I spent (rather wasted ) several hours trying to build the VisionV2 repos using Ubuntu 22.04 LTS. Failed steps and even the built version had a few issues running on the board.
I read in the docs that only 18.04 and 20.04 are mentioned. I built a docker container to build the repo and it was a seamless experience.
Sharing the repo for others who may find it useful.
Ubuntu are not regularly producing containers for riscv at this time.
They produced a few containers in November last year as a test so you could potentially use these, note there is no bionic aka 18.04 you could use focal aka 20.04.
As these are 10 months old there could potentially be a security problem with them.
ubuntu:focal-20220922
ubuntu:jammy-20221003
ubuntu:kinetic-20220922
If you want to run things in docker on your board you can always use the x86_64 container in an emulator.
To do this you need to install the qemu binfmt driver inside docker to allow you to run docker containers for x86_64, arm etc.
docker run --name binfmt --privileged tonistiigi/binfmt:qemu-v6.1.0 --install all
you can then add a --platform linux/amd64 to run the docker command line to use the x86_64 container.
Thanks for the pointer. I had not seen it. But the approaches are different I would say. I went for a minimal but ease of host integration and simple make step not as elaborate as the other approach which looks to be very detailed.
