 0xffffffceff000000 - 0xffffffcf00000000   (  16 MB)
[    0.000000]      vmemmap : 0xffffffcf00000000 - 0xffffffcfffffffff   (4095 MB)
[    0.000000]      vmalloc : 0xffffffd000000000 - 0xffffffdfffffffff   (65535 MB)
[    0.000000]       lowmem : 0xffffffe000000000 - 0xffffffe1ffe00000   (8190 MB)
[    0.000000]       kernel : 0xffffffff80000000 - 0xffffffffffffffff   (2047 MB)
[    0.000000] Memory: 7281392K/8386560K available (11293K kernel code, 5948K rwdata, 10240K rodata, 2570K init, 747K bss, 1072400K reserved, 32768K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x40/0x53c with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] ftrace: allocating 41516 entries in 163 pages
[    0.000000] ftrace: allocated 163 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] riscv-intc: 64 local interrupts mapped
[    0.000000] plic: disable L2 cache irq 128 in plic
[    0.000000] plic: disable L2 cache irq 131 in plic
[    0.000000] plic: disable L2 cache irq 129 in plic
[    0.000000] plic: disable L2 cache irq 130 in plic
[    0.000000] plic: interrupt-controller@c000000: mapped 127 interrupts with 2 handlers for 4 contexts.
[    0.000000] rcu: 	Offload RCU callbacks from CPUs: (none).
[    0.000000] riscv_timer_init_dt: Registering clocksource cpuid [0] hartid [0]
[    0.000000] clocksource: riscv_clocksource: mask: 0xffffffffffffffff max_cycles: 0x171024e6b, max_idle_ns: 440795202301 ns
[    0.000001] sched_clock: 64 bits at 6MHz, resolution 160ns, wraps every 4398046511040ns
[    0.008244] Console: colour dummy device 80x25
[    0.013685] printk: console [tty0] enabled
[    0.017901] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.50 BogoMIPS (lpj=62500)
[    0.028191] pid_max: default: 32768 minimum: 301
[    0.033021] LSM: Security Framework initializing
[    0.037664] Yama: becoming mindful.
[    0.041807] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.049924] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.062077] ASID allocator disabled
[    0.065818] rcu: Hierarchical SRCU implementation.
[    0.072309] Remapping and enabling EFI services.
[    0.077745] smp: Bringing up secondary CPUs ...
[    0.083779] smp: Brought up 1 node, 2 CPUs
[    0.092154] devtmpfs: initialized
[    0.102724] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.112596] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.123440] pinctrl core: initialized pinctrl subsystem
[    0.129943] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.136207] audit: initializing netlink subsys (disabled)
[    0.141980] audit: type=2000 audit(0.090:1): state=initialized audit_enabled=0 res=1
[    0.142591] thermal_sys: Registered thermal governor 'fair_share'
[    0.149745] thermal_sys: Registered thermal governor 'step_wise'
[    0.169261] platform 12000000.crtc: Fixing up cyclic dependency with soc:display-encoder
[    0.198079] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.204784] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.917925] alg: No test for 842 (842-generic)
[    0.922628] alg: No test for 842 (842-scomp)
[    0.949519] raid6: skip pq benchmark and using algorithm int64x8
[    0.955576] raid6: using intx1 recovery algorithm
[    0.960434] fbcon: Taking over console
[    0.964735] iommu: Default domain type: Translated
[    0.969629] iommu: DMA domain TLB invalidation policy: strict mode
[    0.976179] vgaarb: loaded
[    0.979607] SCSI subsystem initialized
[    0.983964] usbcore: registered new interface driver usbfs
[    0.989514] usbcore: registered new interface driver hub
[    0.994872] usbcore: registered new device driver usb
[    1.000203] mc: Linux media interface: v0.10
[    1.004513] videodev: Linux video capture interface: v2.00
[    1.010163] pps_core: LinuxPPS API ver. 1 registered
[    1.015117] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.024267] PTP clock support registered
[    1.028533] EDAC MC: Ver: 3.0.0
[    1.032144] Registered efivars operations
[    1.036745] Advanced Linux Sound Architecture Driver Initialized.
[    1.043709] NetLabel: Initializing
[    1.047132] NetLabel:  domain hash size = 128
[    1.051488] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.057244] NetLabel:  unlabeled traffic allowed by default
[    1.063403] clocksource: Switched to clocksource riscv_clocksource
[    1.192332] VFS: Disk quotas dquot_6.6.0
[    1.196440] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.213435] NET: Registered PF_INET protocol family
[    1.222870] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    1.239913] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    1.248851] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.259382] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    1.271780] TCP: Hash tables configured (established 65536 bind 65536)
[    1.280404] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[    1.288332] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.295805] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    1.304029] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.309722] NET: Registered PF_XDP protocol family
[    1.314544] PCI: CLS 0 bytes, default 64
[    1.318816] Trying to unpack rootfs image as initramfs...
[    1.319844] Initialise system trusted keyrings
[    1.328775] Key type blacklist registered
[    1.333576] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    1.348334] zbud: loaded
[    1.393595] NET: Registered PF_ALG protocol family
[    1.398432] xor: measuring software checksum speed
[    1.407793]    8regs           :  2180 MB/sec
[    1.416713]    8regs_prefetch  :  2178 MB/sec
[    1.425330]    32regs          :  2340 MB/sec
[    1.433944]    32regs_prefetch :  2329 MB/sec
[    1.438313] xor: using function: 32regs (2340 MB/sec)
[    1.443444] Key type asymmetric registered
[    1.447555] Asymmetric key parser 'x509' registered
[    1.452618] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.463606] io scheduler mq-deadline registered
[    1.468149] io scheduler kyber registered
[    1.472515] io scheduler bfq registered
[    1.476772] atomic64_test: passed
[    1.481834] simple-pm-bus soc: coherent device 0 dev->dma_coherent 0
[    1.490284] clk-starfive-jh7100 11800000.clock-controller: coherent device 0 dev->dma_coherent 0
[    1.502103] clk-starfive-jh7100-audio 10480000.clock-controller: coherent device 0 dev->dma_coherent 0
[    1.512529] dw_axi_dmac_platform 100b0000.dma-controller: coherent device 1 dev->dma_coherent 0
[    1.521804] dw_axi_dmac_platform 100b0000.dma-controller: DesignWare AXI DMA Controller, 4 channels
[    1.531041] dw_axi_dmac_platform 10500000.dma-controller: coherent device 0 dev->dma_coherent 0
[    1.540818] dw_axi_dmac_platform 10500000.dma-controller: DesignWare AXI DMA Controller, 16 channels
[    1.550249] L2CACHE: No. of Banks in the cache: 2
[    1.555002] L2CACHE: No. of ways per bank: 16
[    1.559357] L2CACHE: Sets per bank: 1024
[    1.563272] L2CACHE: Bytes per cache block: 64
[    1.567742] L2CACHE: Index of the largest way enabled: 15
[    1.573573] jh7100-reset 11840000.reset-controller: coherent device 0 dev->dma_coherent 0
[    1.582050] jh7100-reset-audio 10490000.reset-controller: coherent device 0 dev->dma_coherent 0
[    1.594408] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    1.609137] vic-rng 118d0000.trng: coherent device 0 dev->dma_coherent 0
[    1.616969] vic-rng 118d0000.trng: Initialized
[    1.621969] starfive-crtc 12000000.crtc: coherent device 0 dev->dma_coherent 0
[    1.630204] starfive-drm soc:display-subsystem: coherent device 1 dev->dma_coherent 0
[    1.641444] libphy: Fixed MDIO Bus: probed
[    1.646896] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.653524] ehci-pci: EHCI PCI platform driver
[    1.658095] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.664349] ohci-pci: OHCI PCI platform driver
[    1.668918] uhci_hcd: USB Universal Host Controller Interface driver
[    1.676192] usbcore: registered new interface driver usbserial_generic
[    1.682789] usbserial: USB Serial support registered for generic
[    1.689141] mousedev: PS/2 mouse device common for all mice
[    1.695366] i2c_dev: i2c /dev entries driver
[    1.700408] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    1.712960] device-mapper: uevent: version 1.0.3
[    1.718115] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    1.727418] EDAC DEVICE0: Giving out device to module Sifive ECC Manager controller sifive_edac.0: DEV sifive_edac.0 (INTERRUPT)
[    1.739474] sdhci: Secure Digital Host Controller Interface driver
[    1.745757] sdhci: Copyright(c) Pierre Ossman
[    1.750190] Synopsys Designware Multimedia Card Interface Driver
[    1.756964] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.763157] ledtrig-cpu: registered to indicate activity on CPUs
[    1.769543] hid: raw HID events driver (C) Jiri Kosina
[    1.775071] usbcore: registered new interface driver usbhid
[    1.780661] usbhid: USB HID core driver
[    1.786174] pwmdac-dit soc:pwmdac-transmitter: coherent device 0 dev->dma_coherent 0
[    1.794316] drop_monitor: Initializing network drop monitor service
[    1.800973] Initializing XFRM netlink socket
[    1.806090] NET: Registered PF_INET6 protocol family
[    2.664158] Freeing initrd memory: 30352K
[    2.695211] Segment Routing with IPv6
[    2.698904] RPL Segment Routing with IPv6
[    2.702988] In-situ OAM (IOAM) with IPv6
[    2.707056] mip6: Mobile IPv6
[    2.710028] NET: Registered PF_PACKET protocol family
[    2.716037] registered taskstats version 1
[    2.720309] Loading compiled-in X.509 certificates
[    2.728987] Loaded X.509 cert 'Build time autogenerated kernel key: f7b2dbbcf2f078e3d37e0cfe41af66a3e1943aa2'
[    2.739228] zswap: loaded using pool lzo/zbud
[    2.744630] Key type ._fscrypt registered
[    2.748639] Key type .fscrypt registered
[    2.752560] Key type fscrypt-provisioning registered
[    2.759369] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[    2.786906] Key type encrypted registered
[    2.790976] ima: No TPM chip found, activating TPM-bypass!
[    2.796525] Loading compiled-in module X.509 certificates
[    2.805118] Loaded X.509 cert 'Build time autogenerated kernel key: f7b2dbbcf2f078e3d37e0cfe41af66a3e1943aa2'
[    2.815075] ima: Allocated hash algorithm: sha256
[    2.819859] ima: No architecture policies found
[    2.824610] evm: Initialising EVM extended attributes:
[    2.829738] evm: security.selinux
[    2.833045] evm: security.SMACK64 (disabled)
[    2.837328] evm: security.SMACK64EXEC (disabled)
[    2.841934] evm: security.SMACK64TRANSMUTE (disabled)
[    2.846985] evm: security.SMACK64MMAP (disabled)
[    2.851589] evm: security.apparmor (disabled)
[    2.855943] evm: security.ima
[    2.858903] evm: security.capability
[    2.862468] evm: HMAC attrs: 0x1
[    2.894414] pinctrl-starfive 11910000.pinctrl: coherent device 0 dev->dma_coherent 0
[    2.903565] pwm-sifive-ptc 12490000.pwm: coherent device 0 dev->dma_coherent 0
[    2.911177] dw-apb-uart 11870000.serial: coherent device 0 dev->dma_coherent 0
[    2.918923] dw-apb-uart 11870000.serial: detected caps 00000000 should be 00000100
[    2.926508] 11870000.serial: ttyS1 at MMIO 0x11870000 (irq = 21, base_baud = 4640625) is a 16550
[    2.935851] dw-apb-uart 12440000.serial: coherent device 0 dev->dma_coherent 0
[    2.943379] 12440000.serial: ttyS0 at MMIO 0x12440000 (irq = 33, base_baud = 6250000) is a 16550A
[    2.952296] printk: console [ttyS0] enabled
[    2.960702] printk: bootconsole [uart0] disabled
[    2.970675] dw_spi_mmio 12410000.spi: coherent device 0 dev->dma_coherent 0
[    2.977825] dw_spi_mmio 12410000.spi: DMA init failed
[    2.983959] restart-gpio gpio-restart: coherent device 0 dev->dma_coherent 0
[    2.991467] dw_mmc 10000000.mmc: coherent device 0 dev->dma_coherent 0
[    2.998140] dw_mmc 10000000.mmc: IDMAC supports 32-bit address mode.
[    2.998377] dw_mmc 10010000.mmc: coherent device 0 dev->dma_coherent 0
[    3.004590] dw_mmc 10000000.mmc: Using internal DMA controller.
[    3.011195] sf-pwmdac 10440000.pwmdac: coherent device 0 dev->dma_coherent 0
[    3.016959] dw_mmc 10000000.mmc: Version ID is 290a
[    3.024132] Initialize pwmdac...success
[    3.028916] dw_mmc 10010000.mmc: IDMAC supports 32-bit address mode.
[    3.032890] i2c_designware 118b0000.i2c: coherent device 0 dev->dma_coherent 0
[    3.039052] dw_mmc 10010000.mmc: Using internal DMA controller.
[    3.047421] tps65086 0-005e: Device: TPS650861, OTP: A, Rev: 0
[    3.052143] dw_mmc 10010000.mmc: Version ID is 290a
[    3.058475] i2c 0-0070: Fixing up cyclic dependency with soc:display-encoder
[    3.062859] dw_mmc 10010000.mmc: DW MMC controller at irq 10,32 bit host data width,32 deep fifo
[    3.069906] dw_mmc 10000000.mmc: DW MMC controller at irq 8,32 bit host data width,32 deep fifo
[    3.087624] mmc_host mmc0: card is polling.
[    3.104528] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 400000Hz, actual 400000HZ div = 125)
[    3.190763] mmc_host mmc0: Bus speed (slot 0) = 100000000Hz (slot req 50000000Hz, actual 50000000HZ div = 1)
[    3.200647] mmc0: new high speed SDHC card at address e624
[    3.209055] mmcblk0: mmc0:e624 SD32G 29.7 GiB
[    3.220288]  mmcblk0: p2 p3 p4
[    3.230920] tda998x 0-0070: found TDA19988
[    3.238799] tda9950 0-0034: driver requires an interrupt
[    3.245544] i2c_designware 118c0000.i2c: coherent device 0 dev->dma_coherent 0
[    3.253308] i2c_designware 12450000.i2c: coherent device 0 dev->dma_coherent 0
[    3.261063] display-encoder soc:display-encoder: coherent device 0 dev->dma_coherent 0
[    3.269504] starfive-drm soc:display-subsystem: bound 12000000.crtc (ops starfive_crtc_component_ops)
[    3.278801] [drm] found bridge on endpoint
[    3.282913] starfive-drm soc:display-subsystem: bound soc:display-encoder (ops starfive_encoder_component_ops)
[    3.293760] [drm] Initialized starfive 1.0.0 20210519 for soc:display-subsystem on minor 0
[    3.339654] random: fast init done
[    3.397840] [drm] kvaddr = 0xffffffe04de00000
[    3.402238] [drm] dma_addr = 0xce000000, size = 2088960
[    3.439580] Console: switching to colour frame buffer device 170x48
[    3.459840] starfive-drm soc:display-subsystem: [drm] fb0: starfive frame buffer device
[    3.468992] dw_mmc 10010000.mmc: coherent device 0 dev->dma_coherent 0
[    3.479942] ALSA device list:
[    3.482986]   No soundcards found.
[    3.486670] dw_mmc 10010000.mmc: IDMAC supports 32-bit address mode.
[    3.493111] dw-apb-uart 12440000.serial: forbid DMA for kernel console
[    3.493242] dw_mmc 10010000.mmc: Using internal DMA controller.
[    3.505894] dw_mmc 10010000.mmc: Version ID is 290a
[    3.510895] dw_mmc 10010000.mmc: DW MMC controller at irq 10,32 bit host data width,32 deep fifo
[    3.520467] dw_mmc 10010000.mmc: coherent device 0 dev->dma_coherent 0
[    3.527329] dw_mmc 10010000.mmc: IDMAC supports 32-bit address mode.
[    3.533948] dw_mmc 10010000.mmc: Using internal DMA controller.
[    3.538415] Freeing unused kernel image (initmem) memory: 2568K
[    3.540028] dw_mmc 10010000.mmc: Version ID is 290a
[    3.551106] dw_mmc 10010000.mmc: DW MMC controller at irq 10,32 bit host data width,32 deep fifo
[    3.712945] Checked W+X mappings: passed, no W+X pages found
[    3.718862] rodata_test: all tests were successful
[    3.723868] Run /init as init process
[    3.795937] systemd[1]: System time before build time, advancing clock.
[    3.827007] systemd[1]: systemd v246.6-3.0.riscv64.fc33 running in system mode. (+PAM +AUDIT +SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD -SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    3.852954] systemd[1]: Detected architecture riscv64.
[    3.858310] systemd[1]: Running in initial RAM disk.
Welcome to Fedora 33 (Rawhide) dracut-050-26.git20200316.0.riscv64.fc33 (Initramfs)!
[    3.903795] systemd[1]: Set hostname to <fedora-starfive>.
[    4.437519] systemd[1]: /usr/lib/systemd/system/dracut-pre-udev.service:27: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.473112] systemd[1]: /usr/lib/systemd/system/dracut-pre-udev.service:28: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[    4.595903] systemd[1]: /usr/lib/systemd/system/dracut-pre-trigger.service:23: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.633091] systemd[1]: /usr/lib/systemd/system/dracut-pre-trigger.service:24: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[    4.675589] systemd[1]: /usr/lib/systemd/system/dracut-pre-pivot.service:30: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.713948] systemd[1]: /usr/lib/systemd/system/dracut-pre-pivot.service:31: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[    4.765452] systemd[1]: /usr/lib/systemd/system/dracut-pre-mount.service:22: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.805387] systemd[1]: /usr/lib/systemd/system/dracut-pre-mount.service:23: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[    4.849842] systemd[1]: /usr/lib/systemd/system/dracut-mount.service:22: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.890752] systemd[1]: /usr/lib/systemd/system/dracut-mount.service:23: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[    4.936061] systemd[1]: /usr/lib/systemd/system/dracut-initqueue.service:24: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    4.979004] systemd[1]: /usr/lib/systemd/system/dracut-initqueue.service:25: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[    5.026341] systemd[1]: /usr/lib/systemd/system/dracut-cmdline.service:26: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    5.071799] systemd[1]: /usr/lib/systemd/system/dracut-cmdline.service:27: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[    5.144435] systemd[1]: Queued start job for default target Initrd Default Target.
[    5.165438] random: systemd: uninitialized urandom read (16 bytes read)
[    5.185840] systemd[1]: Reached target Local File Systems.
[  OK  ] Reached target Local File Systems.
[    5.233780] random: systemd: uninitialized urandom read (16 bytes read)
[    5.252896] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    5.303701] random: systemd: uninitialized urandom read (16 bytes read)
[    5.322628] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    5.373741] systemd[1]: Reached target Timers.
[  OK  ] Reached target Timers.
[    5.424692] systemd[1]: Listening on Journal Audit Socket.
[  OK  ] Listening on Journal Audit Socket.
[    5.474520] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    5.524490] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    5.574526] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    5.624656] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    5.673748] systemd[1]: Reached target Sockets.
[  OK  ] Reached target Sockets.
[    5.732920] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st…odes for the current kernel...
[    5.791476] systemd[1]: Starting Load Kernel Modules...
[    5.850713] systemd[1]: Starting Setup Virtual Console...
[    5.918714] systemd[1]: Finished Create list of static device nodes for the current kernel.
[  OK  ] Finished Create list of st… nodes for the current kernel.
[    6.023789] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.154455] systemd[1]: Finished Create Static Device Nodes in /dev.
[  OK  ] Finished Create Static Device Nodes in /dev.
[    6.224256] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[  OK  ] Started Entropy Daemon based on the HAVEGE algorithm.
[    6.344709] systemd[1]: Starting Journal Service...
[    6.640453] systemd[1]: Finished Setup Virtual Console.
[  OK  ] Finished Setup Virtual Console.
[    6.703974] audit: type=1130 audit(1607040002.900:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-vconsole-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.704889] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[    6.805294] audit: type=1130 audit(1607040002.990:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
         Starting Create Volatile Files and Directories...
[    6.903606] audit: type=1334 audit(1607040003.090:4): prog-id=7 op=LOAD
         Starting Rule-based Manage…for Device Events and Files...
[    6.941758] audit: type=1334 audit(1607040003.090:5): prog-id=8 op=LOAD
[    6.993898] audit: type=1334 audit(1607040003.090:6): prog-id=9 op=LOAD
[  OK  ] Finished Create Volatile Files and Directories.
[    7.144719] audit: type=1130 audit(1607040003.340:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  OK  ] Started Rule-based Manager for Device Events and Files.
         Starting Coldplug All udev Devices...[    7.331974] audit: type=1130 audit(1607040003.520:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    7.558283] fuse: init (API version 7.34)
[  OK  ] Finished Load Kernel Modules.
[    7.655203] audit: type=1130 audit(1607040003.850:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
         Starting Apply Kernel Variables...
[  OK  ] Finished Apply Kernel Variables.
[    7.913907] audit: type=1130 audit(1607040004.110:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  OK  ] Finished Coldplug All udev Devices.
[  OK  ] Reached target System Initializatio[    8.085571] audit: type=1130 audit(1607040004.280:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
n.
[  OK  ] Found device /dev/disk/by-…8-2f22-441a-ba45-4f7185baf23f.
[    9.207304] pwrseq_simple wifi-pwrseq: coherent device 0 dev->dma_coherent 0
[    9.218686] dw_mmc 10010000.mmc: coherent device 0 dev->dma_coherent 0
[    9.228608] dw_mmc 10010000.mmc: IDMAC supports 32-bit address mode.
[    9.239548] dw_mmc 10010000.mmc: Using internal DMA controller.
[    9.245683] dw_mmc 10010000.mmc: Version ID is 290a
[  OK  ] Reached target Initrd Root Device    9.255959] dw_mmc 10010000.mmc: DW MMC controller at irq 10,32 bit host data width,32 deep fifo
0m.
         Starting File System Check…2f22-441a-ba45-4f[    9.274716] dw_mmc 10010000.mmc: allocated mmc-pwrseq
7185baf23f...
[    9.282387] mmc_host mmc1: card is non-removable.
[    9.309682] random: crng init done
[    9.313223] random: 7 urandom warning(s) missed due to ratelimiting
[    9.313487] mmc_host mmc1: Bus speed (slot 0) = 123750000Hz (slot req 400000Hz, actual 399193HZ div = 155)
[    9.460018] mmc_host mmc1: Bus speed (slot 0) = 123750000Hz (slot req 50000000Hz, actual 30937500HZ div = 2)
[    9.479794] mmc1: new high speed SDIO card at address 0001
[  OK  ] Finished File System Check…8-2f22-441a-ba45-4f7185baf23f.
         Mounting /sysroot...
[    9.955438] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[  OK  ] Mounted /sysroot.
[  OK  ] Reached target Initrd Root File System.
         Starting Reload Configuration from the Real Root...
[  OK  ] Finished Reload Configuration from the Real Root.
[  OK  ] Reached target Initrd File Systems.
[  OK  ] Reached target Initrd Default Target.
         Starting Cleaning Up and Shutting Down Daemons...
[  OK  ] Stopped target Initrd Default Target.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Initrd Root Device.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped target Remote File Systems.
[  OK  ] Stopped target Remote File Systems (Pre).
[  OK  ] Stopped target Slices.
[  OK  ] Stopped target Sockets.
[  OK  ] Stopped target System Initialization.
[  OK  ] Stopped target Swap.
[  OK  ] Stopped target Timers.
         Starting Tell haveged about new root...
         Starting Plymouth switch root service...
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
[  OK  ] Stopped Coldplug All udev Devices.
         Stopping Rule-based Manage…for Device Events and Files...
[  OK  ] Finished Tell haveged about new root.
[  OK  ] Finished Cleaning Up and Shutting Down Daemons.
[  OK  ] Stopped Rule-based Manager for Device Events and Files.
[  OK  ] Closed udev Control Socket.
[  OK  ] Closed udev Kernel Socket.
         Starting Cleanup udev Database...
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Stopped Create list of sta… nodes for the current kernel.
[  OK  ] Finished Plymouth switch root service.
[  OK  ] Finished Cleanup udev Database.[   11.735247] kauditd_printk_skb: 31 callbacks suppressed
[   11.735265] audit: type=1130 audit(1607040007.930:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=initrd-udevadm-cleanup-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.780418] audit: type=1131 audit(1607040007.950:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=initrd-udevadm-cleanup-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  OK  ] Reached target Switch Root.
         Starting Switch Root...
[   11.910900] audit: type=1334 audit(1607040008.100:45): prog-id=0 op=UNLOAD
[   11.923779] audit: type=1334 audit(1607040008.120:46): prog-id=0 op=UNLOAD
[   11.935182] audit: type=1334 audit(1607040008.120:47): prog-id=0 op=UNLOAD
[   11.946050] audit: type=1334 audit(1607040008.120:48): prog-id=0 op=UNLOAD
[   11.962980] audit: type=1334 audit(1607040008.160:49): prog-id=0 op=UNLOAD
[   11.974080] audit: type=1334 audit(1607040008.160:50): prog-id=0 op=UNLOAD
[   13.390121] systemd[1]: systemd v246.6-3.0.riscv64.fc33 running in system mode. (+PAM +AUDIT +SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD -SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[   13.426507] systemd[1]: Detected architecture riscv64.
Welcome to Fedora 33 (Rawhide)!
[   13.455745] systemd[1]: Set hostname to <fedora-starfive>.
[   13.493897] audit: type=1334 audit(1607040009.690:51): prog-id=17 op=LOAD
[   13.506661] audit: type=1334 audit(1607040009.710:52): prog-id=0 op=UNLOAD
[   14.161319] zram_generator::generator[274]: Creating dev-zram0.swap for /dev/zram0 (3587MB)
[   14.442956] zram: Added device: zram0
[   14.841178] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-pre-udev.service:27: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   14.877446] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-pre-udev.service:28: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[   14.920575] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-pre-trigger.service:23: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   14.958968] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-pre-trigger.service:24: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[   15.007744] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-pre-pivot.service:30: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   15.047806] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-pre-pivot.service:31: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[   15.104145] systemd[1]: /usr/lib/systemd/system/gssproxy.service:13: PIDFile= references a path below legacy directory /var/run/, updating /var/run/gssproxy.pid → /run/gssproxy.pid; please update the unit file accordingly.
[   15.220887] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-pre-mount.service:22: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   15.263902] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-pre-mount.service:23: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[   15.315564] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-mount.service:22: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   15.360066] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-mount.service:23: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[   15.411025] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-initqueue.service:24: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   15.457260] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-initqueue.service:25: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[   15.509184] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-cmdline.service:26: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   15.555397] systemd[1]: /usr/lib/dracut/modules.d/98dracut-systemd/dracut-cmdline.service:27: Standard output type syslog+console is obsolete, automatically updating to journal+console. Please update your unit file, and consider removing the setting altogether.
[   15.803697] systemd[1]: /usr/lib/systemd/system/ip6tables.service:14: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   15.850227] systemd[1]: /usr/lib/systemd/system/ip6tables.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   15.901134] systemd[1]: /usr/lib/systemd/system/iptables.service:14: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   15.949988] systemd[1]: /usr/lib/systemd/system/iptables.service:15: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[   16.610615] systemd[1]: initrd-switch-root.service: Succeeded.
[   16.635748] systemd[1]: Stopped Switch Root.
[  OK  ] Stopped Switch Root.
[   16.661414] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
[   16.663557] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[   16.719081] systemd[1]: Created slice system-modprobe.slice.
[  OK  ] Created slice system-modprobe.slice.
[   16.751721] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[   16.784592] systemd[1]: Created slice system-sshd\x2dkeygen.slice.
[  OK  ] Created slice system-sshd\x2dkeygen.slice.
[   16.816928] systemd[1]: Created slice system-swap\x2dcreate.slice.
[  OK  ] Created slice system-swap\x2dcreate.slice.
[   16.849223] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[   16.880025] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
[   16.880603] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[   16.936079] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[  OK  ] Set up automount Arbitrary…s File System Automount Point.
[   16.967072] systemd[1]: Reached target Local Encrypted Volumes.
[  OK  ] Reached target Local Encrypted Volumes.
[   16.995551] systemd[1]: Stopped target Switch Root.
[  OK  ] Stopped target Switch Root.
[   17.021933] systemd[1]: Stopped target Initrd File Systems.
[  OK  ] Stopped target Initrd File Systems.
[   17.047047] systemd[1]: Stopped target Initrd Root File System.
[  OK  ] Stopped target Initrd Root File System.
[   17.071373] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[   17.094411] systemd[1]: Reached target Slices.
[   17.117184] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[  OK  ] Listening on Device-mapper event daemon FIFOs.
[   17.141259] systemd[1]: Listening on LVM2 poll daemon socket.
[  OK  ] Listening on LVM2 poll daemon socket.
[   17.174235] systemd[1]: Listening on multipathd control socket.
[  OK  ] Listening on multipathd control socket.
[   17.197725] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[   17.213671] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[   17.237666] systemd[1]: Listening on udev Control Socket.
[   17.253796] systemd[1]: Listening on udev Kernel Socket.
[   17.271269] systemd[1]: Listening on User Database Manager Socket.
[  OK  ] Listening on User Database Manager Socket.
[   17.296649] systemd[1]: Mounting Huge Pages File System...
[   17.318815] systemd[1]: Mounting POSIX Message Queue File System...
[   17.341457] systemd[1]: Mounting Kernel Debug File System...
[   17.373840] systemd[1]: Mounting Kernel Trace File System...
[   17.386955] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   17.394465] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   17.434924] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
         Starting Monitoring of LVM…meventd or progress polling...
[   17.453105] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[   17.460126] systemd[1]: Starting Preprocess NFS configuration convertion...
[   17.512463] systemd[1]: plymouth-switch-root.service: Succeeded.
[   17.527691] systemd[1]: Stopped Plymouth switch root service.
[  OK  ] Stopped Plymouth switch root service.
[   17.542228] kauditd_printk_skb: 10 callbacks suppressed
[   17.542243] audit: type=1131 audit(1607040013.740:63): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-switch-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.552883] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   17.611786] systemd[1]: systemd-fsck-root.service: Succeeded.
[   17.628916] systemd[1]: Stopped File System Check on Root Device.
[  OK  ] Stopped File System Check on Root Device.
[   17.642664] audit: type=1131 audit(1607040013.840:64): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck-root comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.643211] systemd[1]: Stopped Journal Service.
[  OK  ] Stopped Journal Service.
[   17.694110] audit: type=1130 audit(1607040013.880:65): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.694316] audit: type=1131 audit(1607040013.890:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.700429] audit: type=1334 audit(1607040013.890:67): prog-id=23 op=LOAD
[   17.792897] systemd[1]: Starting Journal Service...
[   17.808441] audit: type=1334 audit(1607040013.980:68): prog-id=0 op=UNLOAD
[   17.827207] audit: type=1334 audit(1607040013.980:69): prog-id=0 op=UNLOAD
[   17.827237] audit: type=1334 audit(1607040013.980:70): prog-id=24 op=LOAD
[   17.827251] audit: type=1334 audit(1607040013.980:71): prog-id=25 op=LOAD
[   17.845595] systemd[1]: Starting Load Kernel Modules...
[   17.914147] systemd[1]: Starting Remount Root and Kernel File Systems...
[   17.935237] audit: type=1305 audit(1607040014.130:72): op=set audit_enabled=1 old=1 auid=4294967295 ses=4294967295 res=1
[   18.010488] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[   18.028127] systemd[1]: Starting Coldplug All udev Devices...
[   18.046078] EXT4-fs (mmcblk0p4): re-mounted. Opts: (null). Quota mode: none.
[   18.090189] systemd[1]: sysroot.mount: Succeeded.
[   18.119123] systemd[1]: Started Journal Service.
[  OK  ] Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Trace File System.
[  OK  ] Finished Preprocess NFS configuration convertion.
[  OK  ] Finished Remount Root and Kernel File Systems.
         Mounting FUSE Control File System...
         Starting Flush Journal to Persistent Storage...
         Starting Load/Save Random Seed...
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Finished Load/Save Random Seed.
         Starting Wait for udev To …plete Device Initialization...
[  OK  ] Finished Flush Journal to Persistent Storage.
[   20.563004] leds-gpio leds: coherent device 0 dev->dma_coherent 0
[  OK  ] Finished Monitoring of LVM… dmeventd or progress polling.
[   21.399918] stmmaceth 10020000.ethernet: coherent device 0 dev->dma_coherent 0
[  OK  ] Found device /dev/zram0.
         Starting Create swap on /dev/zram0...
[   21.723388] zram0: detected capacity change from 0 to 7346176
[   21.773584] stmmaceth 10020000.ethernet: IRQ eth_lpi not found
[   21.986557] starfive-si5-wdt 12480000.watchdog: coherent device 0 dev->dma_coherent 0
[   22.002751] starfive-si5-wdt 12480000.watchdog: Heartbeat: timeout=15, count=750000000 (2cb41780)
[  OK  ] Finished Create swap on /dev/zram0.
         Activating swap Compressed swap on /dev/zram0...
[   22.067448] spdif-dir soc:spdif-receiver: coherent device 0 dev->dma_coherent 0
[   22.096643] Adding 3673084k swap on /dev/zram0.  Priority:100 extents:1 across:3673084k SSFS
[  OK  ] Activated swap Compressed swap on /dev/zram0.
[   22.121960] stmmaceth 10020000.ethernet: force_sf_dma_mode is ignored if force_thresh_dma_mode is set.
         Mounting Temporary Directory (/tmp)...
[  OK  ] Mounted Temporary Directory (/tmp).
[   22.231859] sfctemp 124a0000.tmon: coherent device 0 dev->dma_coherent 0
[   22.309413] stmmaceth 10020000.ethernet: User ID: 0x59, Synopsys ID: 0x37
[   22.393839] dmic-codec soc:dmic: coherent device 0 dev->dma_coherent 0
[   22.568209] stmmaceth 10020000.ethernet: 	DWMAC1000
[   22.579131] stmmaceth 10020000.ethernet: DMA HW capability register supported
[   22.592187] stmmaceth 10020000.ethernet: RX Checksum Offload Engine supported
[   22.604078] stmmaceth 10020000.ethernet: COE Type 2
[   22.613174] stmmaceth 10020000.ethernet: Wake-Up On Lan supported
[   22.624958] stmmaceth 10020000.ethernet: Enhanced/Alternate descriptors
[   22.636372] stmmaceth 10020000.ethernet: Enabled extended descriptors
[   22.647393] stmmaceth 10020000.ethernet: Chain mode enabled
[   22.658797] stmmaceth 10020000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[   22.671320] stmmaceth 10020000.ethernet: device MAC address 6c:cf:39:00:00:96
[   22.704589] spdif-dit soc:spdif-transmitter: coherent device 0 dev->dma_coherent 0
[   22.822848] at24 0-0050: supply vcc not found, using dummy regulator
[   22.851132] cdns-usb3 104c0000.usb: coherent device 0 dev->dma_coherent 0
[   22.900632] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   22.957599] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[   23.014745] at24 0-0050: 512 byte 24c04 EEPROM, writable, 16 bytes/write
[   23.135107] xhci-hcd xhci-hcd.3.auto: hcc params 0x200073c8 hci version 0x100 quirks 0x0000002000018010
[   23.279483] xhci-hcd xhci-hcd.3.auto: irq 17, io mem 0x104d0000
[   23.304672] libphy: stmmac: probed
[   23.325462] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[   23.343507] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[   23.343531] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   23.371934] usb usb1: Product: xHCI Host Controller
[   23.382627] usb usb1: Manufacturer: Linux 5.15.10+ xhci-hcd
[   23.393295] usb usb1: SerialNumber: xhci-hcd.3.auto
[   23.407516] mdio_bus stmmac-0:03: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:03, irq=POLL)
[   23.480536] asoc-simple-card soc:snd-card: coherent device 0 dev->dma_coherent 0
[   23.700864] hub 1-0:1.0: USB hub found
[   23.723090] hub 1-0:1.0: 1 port detected
[   23.812589] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   23.888512] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[   23.943618] usb usb1-port1: couldn't allocate usb_device
[   23.953503] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   23.983568] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   24.033703] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[   24.048736] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   24.063995] usb usb2: Product: xHCI Host Controller
[   24.075505] usb usb2: Manufacturer: Linux 5.15.10+ xhci-hcd
[   24.089014] usb usb2: SerialNumber: xhci-hcd.3.auto
[   24.265444] hub 2-0:1.0: USB hub found
[   24.277439] hub 2-0:1.0: 1 port detected
[   24.653651] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[   24.696584] usb 2-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91
[   24.713450] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   24.726886] usb 2-1: Product: USB3.2 Hub
[   24.735794] usb 2-1: Manufacturer: GenesysLogic
[   24.752584] hub 2-1:1.0: USB hub found
[   24.763221] hub 2-1:1.0: 4 ports detected
[*     ] A start job is running for Wait for…ice Initialization (2s / 2min 55s)
[**    ] A start job is running for Wait for…ice Initialization (2s / 2min 55s)
[***   ] A start job is running for Wait for…ice Initialization (4s / 2min 55s)
[ ***  ] A start job is running for Wait for…ice Initialization (5s / 2min 55s)
[   28.835733] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   29.007553] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   ***] A start job is running for Wait for…ice Initialization (6s / 2min 55s)
[    **] A start job is running for Wait for…ice Initialization (6s / 2min 55s)
[     *] A start job is running for Wait for…ice Initialization (7s / 2min 55s)
[    **] A start job is running for Wait for…ice Initialization (7s / 2min 55s)
[   ***] A start job is running for Wait for…ice Initialization (8s / 2min 55s)
[   32.432287] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   32.448414] usbcore: registered new interface driver brcmfmac
[  *** ] A start job is running for Wait for…ice Initialization (8s / 2min 55s)
[   32.570681] kauditd_printk_skb: 19 callbacks suppressed
[   32.570702] audit: type=1130 audit(1607040028.760:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-settle comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  OK  ] Finished Wait for udev To Complete Device Initialization.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /boot...
[   32.672939] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   32.689515] EXT4-fs (mmcblk0p3): recovery complete
[   32.701357] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   32.717780] ext4 filesystem being mounted at /boot supports timestamps until 2038 (0x7fffffff)
[   32.740769] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Feb 16 2020 22:39:24 version 7.45.98.97 (r724416 CY) FWID 01-bf41ed64
[  OK  ] Mounted /boot.
         Mounting /boot/efi...
         Starting Load/Save RF Kill Switch Status...
[  OK  ] Started Load/Save RF Kill Switch Status.
[   33.106269] audit: type=1130 audit(1607040029.300:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.612482] FAT-fs (mmcblk0p2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Mounted /boot/efi.
         Starting Restore /run/initramfs on shutdown...
         Starting Tell Plymouth To Write Out Runtime Data...
[  OK  ] Finished Restore /run/initramfs on shutdown.
[   33.723573] audit: type=1130 audit(1607040029.910:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dracut-shutdown comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  OK  ] Finished Tell Plymouth To Write Out Runtime Data.
[   33.792286] audit: type=1130 audit(1607040029.980:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=plymouth-read-write comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   33.975508] audit: type=1130 audit(1607040030.170:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
         Mounting RPC Pipe File System...
         Starting Security Auditing Service...
[   34.176661] audit: type=1305 audit(1607040030.370:95): op=set audit_enabled=1 old=1 auid=4294967295 ses=4294967295 res=1
[   34.213491] audit: type=1300 audit(1607040030.370:95): arch=c00000f3 syscall=206 success=yes exit=60 a0=3 a1=3fea988ab0 a2=3c a3=0 items=0 ppid=374 pid=375 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="auditd" exe="/usr/sbin/auditd" key=(null)
[   34.256567] audit: type=1327 audit(1607040030.370:95): proctitle="/sbin/auditd"
[   34.273288] audit: type=1305 audit(1607040030.370:96): op=set audit_pid=375 old=0 auid=4294967295 ses=4294967295 res=1
[   34.299455] audit: type=1300 audit(1607040030.370:96): arch=c00000f3 syscall=206 success=yes exit=60 a0=3 a1=3fea986750 a2=3c a3=0 items=0 ppid=374 pid=375 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="auditd" exe="/usr/sbin/auditd" key=(null)
[  OK  ] Started Security Auditing Service.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Finished Update UTMP about System Boot/Shutdown.
[  OK  ] Reached target System Initialization.
[  OK  ] Started dnf makecache --timer.
[  OK  ] Started Discard unused blocks once a week.
[  OK  ] Started Run system activit…ounting tool every 10 minutes.
[  OK  ] Started Generate summary o…esterday's process accounting.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Started daily update of the root trust anchor for DNSSEC.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on SSSD Kerberos…ache Manager responder socket.
         Starting D-Bus System Message Bus...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Reached target Basic System.
         Starting Modem Manager...
[  OK  ] Started Manage Sound Card State (restore and store).
[  OK  ] Reached target Sound Card.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Builds and instal…kernel modules through DKMS...
         Starting firewalld - dynamic firewall daemon...
         Starting GSSAPI Proxy Daemon...
         Starting LSB: Init script for live image....
         Starting RealtimeKit Scheduling Policy Service...
[  OK  ] Reached target sshd-keygen.target.
         Starting System Security Services Daemon...
         Starting Resets System Activity Logs...
         Starting Home Area Manager...
         Starting Disk Manager...
         Starting Daemon for power management...
[  OK  ] Started RealtimeKit Scheduling Policy Service.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started GSSAPI Proxy Daemon.
[  OK  ] Finished Resets System Activity Logs.
[  OK  ] Started Home Area Manager.
[  OK  ] Started Modem Manager.
         Starting Authorization Manager...
[ ***  ] (4 of 8) A start job is running for…ules through DKMS (21s / no limit)
[***   ] (5 of 8) A start job is running for…horization Manager (2s / 1min 30s)
[**    ] (5 of 8) A start job is running for…horization Manager (2s / 1min 30s)
[  OK  ] Finished Builds and instal…w kernel modules through DKMS.
[  OK  ] Started LSB: Init script for live image..
         Starting NTP client/server...
[  OK  ] Started NTP client/server.
[  OK  ] Started Authorization Manager.
[   40.693267] RPC: Registered named UNIX socket transport module.
[   40.704359] RPC: Registered udp transport module.
[   40.712732] RPC: Registered tcp transport module.
[   40.720897] RPC: Registered tcp NFSv4.1 backchannel transport module.
[  OK  ] Mounted RPC Pipe File System.
[  OK  ] Reached target rpc_pipefs.target.
[  OK  ] Reached target NFS client services.
[  OK  ] Reached target Remote File Systems (Pre).
[  OK  ] Reached target Remote File Systems.
[  OK  ] Started System Security Services Daemon.
[  OK  ] Reached target User and Group Name Lookups.
         Starting Accounts Service...
         Starting User Login Management...
[  OK  ] Started Accounts Service.
[  OK  ] Started User Login Management.
[  OK  ] Started Disk Manager.
[  OK  ] Started Daemon for power management.
[  OK  ] Started firewalld - dynamic firewall daemon.
[  OK  ] Reached target Network (Pre).
         Starting Network Manager...
[  OK  ] Started Network Manager.
[  OK  ] Reached target Network.
         Starting Network Manager Wait Online...
         Starting /etc/rc.d/rc.local Compatibility...
         Starting OpenSSH server daemon...
         Starting Permit User Sessions...
[  OK  ] Started /etc/rc.d/rc.local Compatibility.
         Starting Hostname Service...
[  OK  ] Finished Permit User Sessions.
         Starting Light Display Manager...
         Starting Hold until boot process finishes up...
[  OK  ] Started OpenSSH server daemon.
[   45.565037] stmmaceth 10020000.ethernet eth0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL)
[   45.583236] stmmaceth 10020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   45.601261] dwmac1000: Master AXI performs fixed burst length
[   45.611140] stmmaceth 10020000.ethernet eth0: No Safety Features support found
[   45.622753] stmmaceth 10020000.ethernet eth0: No MAC Management Counters available
[   45.638486] stmmaceth 10020000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[   45.672757] stmmaceth 10020000.ethernet eth0: registered PTP clock
[   45.701535] stmmaceth 10020000.ethernet eth0: configuring for phy/rgmii-txid link mode
[   45.723042] [drm] kvaddr = 0xffffffe04e088000
[   45.727506] [drm] dma_addr = 0xce288000, size = 16384
[   49.464477] [drm] kvaddr = 0xffffffe04e100000
[   49.468866] [drm] dma_addr = 0xce300000, size = 4177920
[   49.499311] [drm] kvaddr = 0xffffffe04e088000
[   49.503763] [drm] dma_addr = 0xce288000, size = 16384
Is this your complete boot log ? Did you see the welcome message likes below?
Welcome to the Fedora/RISC-V disk image
https://fedoraproject.org/wiki/Architectures/RISC-V
Build date: Tue Nov 16 23:07:46 UTC 2021
Kernel 5.15.10+ on an riscv64 (ttyS0)
The root password is 'starfive'.
root password logins are disabled in SSH starting Fedora 31.
User 'riscv' with password 'starfive' in 'wheel' group is provided.
To install new packages use 'dnf install ...'
To upgrade disk image use 'dnf upgrade --best'
If DNS isn’t working, try editing ‘/etc/yum.repos.d/fedora-riscv.repo’.
For updates and latest information read:
Fedora/RISC-V
Koji:               http://fedora.riscv.rocks/koji/
SCM:                http://fedora.riscv.rocks:3000/
Distribution rep.:  http://fedora.riscv.rocks/repos-dist/
Koji internal rep.: http://fedora.riscv.rocks/repos/
fedora-starfive login:
Sorry,
Fedora/RISC-V
fedora-starfive login: [   63.370624] Bluetooth: Core ver 2.22
[   63.393444] NET: Registered PF_BLUETOOTH protocol family
[   63.398768] Bluetooth: HCI device and connection manager initialized
[   63.422540] Bluetooth: HCI socket layer initialized
[   63.427463] Bluetooth: L2CAP socket layer initialized
[   63.452504] Bluetooth: SCO socket layer initialized
[   65.503691] Bluetooth: HCI UART driver ver 2.3
[   65.508163] Bluetooth: HCI UART protocol H4 registered
[   65.513325] Bluetooth: HCI UART protocol BCSP registered
[   65.518784] Bluetooth: HCI UART protocol LL registered
[   65.523947] Bluetooth: HCI UART protocol ATH3K registered
[   65.529419] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   65.535949] Bluetooth: HCI UART protocol Intel registered
[   65.541516] Bluetooth: HCI UART protocol Broadcom registered
[   65.552068] Bluetooth: HCI UART protocol QCA registered
[   65.557327] Bluetooth: HCI UART protocol AG6XX registered
[   65.562804] Bluetooth: HCI UART protocol Marvell registered
[   66.303527] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   66.308861] Bluetooth: BNEP filters: protocol multicast
[   66.314171] Bluetooth: BNEP socket layer initialized
It looks normal ,have you try another HDMI monitor?
Hi:
During you power on this board, Is there any other image display on the HDMI screen?
When connected to DELL U2421E, it was displayed normally.
Thanks.
