How to boot OpenBSD from NVMe?
Hey, ive tried to install OpenBSD with this tutorial:
i suceeded to step 10. But i didn’t know how to boot from there, u-boot auto boots the install image from sd card, if i remove sd card it doesn’t work. Ive tried to install EDK2, it boots also the sd card but with errors:
User
Range:RISC-V unsupported function.
Failed to read data, mDwEmmcCommand:A0002351, mDwEmmcArgument:0, Status:Device Error
MmcIoBlocks(): Failed to transfer block and Status:Device Error
InvalidateDataCacheRange:RISC-V unsupported function.
WriteBackDataCacheRange:RISC-V unsupported function.
disks: sd0* sd1 sd2 sr0
>> OpenBSD/riscv64 BOOTRISCV64 1.5
nvme boot, after sd card removed, also dont work in edk2.
ls
on FS0: (nvme) just says 0 dirs/0 files maybe because i installed openbsd without uefi? (I dont know really whats happening xD)
Ive tried to install openbsd again from edk2, and thought the errors are because of a missing .dtb file. So ive tried to add with
bcfg boot -opt "-dtb FS0:\visiofive2-v1.2a.dtb"
but it always failed, edk2 dont knows what i mean with this argument :c (chatgpt’s idea)
i now switched back to u-boot (latest version) it doesnt boot and shows error: couldnt find partition nvme 0:3
Do u know how to come from here to boot?
Thank you :slight_smile:
output:
U-Boot SPL 2021.10 (Nov 29 2023 - 14:51:40 +0800)
Trying to boot from SPI
OpenSBI v1.2
Platform HART Count       : 5
Platform Suspend Device   : ---
Firmware Size             : 392 KB
Firmware RW Offset        : 0x40000
Domain0 Boot HART         : 1
Domain0 Region00          : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region01          : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: ()
Domain0 Region02          : 0x0000000040040000-0x000000004007ffff M: (R,W) S/U: ()
Domain0 Region03          : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X)
Domain0 SysSuspend        : yes
Boot HART ID              : 1
Boot HART PMP Count       : 8
Boot HART MHPM Count      : 2
U-Boot 2021.10 (Nov 29 2023 - 14:51:40 +0800), Build: jenkins-github_visionfive2-20
CPU:   rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM:  8 GiB
Product full SN: VF7110A1-2249-D008E000-00000085
PCB revision: 0xa1
Ethernet MAC0 address: 6c:cf:39:00:1d:f5
Ethernet MAC1 address: 6c:cf:39:00:1d:f6
In:    serial
Out:   serial
Err:   serial
PCI: Failed autoconfig bar 10
starfive_pcie pcie@2C000000: Port link up.
Device 0: Vendor: 0x1e4b Rev: SN11457  Prod: AA232520065
            Type: Hard Disk
            Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
... is now current device
Try booting from NVME0 ...
** Invalid partition 3 **
Couldn't find partition nvme 0:3
Can't set block device
## Info: input data size = 16731 = 0x415B
## Error: "boot2" not defined
            Type: Hard Disk
Tring booting distro ...
            Type: Hard Disk
fatwrite - write file into a dos filesystem
Usage:
fatwrite <interface> <dev[:part]> <addr> <filename> [<bytes> [<offset>]]
    - write file 'filename' from the address 'addr' in RAM
      to 'dev' on 'interface'
Error reading config file
            Type: Hard Disk
Usage:
StarFive #
Maybe this can help you:
hey, yes seems to be the same problem! I finally managed to install openbsd on sdcard. I followed the instructions on github ive linked + i coped the efi directory from installer to sd card after installation + dtb file. then i booted like the installer :slight_smile: but nvme would be even better
It is basically the same. dd image to nvme and copy .dtb files to vendor directory. Load with command from my post (nvme instead of mmc).
yeah, i just plugged the nvme after install to my linux pc with a nvme to usb
then i copied the efi folder from mininstall img and the dtb file to the partition that appears in file manager :slight_smile:
and finally i can boot from nvme <3
load nvme 0:1 ${fdt_addr_r} jh7110-starfive-visionfive-2-v1.2a.dtb
load nvme 0:1 ${kernel_addr_r} efi/boot/bootriscv64.efi
bootefi ${kernel_addr_r} ${fdt_addr_r}
or automatic like in youre post:
env default -a -f
setenv distro_boot_env “echo Booting OpenBSD from NVME; load nvme 0:1 ${fdt_addr_r} jh7110-starfive-visionfive-2-v1.2a.dtb; load nvme 0:1 ${kernel_addr_r} efi/boot/bootriscv64.efi; bootefi ${kernel_addr_r} ${fdt_addr_r}”
saveenv
reset
thank you <33
After installing the v3.9.3 u-boot in flash and env default -a -f then saveenv…
I also use the dtb file you mention, unfortunately it is pretty old and doesn’t match the flash0 partitions in the current u-boot. I have updated a few parts of the dtb
at u-boot prompt #StarFive
check these variables
setenv fdt_addr_r 0x48000000 WAS 0x46000000
setenv kernel_addr_r 0x44000000 WAS 0x40200000
setenv kernel_comp_addr_r 0x90000000 WAS 0x5a000000
setenv kernel_comp_size 0x10000000 WAS 0x4000000
setenv ramdisk_addr_r 0x48100000 WAS 0x46100000
setenv fdtfile starfive/jh7110-visionfive-v2.dtb
saveenv
setenv devnum 1
run mmc_boot
will boot microsd and run OpenBSD installation
after install, at u-boot prompt $StarFive
setenv devnum 0
run nvme_boot
will boot from nvme
Device 0: Vendor: 0x1e0f Rev: HP01AE00 Prod: 42CPC1KBQX74
Type: Hard Disk
… is now current device
Scanning nvme 0:1…
28354 bytes read in 5 ms (5.4 MiB/s)
** Unable to read file ubootefi.var **
Failed to load EFI variables
Found EFI removable media binary efi/boot/bootriscv64.efi
152396 bytes read in 5 ms (29.1 MiB/s)
disks: sd0*
boot>
now a few changes to u-boot will get it automatic
