I’m working in porting a bootloader to VisionFive instead of using standard U-Boot SPL. I have been looking into the boot specs at JH7110 Boot User Guide (rvspace.org) but can’t find a way to boot using the offset where SPL should live. Is there an additional header, padding or something else to be taken into consideration?
My linker is very similar to u-boot/arch/riscv/cpu/u-boot-spl.lds at master · u-boot/u-boot (github.com) but still no lucky…
Thank you in advance!
SPL image needs to be prepared with
and depends on what media you use (qspi/emmc/sdcard), it needs to be flashed differently. For qspi, it’s at offset 0. For sdcard/emmc, see this:
The device firmware loads U-Boot SPL (u-boot-spl.bin.normal.out) from the partition with type GUID 2E54B353-1271-4842-806F-E436D6AF6985. You are free to choose any partition number.
Sorry for the late reply. Thank you! I will give a try.
