Hi everyone,
currently im doing compiling Linux Kernel, im following this step Compiling& updating Kernel but i have fa some error which is :
linux$ make ARCH=riscv olddefconfig
LEX scripts/kconfig/lexer.lex.c
/bin/sh: 1: flex: not found
make[1]: *** [scripts/Makefile.host:9: scripts/kconfig/lexer.lex.c] Error 127
make: *** [Makefile:616: olddefconfig] Error 2
anyone know how to fix this problem , thank in advance.
Iâd recomend reading this chapter first:
Install Packages (rvspace.org)
If it still misses flex then you need to install it just like before.
apt install flex
And do this for anything that is missing. In order to do stuff you have to have the tools installed first.
Step 1. indicated all the packages to install including flex.
More broadly:
https://kernel-team.pages.debian.net/kernel-handbook/ch-common-tasks.html#s-common-official
apt-get install build-essential
apt-get build-dep linux
apt-get source linux
between the build-essential and the build-dep, it will definitely fetch whatever you need to build.
i already the step and another error come out:
~/linux$ make ARCH=riscv -j$(nproc) bindeb-pkg
sh ./scripts/package/mkdebian
dpkg-buildpackage -r"fakeroot -u" -a$(cat debian/arch) -b -nc -uc
dpkg-buildpackage: info: source package linux-upstream
dpkg-buildpackage: info: source version 5.15.0-1
dpkg-buildpackage: info: source distribution bookworm
dpkg-buildpackage: info: source changed by user <user@starfive>
dpkg-buildpackage: info: host architecture riscv64
dpkg-source --before-build .
dpkg-checkbuilddeps: error: Unmet build dependencies: bc
dpkg-buildpackage: warning: build dependencies/conflicts unsatisfied; aborting
dpkg-buildpackage: warning: (Use -d flag to override.)
make[1]: *** [scripts/Makefile.package:83: bindeb-pkg] Error 3
make: *** [Makefile:1576: bindeb-pkg] Error 2
anyone know how to fix this problem, thank in advance
sudo apt-get build-dep linux
Reading package lists... Done
E: You must put some 'deb-src' URIs in your sources.list
how to fix this problem? thank you in advance.
Whatâre the contents of your /etc/apt/sources.list?
Sounds like apt has no idea where to get packages.
deb https://snapshot.debian.org/archive/debian-ports/20221225T084846Z unstable >
what is this can anyone explain ? and how to fix.
Ahhhh⌠youâre telling it to fetch the source for package âlinuxâ, but you have no deb-src sources configured.
I donât think you need the apt-get source linux â you donât want a source DEB. Youâve got your own sources.
After apt install build-essential, what does your make ARCH=riscv -j$(nproc) bindeb-pkg look like?
Incidentally, hereâs how I build:
nohup make INSTALL_MOD_STRIP=1 -j5 bindeb-pkg &
Stripping the modules is not advised if youâre planning to do any kernel debugging. But if youâre not, it saves a chunk of disk space and a TON of time. Each time the system rebuilds its initrd thereâs much less data to compress.
apt-get install build-essential linux-source bc kmod cpio flex libncurses5-dev libelf-dev libssl-dev dwarves bison git ![]()
git clone GitHub - starfive-tech/linux ![]()
cd linux/ ![]()
cp arch/riscv/configs/starfive_visionfive2_defconfig .config ![]()
make ARCH=riscv olddefconfig ![]()
make ARCH=riscv -j$(nproc) bindeb-pkg:
dpkg-genbuildinfo --build=binary -O../linux-upstream_5.15.0-1_riscv64.buildinfo
dpkg-genchanges --build=binary -O../linux-upstream_5.15.0-1_riscv64.changes
dpkg-genchanges: info: binary-only upload (no source code included)
dpkg-source --after-build .
dpkg-buildpackage: info: binary-only upload (no source included)
How to fix this problem?
Iâm deeply sorry, I misled when I mentioned the apt-get source linux. That was a broad stroke about how itâs usually done on intel x86_64 for building the kernel for Debian Linux. scottfk is entirely right. You donât need the apt-get source linux because youâre using the starfive github sources for the kernel(aka linux). Yeah when starfiveâs sources are entirely merged with the linux mainline, fetching the sources using âapt-get source linuxâ will be possible, but not yet unfortunately.
Iâm not seeing the problem⌠When I do a make bindeb-pkg, I get the same informational output as youâre seeing. But I also get working kernel DEBs.
Are there errors being spit out as well? Can you copy/paste the contents of your shell from build (make bindeb-pkg) through to exit and return to prompt?
dpkg-buildpackage: info: source version 5.15.0-7
dpkg-buildpackage: info: source changed by root <root@starfive>
debian/rules binary
make KERNELRELEASE=5.15.0 ARCH=riscv KBUILD_BUILD_VERSION=7 -f ./Makefile
CALL scripts/atomic/check-atomics.sh
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
UPD include/generated/compile.h
CC init/version.o
AR init/built-in.a
CC [M] drivers/net/wireless/eswin/ecrnx_msg_tx.o
CC [M] drivers/net/wireless/eswin/ecrnx_msg_rx.o
CC [M] drivers/net/wireless/eswin/ecrnx_utils.o
CC [M] drivers/net/wireless/eswin/ecrnx_cmds.o
drivers/net/wireless/eswin/ecrnx_msg_rx.c: In function âecrnx_rx_remain_on_channel_exp_indâ:
drivers/net/wireless/eswin/ecrnx_msg_rx.c:412:5: warning: "CONFIG_ECRNX_P2P" is not defined, evaluates to 0 [-Wundef]
412 | #if CONFIG_ECRNX_P2P
drivers/net/wireless/eswin/ecrnx_msg_rx.c: In function âecrnx_rx_handle_msgâ:
drivers/net/wireless/eswin/ecrnx_msg_rx.c:1582:29: warning: the comparison will always evaluate as âtrueâ for the address of âcmd_mgrâ will never be NULL [-Waddress]
1582 | if(!ecrnx_hw || !msg || !(&ecrnx_hw->cmd_mgr))
In file included from drivers/net/wireless/eswin/ecrnx_msg_rx.c:12:
/home/user/linux/drivers/net/wireless/eswin/fullmac/ecrnx_defs.h:595:26: note: âcmd_mgrâ declared here
595 | struct ecrnx_cmd_mgr cmd_mgr;
CC [M] drivers/net/wireless/eswin/ecrnx_cfgfile.o
CC [M] drivers/net/wireless/eswin/ecrnx_strs.o
CC [M] drivers/net/wireless/eswin/ecrnx_txq.o
CC [M] drivers/net/wireless/eswin/ecrnx_mod_params.o
CC [M] drivers/net/wireless/eswin/ecrnx_platform.o
CC [M] drivers/net/wireless/eswin/ipc_host.o
CC [M] drivers/net/wireless/eswin/hal_desc.o
CC [M] drivers/net/wireless/eswin/ecrnx_iwpriv.o
CC [M] drivers/net/wireless/eswin/fw_head_check.o
CC [M] drivers/net/wireless/eswin/slave_log_buf.o
CC [M] drivers/net/wireless/eswin/fullmac/ecrnx_tdls.o
CC [M] drivers/net/wireless/eswin/fullmac/ecrnx_mesh.o
CC [M] drivers/net/wireless/eswin/fullmac/ecrnx_main.o
CC [M] drivers/net/wireless/eswin/fullmac/ecrnx_rx.o
CC [M] drivers/net/wireless/eswin/fullmac/ecrnx_tx.o
CC [M] drivers/net/wireless/eswin/fullmac/ecrnx_calibration_data.o
CC [M] drivers/net/wireless/eswin/usb/usb.o
drivers/net/wireless/eswin/fullmac/ecrnx_main.c: In function âecrnx_cfg80211_add_stationâ:
drivers/net/wireless/eswin/fullmac/ecrnx_main.c:1848:54: warning: the comparison will always evaluate as âtrueâ for the address of âmac_addrâ will never be NULL [-Waddress]
1848 | if((!is_multicast_sta(sta->sta_idx)) && (sta->mac_addr)) {
In file included from drivers/net/wireless/eswin/fullmac/ecrnx_main.c:20:
drivers/net/wireless/eswin/fullmac/ecrnx_defs.h:411:8: note: âmac_addrâ declared here
411 | u8 mac_addr[ETH_ALEN];
drivers/net/wireless/eswin/fullmac/ecrnx_main.c: In function âecrnx_cfg80211_tdls_mgmtâ:
drivers/net/wireless/eswin/fullmac/ecrnx_main.c:3172:12: warning: this statement may fall through [-Wimplicit-fallthrough=]
3172 | if ((status_code == 0) &&
drivers/net/wireless/eswin/fullmac/ecrnx_main.c:3179:5: note: here
3179 | case WLAN_TDLS_SETUP_REQUEST:
CC [M] drivers/net/wireless/eswin/usb/ecrnx_usb.o
CC [M] drivers/net/wireless/eswin/usb/core.o
CC [M] drivers/net/wireless/eswin/usb/fw.o
CC [M] drivers/net/wireless/eswin/eswin_port/eswin_utils.o
CC [M] drivers/net/wireless/eswin/fullmac/ecrnx_amt.o
CC [M] drivers/net/wireless/eswin/ecrnx_radar.o
CC [M] drivers/net/wireless/eswin/ecrnx_debug.o
In file included from ./include/linux/kernel.h:5,
from ./include/linux/interrupt.h:6,
from /home/user/linux/drivers/net/wireless/eswin/fullmac/ecrnx_defs.h:16,
from drivers/net/wireless/eswin/ecrnx_debug.c:14:
./include/linux/stdarg.h:6: warning: "va_start" redefined
6 | #define va_start(v, l) __builtin_va_start(v, l)
In file included from drivers/net/wireless/eswin/ecrnx_debug.c:12:
/usr/lib/gcc/riscv64-linux-gnu/12/include/stdarg.h:47: note: this is the location of the previous definition
47 | #define va_start(v,l) __builtin_va_start(v,l)
./include/linux/stdarg.h:8: warning: "va_arg" redefined
8 | #define va_arg(v, T) __builtin_va_arg(v, T)
/usr/lib/gcc/riscv64-linux-gnu/12/include/stdarg.h:49: note: this is the location of the previous definition
49 | #define va_arg(v,l) __builtin_va_arg(v,l)
./include/linux/stdarg.h:9: warning: "va_copy" redefined
9 | #define va_copy(d, s) __builtin_va_copy(d, s)
/usr/lib/gcc/riscv64-linux-gnu/12/include/stdarg.h:52: note: this is the location of the previous definition
52 | #define va_copy(d,s) __builtin_va_copy(d,s)
LD [M] drivers/net/wireless/eswin/wlan_ecr6600u_usb.o
GEN .version
LD vmlinux.o
MODPOST vmlinux.symvers
MODINFO modules.builtin.modinfo
GEN modules.builtin
LD .tmp_vmlinux.kallsyms1
KSYMS .tmp_vmlinux.kallsyms1.S
AS .tmp_vmlinux.kallsyms1.S
LD .tmp_vmlinux.kallsyms2
KSYMS .tmp_vmlinux.kallsyms2.S
AS .tmp_vmlinux.kallsyms2.S
LD vmlinux
SORTTAB vmlinux
SYSMAP System.map
OBJCOPY arch/riscv/boot/Image
MODPOST modules-only.symvers
GZIP arch/riscv/boot/Image.gz
GEN Module.symvers
LD [M] drivers/net/wireless/eswin/wlan_ecr6600u_usb.ko
Kernel: arch/riscv/boot/Image.gz is ready
make KERNELRELEASE=5.15.0 ARCH=riscv KBUILD_BUILD_VERSION=7 -f ./Makefile intdeb-pkg
sh ./scripts/package/builddeb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/sifive/hifive-unleashed-a00.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/sifive/hifive-unmatched-a00.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-visionfive-v2.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/vf2-overlay/vf2-overlay-uart3-i2c.dtbo
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/evb-overlay/jh7110-evb-overlay-can.dtbo
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-fpga.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/evb-overlay/jh7110-evb-overlay-sdio.dtbo
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-can-pdm-pwmdac.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-dvp-rgb2hdmi.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/evb-overlay/jh7110-evb-overlay-spi.dtbo
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-pcie-i2s-sd.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/evb-overlay/jh7110-evb-overlay-uart4-emmc.dtbo
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/evb-overlay/jh7110-evb-overlay-uart5-pwm.dtbo
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-i2s-ac108.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/evb-overlay/jh7110-evb-overlay-rgb2hdmi.dtbo
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-spi-uart2.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-uart1-rgb2hdmi.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-uart4-emmc-spdif.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-uart5-pwm-i2c-tdm.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-evb-usbdevice.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-visionfive-v2-A10.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-visionfive-v2-A11.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-visionfive-v2-wm8960.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-visionfive-v2-sof-wm8960.dtb
INSTALL debian/linux-image/usr/lib/linux-image-5.15.0/starfive/jh7110-visionfive-v2-ac108.dtb
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/crypto/md4.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/crypto/md5.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/crypto/tcrypt.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/bluetooth/aic_btusb/aic_btusb.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/bluetooth/btintel.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/bluetooth/btusb.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/mailbox/starfive_mailbox-test.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/md/dm-mod.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/a8293.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/af9033.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/ascot2e.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/atbm8830.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/au8522_common.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/au8522_decoder.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/au8522_dig.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/bcm3510.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cx22700.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cx22702.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cx24110.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cx24113.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cx24116.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cx24117.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cx24120.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cx24123.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cxd2099.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cxd2820r.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dib0070.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cxd2841er.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/cxd2880/cxd2880.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dib0090.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dib3000mb.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dib3000mc.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dib7000m.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dib7000p.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dib8000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dib9000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dibx000_common.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/drx39xyj/drx39xyj.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/drxd.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/drxk.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/ds3000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/dvb-pll.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/ec100.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/helene.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/horus3a.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/isl6405.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/isl6421.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/isl6423.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/itd1000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/ix2505v.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/l64781.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lg2160.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lgdt3305.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lgdt330x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lgs8gl5.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lgs8gxx.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lnbh25.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lnbh29.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lnbp21.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/lnbp22.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/m88rs2000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mb86a16.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mb86a20s.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mn88443x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mn88472.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mn88473.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mt312.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mt352.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mxl5xx.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/mxl692.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/nxt200x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/nxt6000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/or51132.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/or51211.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/s5h1409.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/s5h1411.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/s5h1420.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/s5h1432.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/s921.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/si2165.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/si21xx.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/sp2.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/sp887x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stb0899.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stb6000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv0288.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stb6100.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv0297.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv0299.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv0367.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv0900.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv090x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv0910.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv6110.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv6110x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/stv6111.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tc90522.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda10021.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda10023.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda10048.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda1004x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda10071.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda10086.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda18271c2dd.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda665x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda8083.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda8261.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tda826x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/ts2020.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/tua6100.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/ves1820.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/ves1x93.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/zd1301_demod.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/zl10036.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/zl10039.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/dvb-frontends/zl10353.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/platform/chips-media/wave5/wave5.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/spi/cxd2880-spi.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/e4000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/fc0011.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/fc0012.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/fc0013.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/fc2580.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/it913x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/m88rs6000t.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mc44s803.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/max2165.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/msi001.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mt2060.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mt2063.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mt20xx.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mt2131.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mt2266.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mxl301rf.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mxl5005s.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/mxl5007t.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/qm1d1b0004.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/qm1d1c0042.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/qt1010.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/r820t.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/si2157.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tda18218.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tda18212.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tda18250.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tda18271.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tda827x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tda8290.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tda9887.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tea5761.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tea5767.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tua9001.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tuner-types.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tuner-simple.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/tuner-xc2028.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/xc4000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/tuners/xc5000.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/media/v4l2-core/v4l2-mem2mem.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/net/wireless/aic8800/aic8800_fdrv/aic8800_fdrv.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/net/wireless/aic8800/aic_load_fw/aic_load_fw.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/net/wireless/eswin/wlan_ecr6600u_usb.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/misc/ezusb.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/aircable.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/ark3116.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/belkin_sa.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/ch341.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/cp210x.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/cyberjack.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/cypress_m8.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/digi_acceleport.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/empeg.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/f81232.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/ftdi_sio.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/garmin_gps.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/io_edgeport.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/io_ti.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/ipaq.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/ipw.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/ir-usb.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/iuu_phoenix.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/keyspan.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/keyspan_pda.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/kl5kusb105.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/kobil_sct.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/mct_u232.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/metro-usb.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/mos7720.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/navman.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/mos7840.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/omninet.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/opticon.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/oti6858.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/pl2303.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/qcaux.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/qcserial.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/safe_serial.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/sierra.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/spcp8x5.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/ssu100.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/symbolserial.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/ti_usb_3410_5052.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/usb_debug.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/usb_wwan.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/usbserial.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/visor.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/whiteheat.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/wishbone-serial.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/drivers/usb/serial/xsens_mt.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/fs/cifs/cifs.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/fs/efivarfs/efivarfs.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/fs/ksmbd/ksmbd.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/fs/nfs/blocklayout/blocklayoutdriver.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/fs/nls/nls_utf8.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/fs/smbfs_common/cifs_arc4.ko
INSTALL debian/linux-image/lib/modules/5.15.0/kernel/fs/smbfs_common/cifs_md4.ko
DEPMOD debian/linux-image/lib/modules/5.15.0
dpkg-deb: building package 'linux-headers-5.15.0' in '../linux-headers-5.15.0_5.15.0-7_riscv64.deb'.
INSTALL debian/linux-libc-dev/usr/include
dpkg-deb: building package 'linux-libc-dev' in '../linux-libc-dev_5.15.0-7_riscv64.deb'.
dpkg-deb: building package 'linux-image-5.15.0' in '../linux-image-5.15.0_5.15.0-7_riscv64.deb'.
dpkg-genbuildinfo --build=binary -O../linux-upstream_5.15.0-7_riscv64.buildinfo
dpkg-genchanges --build=binary -O../linux-upstream_5.15.0-7_riscv64.changes
hope someone can solve this
Looks like you got a clean build and 3 DEB packages created. What problem are you seeing?
here:
what is this mean, can you explain? (sorry im new here)
I still get error for next part:
~/linux$ dpkg -i *.deb
dpkg: error: requested operation requires superuser privilege
What is it you are trying to accomplish? I donât mean to sound rude, but you are clearly out of your depth.
All of the output you have seen can be understood by reading it carefully and thinking it through in the context of building a packaged kernel. Your questions indicate you are neither reading nor understanding the context.
The last lines you quoted indicate that you have built binary-only packages. You did not include source code.
The final line indicates that you are trying to install packages without proper privileges (usually root). It also indicates that you lack fundamental Linux skills.
