My Vision5 boots with a 100Hz video signal, which is out of spec for my monitor.  How can I change the boot kernel configuration for a 60Hz video refresh rate ?
Can I manually edit /boot/config-5.15.0-61.fc33.riscv64 at comment “Kernel features” ?
Malcolm
Do you mean HDMI monitor? Did you connect the monitor before power on?
yes, monitor on before power to vision5
What version of fedora image are you using? the newest fedora image is release in 2021.12.26,   kernel is 5.15.10 .
This is as supplied on the SD card:
-rwxr-xr-x  1 root root  11M Nov 11  2021 vmlinuz-5.15.0-61.fc33.riscv64
-rw-r–r–. 1 root root  11M Dec 25 20:40 vmlinuz-5.15.10+
-rw-r–r–. 1 root root  11M Dec 25 20:41 vmlinuz-5.16.0-rc6+
As only the top one is executable, I assume that is the image loaded.
Without video I use an ssh terminal
Malcolm
It look the Fedora image version is newest.
would you please take  a picture of the prompt on the dispaly?
do you have the whole boot log of visionfive from serial port?
dmesg output:
dmesg (51.8 KB)
I will send photo of 98Hz error message from the screen next
in place of grub.cfg at /boot/efi/EFI/fedora I have instead a binary file: grubriscv64 and I have no templates at /etc/grub.d or chance to use grub2-mkconfig to make changes to the boot process.
here is an extract from: config-5.15.0-61.fc33.riscv64
looks like 100Hz is set here
kernel seems to be aligned with fedora 33, but 36 is now available.
Do you have another HDMI monitor to try?
This configuration value has nothing to do with your problem, it has nothing to do with the TV frequency at all. I have this value in the config and everything works fine on a TV with 60 Hz. What is the monitor model and how is the monitor connected to the StaFive (cable length and type)? You can force the resolution and frequency settings in the kernel command line parameters and check the operation (for example, take an Altlinux image and add the desired value to extlinux.conf).
@balbes150
Thanks, I’ll take another look at the problem.
