Installation README.TXT
kernel 6.6.16
irradium-3.7-riscv64-core-visionfive_2-6.6.16-build-20240210.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.6.16-build-20240210.img.zst.sha256
irradium-3.7-riscv64-xfce-visionfive_2-6.6.16-build-20240210.img.zst
irradium-3.7-riscv64-xfce-visionfive_2-6.6.16-build-20240210.img.zst.sha256
opensbi and u-boot are updated from upstream, HDMI output work.
update SPI bootloader
cat /proc/mtd
flashcp -v /boot/ u-boot.bin/dev/mtd0
flashcp -v /boot/u-boot.itb /dev/mtd2
U-Boot SPL 2024.01-jh7110 (Feb 10 2024 - 06:22:41 +0200)
DDR version: dc2e84f0.
Trying to boot from SPI
spl_fdt_fixup_version_b set prop starfive,tx-use-rgmii-clk fail.
OpenSBI v1.4
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Name : Generic
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform PMU Device : ---
Platform Reboot Device : ---
Platform Suspend Device : ---
Platform CPPC Device : ---
Firmware Base : 0x40000000
Firmware Size : 363 KB
Firmware RW Offset : 0x40000
Firmware RW Size : 107 KB
Firmware Heap Offset : 0x50000
Firmware Heap Size : 43 KB (total), 2 KB (reserved), 9 KB (used), 31 KB (free)
Firmware Scratch Size : 4096 B (total), 328 B (used), 3768 B (free)
Runtime SBI Version : 2.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Region00 : 0x0000000010000000-0x0000000010000fff M: (I,R,W) S/U: (R,W)
Domain0 Region01 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region02 : 0x0000000040040000-0x000000004005ffff M: (R,W) S/U: ()
Domain0 Region03 : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: ()
Domain0 Region04 : 0x000000000c000000-0x000000000fffffff M: (I,R,W) S/U: (R,W)
Domain0 Region05 : 0x0000000000000000-0xffffffffffffffff M: () S/U: (R,W,X)
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART ISA Extensions : zihpm
Boot HART PMP Count : 8
Boot HART PMP Granularity : 12 bits
Boot HART MHPM Info : 2 (0x00000018)
U-Boot 2024.01-jh7110 (Feb 10 2024 - 06:19:21 +0200)
CPU: rv64imafdc_zba_zbb
DRAM: 8 GiB
Core: 134 devices, 26 uclasses, devicetree: board
WDT: Not starting watchdog@13070000
MMC: mmc@16010000: 0, mmc@16020000: 1
Loading Environment from nowhere... OK
Product full SN: VF7110B1-2310-D004E000-00001219
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:26:e3
Ethernet MAC1 address: 6c:cf:39:00:26:e4
starfive_7110_pcie pcie@2b000000: Starfive PCIe bus probed.
starfive_7110_pcie pcie@2c000000: Starfive PCIe bus probed.
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
starting USB...
Bus xhci_pci: Register 5000420 NbrPorts 5
Starting the controller
USB XHCI 1.00
scanning bus xhci_pci for devices... 2 USB Device(s) found
Working FDT set to ff72ec90
Device 0: unknown device
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:3...
Found U-Boot script /boot.scr
2584 bytes read in 2 ms (1.2 MiB/s)
## Executing script at 43900000
Boot script loaded from mmc 1:3
155 bytes read in 1 ms (151.4 KiB/s)
43142 bytes read in 7 ms (5.9 MiB/s)
21838336 bytes read in 779 ms (26.7 MiB/s)
Working FDT set to 46000000
Failed to load '/dtb/starfive/overlay/starfive-fixup.scr'
2873152 bytes read in 176 ms (15.6 MiB/s)
## Loading init Ramdisk from Legacy Image at 46100000 ...
Image Name: uInitrd
Image Type: RISC-V Linux RAMDisk Image (gzip compressed)
Data Size: 2873088 Bytes = 2.7 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 46000000
Booting using the fdt blob at 0x46000000
Loading Ramdisk to fe462000, end fe71f700 ... OK
Loading Device Tree to 00000000fe3ef000, end 00000000fe461fff ... OK
Working FDT set to fe3ef000
Starting kernel ...
debugfs: Directory '16008000.dma-controller' with parent 'dmaengine' already present!
imx219 6-0010: Error reading reg 0x 0: -121
imx219 6-0010: failed to read chip id 219
Successfully mounted device UUID=32539e08-a5c0-4084-9f32-0932043d95e3
No kernel modules for Linux 6.6.16
INIT: version 3.08 booting
The system is coming up. Please wait.
udevd[138]: specified group 'sgx' unknown
linuxroot: clean, 112848/3769920 files, 1912311/15112960 blocks
boot: clean, 34/76912 files, 48313/307200 blocks
hostname: visionfive-2
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --verbose option to see the details of our search for an access method.
font: default
Couldn't get a file descriptor referring to the console.
keyboard: us
INIT: Entering runlevel: 2
INIT: version 3.08 reloadinglo net[ERROR] sshd crond firstrun
alsa dbus elogind lightdm
irradium (visionfive-2) (ttyS0)
