I recently bought Visionfive board along with the etched SD card (with Fedora). When I connect the board to HDMI, nothing shows up. The display shows the error “the current input timing is not supported by the monitor display. Please change your input timing to 1920x1820, 60Hz or any other monitor listed timing as per monitor specifications”
What’s the version of fedora?
Have you connected the board to HDMI before you power up?
If possible, would you please take a picture of the prompt on the dispaly? 1920x1820?
I am using 2021-December-26 release from GitHub - starfive-tech/Fedora_on_StarFive
Yes I am connecting the board to HDMI before power up.
the snapshot of the display is attached.
the yellow line says 1920x1080, 60 Hz
thanks.
do you have the whole booting log from serial port? please attached if possible
Processing: boot log visionfive.txt…
yes I have the file i have tried to attach it here
Sorry, I cannot see your attachment. would you please try it again?
Hi Michael, my board has started working and giving a display. Thanks for your time.
