Help debugging eMMC being unavailable?
I’ve got my VisionFive2 booting nicely from SD card, and want to use eMMC as additional storage (more precisely, I was planning to write the eMMC image to the eMMC while booted off the SD card, but I’ve hit a snag well before that point).
I have installed an eMMc module on the board, but it doesn’t appear to be detected. From Linux, there is simply no /dev/mmcblk0 device at all. From u-boot (from the SD card), it appears that the card is not registering. Here’s a snippet of the u-boot output via uart:
U-Boot SPL 2021.10-dirty (Jun 11 2023 - 07:44:44 +0000)
DDR version: dc2e84f0.
Trying to boot from MMC2
OpenSBI VF2_515_v3.1.5_IMG1.19
Platform HART Count       : 5
Platform Suspend Device   : ---
Firmware Size             : 392 KB
Firmware RW Offset        : 0x40000
Domain0 Boot HART         : 1
Domain0 Region00          : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region01          : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: ()
Domain0 Region02          : 0x0000000040040000-0x000000004007ffff M: (R,W) S/U: ()
Domain0 Region03          : 0x0000000000000000-0xffffffffffffffff M: (R,W,X) S/U: (R,W,X)
Domain0 SysSuspend        : yes
Boot HART ID              : 1
Boot HART PMP Count       : 8
Boot HART MHPM Count      : 2
U-Boot 2021.10-dirty (Jun 11 2023 - 07:44:44 +0000), Build: jenkins-VisionFive2-SDK-Components-135
CPU:   rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM:  8 GiB
Product full SN: VF7110B1-2253-D008E000-00003992
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:42:8c
Ethernet MAC1 address: 6c:cf:39:00:42:8d
In:    serial
Out:   serial
Err:   serial
Error: 1 bit/pixel mode, but BMP has 24 bit/pixel
bootmode sd device 1/0
StarFive # mmc info
Device: sdio1@16020000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode: SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
StarFive # mmc list
sdio0@16010000: 0
sdio1@16020000: 1 (SD)
StarFive # mmc dev 0
StarFive #
This is a pretty new board, V1.3B. While it’s certainly possible that my eMMC module is simply non-functional, as this is currently the only one I have, I’d appreciate any tips on other things to try beside buying another. If the physical connection is sometimes finicky, I’d welcome advice on that as well (this is the first time I’ve done anything with an eMMC module).
Maybe you need to set switches?
The only switches I’m aware of are the RGPIO toggles for boot device, and I’m not (yet) trying to boot off the eMMC, I just want to use it as storage right now.
Please check your module is installed correctly. If you’re sure it’s correctly installed, this might be a hardware failure.
Remove and reinsert the eMMC card a few times. If it’s not showing up in dmesg or as mmcblk0 as you’re expecting, it may just not be connected fully. I had to attach mine 4 times I think to get it to show. Power down the board between removals of course.
This seems to be it. I think the 4th attempt was also the magic number for me. Finally the last time one of the connectors clicked in a bit further (visibly closer to the board), and pushing a bit harder on the other end got that on too; it was not falling off, but I guess in trying not to snap anything I ended up just not pressing hard enough. OpenSBI at least can now identify the card and retrieve stats.
Those connectors - on all boards - are a little tricky. My technique is to push in toward the socket harder than you think is necessary while rotating the card from about 20-60 degrees. There is often a little shift or a click while it locks in. Then, while holding in that pressure, rotate it down and let it click in.
Time for my own question: My eMMC card is too short for this board. Does anyone know of a little extender that perhaps grabs the card on the side edges and then extends the length, probably tapers into the ratchets on the back? I can’t seem to find the words Google uses to find such a device.
