Hi everyone, I would need to run a simulation of gem5 in Full System emulation with RISCV architecture with a simple C program. I therefore tried to use the --bare-metal option.
So, I tried to run the following command:
./gem5/build/RISCV/gem5.opt ./gem5/configs/example/riscv/fs_linux.py --kernel=test —bare-metal
where “test” is a compiled program written in C:
#include <stdio.h>
int main(void){
unsigned int r = 1337;
printf(“Hello World! %d\n”, r);
while (1) { }
and compiled with the following command: riscv64-unknown-linux-gnu-gcc --static test.c -o test
but gem5 returns me the following error:
gem5 Simulator System. https://www.gem5.org
gem5 is copyrighted software; use the --copyright option for details.
gem5 version 23.0.1.0
gem5 compiled Dec 15 2023 12:35:45
gem5 started Jan 8 2024 12:55:50
gem5 executing on 46f410d0d38b, pid 1704898
command line: ./gem5/build/RISCV/gem5.opt ./gem5/configs/example/riscv/fs_linux.py --kernel=test —bare-metal
warn: The
get_runtime_isafunction is deprecated. Please migrate away from using this function.warn: The
get_runtime_isafunction is deprecated. Please migrate away from using this function.Global frequency set at 1000000000000 ticks per second
warn: No dot file generated. Please install pydot to generate the dot file and pdf.
src/mem/dram_interface.cc:690: warn: DRAM device capacity (8192 Mbytes) does not match the address range assigned (512 Mbytes)
src/base/statistics.hh:279: warn: One of the stats is a legacy stat. Legacy stat is a stat that does not belong to any statistics::Group. Legacy stat is deprecated.
0: system.platform.rtc: Real-time clock set to Sun Jan 1 00:00:00 2012system.platform.terminal: Listening for connections on port 3456
system.remote_gdb: Listening for connections on port 7000
**** REAL SIMULATION ****
src/sim/simulate.cc:194: info: Entering event queue @ 0. Starting simulation…
src/cpu/simple/atomic.cc:753: panic: panic condition pkt.isError() occurred: Instruction fetch ([0x10420:0x10424]) failed: BadAddressError [10420:10423] IF
Memory Usage: 626284 KBytes
Program aborted at tick 0
— BEGIN LIBC BACKTRACE —
gem5.opt(+0x63c370)[0x56510fbd8370]
gem5.opt(+0x66b7ac)[0x56510fc077ac]
/lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f32bd310520]
/lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x12c)[0x7f32bd3649fc]
/lib/x86_64-linux-gnu/libc.so.6(raise+0x16)[0x7f32bd310476]
/lib/x86_64-linux-gnu/libc.so.6(abort+0xd3)[0x7f32bd2f67f3]
gem5.opt(+0x654825)[0x56510fbf0825]
gem5.opt(+0xb92873)[0x56511012e873]
gem5.opt(+0xb91920)[0x56511012d920]
gem5.opt(+0x657612)[0x56510fbf3612]
gem5.opt(+0x6953b8)[0x56510fc313b8]
gem5.opt(+0x6959ab)[0x56510fc319ab]
gem5.opt(+0x132e8f0)[0x5651108ca8f0]
gem5.opt(+0x5d0b74)[0x56510fb6cb74]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(+0x128023)[0x7f32bde0f023]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(_PyObject_Call+0x5c)[0x7f32bddc8fec]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(_PyEval_EvalFrameDefault+0x4b16)[0x7f32bdd5d776]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(+0x1c23af)[0x7f32bdea93af]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(_PyEval_EvalFrameDefault+0x9d68)[0x7f32bdd629c8]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(_PyEval_EvalFrameDefault+0x69de)[0x7f32bdd5f63e]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(PyEval_EvalCode+0xbe)[0x7f32bdea43de]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(+0x1bd96d)[0x7f32bdea496d]
/lib/x86_64-linux-gnu/libpython3.10.so.1.0(+0x1287b3)[0x7f32bde0f7b3]
gem5.opt(+0x66e2f7)[0x56510fc0a2f7]
gem5.opt(+0x3cff1b)[0x56510f96bf1b]
/lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f32bd2f7d90]
— END LIBC BACKTRACE —
For more info on how to address this issue, please visit gem5: Common errors within gem5
Aborted (core dumped)
How can I fix it?
Is it correct to use the bare-metal option? Or can I do it some other way?
Does the C program need any dependencies?
