Can‘t boot
U-Boot SPL 2021.10 (Dec 19 2022 - 17:24:44 +0800)
DDR version: dc2e84f0.
Trying to boot from SPI
OpenSBI v1.0
Platform HART Count       : 5
Platform Reboot Device    : ---
Platform Shutdown Device  : ---
Firmware Size             : 360 KB
Runtime SBI Version       : 0.3
Domain0 Boot HART         : 1
Domain0 Region00          : 0x0000000002000000-0x000000000200ffff (I)
Domain0 Region01          : 0x0000000040000000-0x000000004007ffff ()
Domain0 Region02          : 0x0000000000000000-0xffffffffffffffff (R,W,X)
Boot HART ID              : 1
Boot HART PMP Count       : 8
Boot HART MHPM Count      : 2
U-Boot 2021.10 (Dec 19 2022 - 17:24:44 +0800)
CPU:   rv64imacu
Model: StarFive VisionFive V2
DRAM:  8 GiB
OK
Product full SN: VF7110B1-2253-D008E000-00002052
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:31:d1
Ethernet MAC1 address: 6c:cf:39:00:31:d2
In:    serial@10000000
Out:   serial@10000000
Err:   serial@10000000
bootmode flash device 0
Couldn't find partition mmc 0:3
Can't set block device
Importing environment from mmc0 ...
Couldn't find partition mmc 1:2
## Error: "boot2" not defined
ethernet@16030000 Waiting for PHY auto negotiation to complete...... done
BOOTP broadcast 1
BOOTP broadcast 2
DHCP client bound to address 192.168.0.100 (376 ms)
TFTP from server 192.168.0.12; our IP address is 192.168.0.100
Filename 'boot.scr.uimg'.
Load address: 0x43900000
Loading: *
ARP Retry count exceeded; starting again
BOOTP broadcast 1
DHCP client bound to address 192.168.0.100 (123 ms)
Load address: 0x40200000
Loading: *
I can’t figure out the problem. I’d appreciate any help figuring it out.
You have to update the firmware maybe. :flushed:
Which specific firmware?
Take Releases · starfive-tech/VisionFive2 · GitHub if you prefer the Debian StarFive provided, or take Packages in “Ubuntu RISC-V Release PPA” : Ubuntu RISC-V Release PPA : “Development of Ubuntu software for RISC-V platforms” team if you’d like to install Ubuntu.
Just try step 1&2 from Install Ubuntu 23.10 for VF2 (NVMe SSD) step by step . (Pay attention to the file names, u-boot.itb is called visionfive2_fw_payload.img if you use the firmware StarFive released.)
I am using the 69image version of debain. I use putty to connect vf2. When I power on vf2, it will report this error.
Folk, did you update the firmware?
@Zen You can actually have practice for step 1&2, and feel free to mention me for every possible issue.
What should I do if I am using a Windows system? What you provide is the operation of Linux system.Should I write commands directly on the putty port?
Ha…, :rofl: :rofl: my friend, it stumps me.
I haven’t been using Windows for a long time and haven’t tried it.
Thank you for your patient answer.
