I “flashed” the nvme with balenaetch (with NVME image)
this is the serial log of the initial boot phase
U-Boot SPL 2021.10 (Aug 31 2023 - 12:55:45 +0800)
Trying to boot from SPI
OpenSBI v1.2
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Firmware Base : 0x40000000
Firmware Size : 392 KB
Firmware RW Offset : 0x40000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Aug 31 2023 - 12:55:45 +0800), Build: jenkins-github_visionfive2-17
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 8 GiB
cdns3_bind: unsupported dr_mode
Product full SN: VF7110A1-2250-D008E000-00000926
PCB revision: 0xa1
Ethernet MAC0 address: 6c:cf:39:00:1a:bb
Ethernet MAC1 address: 6c:cf:39:00:1a:bc
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1 is current device
Try booting from MMC1 ...
Failed to load 'vf2_uEnv.txt'
## Error: "boot2" not defined
PCI: Failed autoconfig bar 10
Device 0: Vendor: 0x1e4b Rev: HS11795 Prod: P300EDBB23061700977
Type: Hard Disk
Capacity: 122104.3 MB = 119.2 GB (250069680 x 512)
... is now current device
Try booting from NVME0 ...
Type: Hard Disk
Tring booting distro ...
406 bytes read in 5 ms (79.1 KiB/s)
52677 bytes read in 9 ms (5.6 MiB/s)
52677 bytes written in 30 ms (1.7 MiB/s)
792 bytes read in 5 ms (154.3 KiB/s)
U-Boot menu
Enter choice: 1: Debian GNU/Linux bookworm/sid 5.15.0-starfive
Retrieving file: /initrd.img-5.15.0-starfive
9272042 bytes read in 409 ms (21.6 MiB/s)
Retrieving file: /vmlinuz-5.15.0-starfive
8588858 bytes read in 380 ms (21.6 MiB/s)
append: root=/dev/mmcblk1p4 rw console=tty0 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0
Uncompressing Kernel Image
Moving Image from 0x44000000 to 0x40200000, end=419b5000
Using Device Tree in place at 0000000048000000, end 000000004800fdc4
Starting kernel ...
NVME seems in working order
user@starfive:~$ lsblk
mtdblock0 31:0 0 256K 0 disk
mtdblock1 31:1 0 3M 0 disk
mtdblock2 31:2 0 1M 0 disk
mmcblk1 179:0 0 58.3G 0 disk
|-mmcblk1p1 179:1 0 2M 0 part
|-mmcblk1p2 179:2 0 4M 0 part
|-mmcblk1p3 179:3 0 100M 0 part
`-mmcblk1p4 179:4 0 58.1G 0 part /
nvme0n1 259:0 0 119.2G 0 disk
|-nvme0n1p1 259:1 0 2M 0 part
|-nvme0n1p2 259:2 0 4M 0 part
|-nvme0n1p3 259:3 0 100M 0 part
`-nvme0n1p4 259:4 0 3.8G 0 part
user@starfive:~$
