Cross compiler on mac os
I’m following the tutorial on this page : VisionFive Single Board Computer Software Technical Reference Manual | RVspace
and it asks for a cross compiler but since the tutorial is targeted at Linux users, I don’t know what’s the equivalent in mac. I’m talking about this :
sudo apt update
sudo apt upgrade
sudo apt install gcc-riscv64-linux-gnu
how do I install riscv64 cross compiler on a mac ? and how the following command would change ?
make <Configuration_File> ARCH=riscv CROSS_COMPILE=riscv64-linux-gnu-
Thanks a lot
Maybe you can refer this link to build the cross compiler under mac.
We tried this method and found that mac can’t generate riscv64-linux-gnu-cross compiler, can generate riscv64-unknow-elf-compiler based on newlib, can’t generate riscv64-linux-gnu- based on glibc,because riscv64-linux-gnu-toolchain build requires a case-sensitive filesystem, macOsx is a case-insensitive filesystem.
you can Install the ubuntu virtual machine through virtualbox on the mac to build the compilation environment.
Homebrew provides a lovely kit of binaries for riscv64-unknown-elf-, but I’m less sure about a premade Linux cross.
The case sensitivity thing is a nuisance, but it’s not hard. You just create a case-sensitivity afs filesystem in a dmg, mount it, and do your build there. Look at the recipe (it’s probably in Ruby) on how Homebrew automates the builds and copy that.
Blogger nc-pin recently did a series of building RISC-V chain for a different RISC-V chip (ch32v) but you can use the “Mac part” of the recipe and slot in the Linux triplet in configure and such.
See Building Toolchain for RISC-V on macOS – NC Pin and related pages. It even links back to the crosstool-ng which has more (and less supported) doc on building the GNU chain on MacOS.
and
a few other pages help take the MacOS edges off enough that fro m there you can treat it like just a Linux system. The addition of Homebrew to your toolbelt where you can easily add things like GNU sed or awk or whatever the build wants can really be a lifesaver.
Some advice from my own cross-compilation adventures:
A “-elf” toolchain should be able to build for any modern Linux kernel. Certain builds may benefit from a “-linux(-musl|-gnu)” on the end of the triplet, but the current ABIs are defined for elf, so I don’t see why -elf wouldn’t work. Only gotcha I can think of off the top of my head is the specific suffix may influence the OS ABI (i.e. 0 - UNIX_SV, 3 - Linux, 6 - SunOS, etc., byte at offset 0x7 in elf). That said, you can use elfedit to rectify this.
The without-headers and with-newlib options when building GCC are very important. The former will prevent looking for system C library headers, that way you don’t inadvertently pull in a constant or something from your host system (or another cross compiler). The latter will prevent glibc-specific behavior when building libgcc among other components. For some reason that I don’t understand the validity of, there is a circular dependency between libgcc and glibc, so libgcc is built in terms of glibc, and thus any compilation is then tainted with glibc, despite what should be the independent nature of the compiler from the environment that consumes it. In any case, ensuring you use with-newlib prevents attempts to use these glibc-specific cases.
That said, if you’re specifically targeting glibc, and you want the purity of a glibc-oriented compilation environment, your challenge is twofold. First, you have to build the cross-compiler using the ‘with-newlib’ option to build it without glibc-based assumptions. Of course there are countless other options you need to include, you’ll find those in the guidance linked in this thread, but essentially you’re cutting out unessential libraries as well as features that can’t really be used in a cross-compilation environment.
Before you start building glibc, make sure you grab a copy of the kernel headers for the kernel you’re looking to target. You can either pass a command-line argument to the glibc configure script or just place the includes (via make INSTALL_HDR_PATH=/path/to/riscv/includes headers_install in the kernel source)
This first compiler can then be used to cross-compile glibc targeting riscv64-unknown-linux-gnu (–host=riscv64-unknown-linux-gnu). You’ll want to ensure this gets installed in your cross-compiler’s prefix, typically /usr/local/. Once you’ve got a working copy of glibc stood up, then you’d need to build GCC again but this time omit ‘with-newlib’ and I believe you would issue --with-headers= and that will build a second pass of GCC but this time using the glibc-specific extensions in libgcc. I’m not certain but I think at this point you could build this version with shared library and threading support enabled since it can make use of those bits of glibc. Not certain though, mileage may vary, I’ve never bothered with glibc purity in my cross compiler like this.
That should then result in a cross-compilation environment capable of building C for riscv64 Linux. I didn’t touch on C++, but I believe you’d just include c++ in your ‘enable-languages’ argument and avoid disabling libstdc++, although I have never tried to build GCC’s libc++ against anything other than glibc.
There really shouldn’t be much different between building these toolchains on Linux vs macOS, or any other reasonably POSIX-y OS. I do most of my day to day on FreeBSD these days, and have fully functioning cross C environments for riscv64, aarch64, x86_64, and m68k. Happy to provide any other info, been tinkering with cross development for a while now.
