It looks like the NVMe image is broken. do we get an ipdated Image ?
Yes, itâs missing a large part of the image. We still havenât seen anything in this thread about a new image coming.
In the mean time, several of us have had success using the SD card image to repair it.
- Boot from the SD card with the NVMe installed.
- dd if=/dev/mmcblk1p4 of=/dev/nvme0n1p4 bs=4M
- Remove the SD card and reboot
This worked well enough but a fixed image would be nice.
dd if=/dev/mmcblk1p4 of=/dev/nvme0n1p4 bs=4M status=progress to seeing progress of command.
but still not working, here the log:
U-Boot SPL 2021.10 (Mar 14 2024 - 19:21:18 +0800)
Trying to boot from SPI
OpenSBI v1.2
/ __ \ / | _ _ |
| | | | __ ___ _ __ | ( | |) || |
_/| ./ _|| ||/|/___|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : â
Platform PMU Device : â
Platform Suspend Device : â
Firmware Base : 0x40000000
Firmware Size : 392 KB
Firmware RW Offset : 0x40000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Mar 14 2024 - 19:21:18 +0800), Build: jenkins-github_visionfive2-23
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 8 GiB
Loading Environment from SPIFlash⌠SF: Detected gd25lq128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
Product full SN: VF7110A1-2250-########-00000###
PCB revision: 0xa1
Ethernet MAC0 address: ##:##:##:##:##:##
Ethernet MAC1 address: ##:##:##:##:##:##
In: serial
Out: serial
Err: serial
PCI: Failed autoconfig bar 10
starfive_pcie pcie@2C000000: Port link up.
Device 0: Vendor: 0x144d Rev: 5B2QGXA7 Prod: S5GXNX1W311984F
Type: Hard Disk
Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512)
⌠is now current device
Try booting from NVME0 âŚ
Failed to load âvf2_uEnv.txtâ
Info: input data size = 829 = 0x33D
Error: âboot2â not defined
Type: Hard Disk
Tring booting distro âŚ
Type: Hard Disk
419 bytes read in 3 ms (135.7 KiB/s)
1386 bytes read in 4 ms (337.9 KiB/s)
U-Boot menu
1: Debian GNU/Linux bookworm/sid 6.6.20-starfive
2: Debian GNU/Linux bookworm/sid 6.6.20-starfive (rescue target)
3: Debian GNU/Linux bookworm/sid 5.15.0-starfive
4: Debian GNU/Linux bookworm/sid 5.15.0-starfive (rescue target)
Enter choice: 1: Debian GNU/Linux bookworm/sid 6.6.20-starfive
Retrieving file: /initrd.img-6.6.20-starfive
** No partition table - nvme 0 **
Couldnât find partition nvme 0:3
Canât set block device
Skipping l0 for failure retrieving initrd
Skipping l0r for failure retrieving initrd
Retrieving file: /initrd.img-5.15.0-starfive
Skipping l1 for failure retrieving initrd
Skipping l1r for failure retrieving initrd
Type: Hard Disk
Error reading config file
same here. last working image 202311
I also had the problem with the image for nvme, it doesnât boot. Seeing the size of the file I ask the riscv team to check if an incorrect or corrupt file was uploaded by mistake.
The other images are 1GB and I donât understand why the one for nvme is 542MB
Greetings to the entire riscv team and thank you for everything you are doing @Michael.Zhu
exactly same issue here.
booting from SD image worked, but no network
dding SD to SSD ⌠no boot
Board revision
PCB revision: 0xa1
My bad
just upload the correct one
I was a little embarrassed to ask you to check, but Iâm happy it was just a problem of having uploaded the file wrong.
@Michael.Zhu when you have time try to correct the file extension to .bz2 because currently the extension is .img and can be confusing when uploading to nvme.
Thank you as always for your prompt willingness to resolve.
- Thanks for uploading a fresh image
Downloaded,
flashed NVMe, still problems, Debian is not loaded.
(re)flashing NVMe, with deactivated Antivirus. boot success
but onboard Network adapers do not connect (remain in status connecting) . any clue, how to fix ?
there seems te same problem with the 202403 image
You need to rename the file from img extension to img.bz2 and unzip the file. The size of the decompressed image file is approximately 4GB
yes, did fresh download.
boots now (flash seems to need disabled antivirus)
but no network
no network for me too
There are a few things you can tryďź
1.checking network under uboot.
2.updating spl and uboot in Flash.
3.eraseenv under uboot.
4.checking is there any network by flashing SD image and boot from SD card bootmode.
Updating SPL and U-Boot of Flash (rvspace.org)
Here is the method to update spl and uboot.
Have already updated both to latest version
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 6c:cf:39:00:20:79 brd ff:ff:ff:ff:ff:ff
3: eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 6c:cf:39:00:20:7a brd ff:ff:ff:ff:ff:ff
4: sit0@NONE: mtu 1480 qdisc noop state DOWN group default qlen 1000
link/sit 0.0.0.0 brd 0.0.0.0
How about the network under uboot? Could you please ping a IP under uboot?
no idea, how i can do.
image 202311 worked fine out of the box, since 202403 not. so network in principle should work, but i have no clue jet, i maybe miss a config setting ⌠but which. as you can see, it does not get an ip-address
DRAM: 8 GiB
Product full SN: VF7110A1-2250-D008E000-00000407
PCB revision: 0xa1
Ethernet MAC0 address: 6c:cf:39:00:20:79
Ethernet MAC1 address: 6c:cf:39:00:20:7a
In: serial
Out: serial
Err: serial
StarFive # ping 10.168.246.1
ethernet@16030000 Waiting for PHY auto negotiation to complete⌠done
Warning: gatewayip needed but not set
ping failed; host 10.168.246.1 is not alive
StarFive # ping 10.168.246.2
host 10.168.246.2 is alive
