Hi @rdunkle !
Works with U-Boot v2025.10 and OpenSBI higher than v1.7 for me:
U-Boot SPL 2025.10 (Nov 06 2025 - 07:48:41 +0100)
DDR version: dc2e84f0.
Trying to boot from MMC2
OpenSBI v1.7-71-g38a6106
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Name : StarFive VisionFive 2 v1.3B
Platform Features : medeleg
Platform HART Count : 4
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Platform CPPC Device : ---
Firmware Base : 0x40000000
Firmware Size : 357 KB
Firmware RW Offset : 0x40000
Firmware RW Size : 101 KB
Firmware Heap Offset : 0x4d000
Firmware Heap Size : 49 KB (total), 0 KB (reserved), 12 KB (used), 35 KB (free)
Firmware Scratch Size : 4096 B (total), 416 B (used), 3680 B (free)
Runtime SBI Version : 3.0
Standard SBI Extensions : time,rfnc,ipi,base,hsm,srst,pmu,dbcn,fwft,legacy,dbtr,sse
Experimental SBI Extensions : none
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 HARTs : 1*,2*,3*,4*
Domain0 Region00 : 0x0000000040040000-0x000000004005ffff M: (F,R,W) S/U: ()
Domain0 Region01 : 0x0000000040000000-0x000000004003ffff M: (F,R,X) S/U: ()
Domain0 Region02 : 0x0000000010000000-0x0000000010000fff M: (I,R,W) S/U: (R,W)
Domain0 Region03 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region04 : 0x000000000c000000-0x000000000fffffff M: (I,R,W) S/U: (R,W)
Domain0 Region05 : 0x0000000000000000-0xffffffffffffffff M: () S/U: (R,W,X)
Domain0 Next Arg1 : 0x00000000402c1d28
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART ISA Extensions : zihpm,sdtrig
Boot HART PMP Count : 8
Boot HART PMP Granularity : 12 bits
Boot HART PMP Address Bits : 34
Boot HART MHPM Info : 2 (0x00000018)
Boot HART Debug Triggers : 8 triggers
U-Boot 2025.10 (Nov 06 2025 - 07:48:41 +0100)
CPU: sifive,u74-mc
Model: StarFive VisionFive 2 v1.3B
DRAM: 8 GiB
Core: 159 devices, 29 uclasses, devicetree: board
WDT: Not starting watchdog@13070000
MMC: mmc@16010000: 0, mmc@16020000: 1
Product full SN: VF7110B1-2318-D008E000-18003208
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:5d:7e
Ethernet MAC1 address: 6c:cf:39:00:5d:7f
starfive_7110_pcie pcie@940000000: Starfive PCIe bus probed.
starfive_7110_pcie pcie@9c0000000: Starfive PCIe bus probed.
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
starting USB...
Register 5000420 NbrPorts 5
Starting the controller
USB XHCI 1.00
Bus xhci_pci: 2 USB Device(s) found
Working FDT set to ff719f00
StarFive #
With OpenSBI version 1.7, when building with FW_START_ADDR, the parameter will be ignored. So it defaults to address 0x0 instead of 0x40000000 which raise an exception. That’s might be a bug. But with the current sources in the main/master branch from OpenSBI it works.
Hope this helps.
