Network failing to load
18:52 rneese: Ethernet MAC address: 6c:cf:39:00:05:21
18:52 rneese: --------EEPROM INFO--------
18:52 rneese: In: serial@12440000
18:52 rneese: Out: serial@12440000
18:52 rneese: Err: serial@12440000
18:52 rneese: Net: Could not get PHY for dwmac.10020000: addr 3
18:52 rneese: dwmac.10020000
it seems there is either hardware failure or a firmware bug
Is this problem bound to occur when you start it more than once?
Could you please show your full log?
bootloader version:211102-0b86f96
ddr 0x00000000, 1M test
ddr 0x00100000, 2M test
DDR clk 2133M,Version: 211102-d086aee
0 crc flash: c08c9d08, crc ddr: c08c9d08
crc check PASSED
bootloader.
OpenSBI v1.0
/ __ \ / | _ _ |
__ ___ _ __ | (
_
/| ./ _|| ||/|____/|
Platform Name : StarFive VisionFive V1
Platform Features : medeleg
Platform HART Count : 2
Platform Timer Device : aclint-mtimer @ 6250000Hz
Platform HSM Device : —
Platform Reboot Device : —
Platform Shutdown Device : —
Firmware Base : 0x80000000
Firmware Size : 296 KB
Runtime SBI Version : 0.3
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 HARTs : 0*,1*
Domain0 Region01 : 0x0000000080000000-0x000000008007ffff ()
Domain0 Next Address : 0x0000000080200000
Domain0 Next Arg1 : 0x0000000082200000
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART ISA : rv64imafdcsux
Boot HART Features : scounteren,mcounteren
Boot HART PMP Count : 16
Boot HART PMP Address Bits: 36
Boot HART MHPM Count : 2
U-Boot 2022.01-rc4-VisionFive-g0c08d335c5 (Dec 30 2021 - 20:05:04 +0800)StarFive
CPU: rv64imafdc
Model: StarFive VisionFive V1
DRAM: 8 GiB
MMC: mmc@10000000: 0, mmc@10010000: 1
Loading Environment from SPIFlash… cadence_spi spi@11860000: Can’t get reset: -524
OK
StarFive EEPROM format v1
Product full SN: VF7100A1-2209-D008E000-00000522
data version: 0x1
PCB revision: 0x1
In: serial@12440000
dwmac.10020000
MMC CD is 0x1, force to True.
switch to partitions #0, OK
mmc0 is current device
Can’t set block device
302 bytes read in 32 ms (8.8 KiB/s)
Importing environment from mmc0 …
** Invalid partition 2 **
Couldn’t find partition mmc 0:2
** Invalid partition 3 **
Couldn’t find partition mmc 0:3
Run uenvcmd …
** Bad device specification mmc -bootable **
updated bl still no go.
0 crc flash: 7816e82f, crc ddr: 7816e82f
crc check PASSED
bootloader.
OpenSBI v1.0
/ __ \ / | _ _ |
__ ___ _ __ | (
_
fdt_reset_driver_init: gpio-restart init failed, -1001
Firmware Size : 300 KB
Domain0 Name : root
Boot HART ID : 1
U-Boot 2022.04-rc2-VisionFive (Mar 07 2022 - 21:12:22 +0800)StarFive
CPU: rv64imafdc
DRAM: 8 GiB
Core: 13 devices, 9 uclasses, devicetree: separate
OK
data version: 0x1
PCB revision: 0x1
In: serial@12440000
dwmac.10020000
seeing 2 issues
dwmac.10020000
If you have compiled the software yourself please try to restore the factory Settings.
If it doesn’t work, it’s probably a hardware problem.
how to factory reset. and no the firmware is right from the starfive site .
maybe this can help you
VisionFive Single Board Computer Quick Start Guide (rvspace.org)
(C)SiFive
load 0x18000000
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC, Type ? or help to get CMD info
E#VƊUŊUE
Warning : Error command, Type ? or help to get CMD info
i can not get the recover bl to load
GitHub - xypron/JH71xx-tools: Bootloader recovery and updater tool for StarFive JH71x0 SoCs. this tool worked at reflashing the unit
so even after reflashing the board U-Boot 2022.04-rc2-VisionFive (Mar 07 2022 - 21:12:22 +0800)StarFive
CPU: rv64imafdc
DRAM: 8 GiB
OK
data version: 0x1
PCB revision: 0x1
In: serial@12440000
dwmac.10020000
./jh7100-recover -D /dev/cu.usbserial-22340 -r jh7100_recovery_boot.bin -b bootloader-JH7100-211102.bin.out -d ddrinit-2133-211102.bin.out
Waiting for bootloader mode on /dev/cu.usbserial-22340…
(C)SiFive
Bootloader mode active
Uploading recovery binary…
load 0x18000000
Waiting for XMODEM request[C]…
Sending jh7100_recovery_boot.bin
[########################################] 100% 24081/24081 Bytes
do 0x18000000
----------Enter recovery mode----------
Updating bootloader…
Load file ok
do 0x18000000?
VIC second boot, version:210714-d9d6147 debug
***************JH7100 recovery boot ***************
0:updata bootloader
1:updata ddr init
Select the function to test
0
: 0
select 0
send a file by xmodem
Sending bootloader-JH7100-211102.bin.out
[########################################] 100% 9456/9456 Bytes
Awaiting confirmation…
idcode:0x1860C8
updata flash ok
done.
Updating ddrinit…
updata success
0:updata bootloader
1:updata ddr init
1
: 1
select 1
Sending ddrinit-2133-211102.bin.out
[########################################] 100% 87540/87540 Bytes
idcode:0x1860C8
updata flash ok
done.
Firmware update completed!
richardneese@Richards-Mac-mini JH71xx-tools %
