When the VisionFive V1 is left idle and used only over ssh, the monitor switches off. It does not switch back on again when the USB keyboard is activated by a keypress, nor if the USB mouse is moved. Is there a trick to getting the monitor to show the desktop again? Currently I have to restart the VisionFive just to get the desktop visible again.
Are you sure that the usb keyboard and mouse are responsive before standby?
Hi. Indeed shutdown -r now did not restore any USB input capabilities. A reset using the reset button did not either. Only removing the power supply completely and rebooting from a power down state made the USB keyboard and mouse work again.
I have tested the wake-up problem many times in the past two days, and found that I can wake up with the keyboard and mouse every time. Please confirm the following points:
- Before the system standby, the USB keyboard or mouse can be responded;
- Please use a 5V/3A type-c adapter.
Thanks. Will report using https://www.amazon.de/-/en/dp/B07WKD71DX?psc=1&smid=AV5KLZDJ9GHAI&ref_=chk_typ_quicklook_titleToDp
OK so far with proper power supply I have not noticed any problem.
