File Format Conversion and compression
Transforming images from one format to another is fundamental. Different formats offer distinct advantages in terms of quality, compression, and transparency. I got a tif file image which is size in 8MB, the picture taken from the satellite, and I want to keep that image in smaller size, and I also want to use that on my project. For this I will have to compress and convert file format for compression I’m using the application such as https://jpegcompressor.com/ it is good in image compression and also, I’m searching file converter application which will convert fast and save my time. Do you have any suggestion or recommendation it will appreciate.
Thank you.
Imagemagick has support for command line automation of fromat changes, rotation, scaling, and a lot more.
Thank you I’ll figure it out.
