Fedora Image:
2021-December-26: Fedora-riscv64-jh7100-developer-xfce-Rawhide-20211226-214100.n.0-sda.raw.zst
sha256sum:
sha256sum: 94c73c967e12c80192d7bf25147badd9f0ee1738dc9800d1c502f376df5d5e2f - Changes:
- Using the LTS kernel 5.15 with tag linux-5.15.10;
- Using the latest 5.16-rc6+ kernel - starfive-tech/linux;
- Support UVC camera using camorama application;
- Support both of Starlight and VisionFive board;
- Support ASLA driver and aplay audio files through the mini-jack on the board (only support 16kHz samplerate for now);
- Fix kernel oops/crash issue by brcmfmac driver - jira CS-18 and CS-16;
- Fix the issue of not being able to switch some display resolutions - jira CS-19;
- Issues:
- Kernel panic when system booting with USB drive in rare case;
- Real hot swap is not supported in case of HDMI is not connected before power-on;
- Failed to open the Bilibili web page by firefox;
sha256sum:
Linux Kernel:
- Linux kernel branch: visionfive
- Changes:
- Added the audio drivers - PWMDAC module;
- Rebased the dma patches, so they build on the support for more than 8 channels that is upstream in 5.16
- Fixed the gpio-restart priority
- Changes:
- LTS branch: visionfive-5.15.y-devel with tag Linux 5.15.10
- Changes:
- Add the audio drivers - PWMDAC module;
- Enable CONFIG_SOC_SIFIVE for fixing Oops/panic problem;
- Expand CMA size to 32M by CONFIG_CMA_SIZE_MBYTES=32;
- Remove clk configuration for lcdc to fix the issue of not being able to switch some resolutions;
- Changes:
u-boot / OpenSBI
- OpenSBI (branch: master): with released tag OpenSBI-v1.0-48f91ee
- u-boot (branch: JH7100_upstream): with released tag u-boot-2022.01-rc4-g0c08d33
- Please download the release binary fw_payload_jh7100 based on Starlight/VisionFive board
- Changes:
- update to 2022.01-rc4 (u-boot);
- Add ID_EEPROM (
maccommand) support for visionfive V1;
- Changes:
