Issues with official Ubuntu 23.04 image and fixes for USB and v1.2a Ethernet
I’ve gone back and added those modules and checked against the script you mentioned but it still doesn’t want to work with me with NFTables. Using “update-alternatives” and setting iptables to iptables-legacy and ip6tables to ip6tables-legacy is the only way I’ve been successful getting Docker to run.
Hi, agreenbhm,
I just installed ubuntu on my VF2 and found myself in the similar shoes as you are: USB not working, one of the ether ports works, but not the other.
I really need to get USB working. It appears your link does not work anymore. Do you have a new place hosting the USB fix?
Thanks!
@diamond_wolf please see this thread for current links Daily Ubuntu Kernel Builds - Now With 100% More APT Repo!. I only just became able to edit posts on this forum so the OP of this thread was outdated (though I just updated it so others don’t run into the same issue you did).
I noticed that Ubuntu appears to have open for the beta; any reason I shouldn’t try do-release-upgrade -d? Is it likely to interfere with your kernel?
I’m just guessing, but it probably would be ok.
Hello! I get this error on a 1.2A board with ubuntu 23.04 and the 6.4 kernel.
Anyone knows if both ethernet ports are supported and which distro? I also have the 1.3B board with two-gigabit ports but haven’t tried it yet.
starfive-dwmac 16030000.ethernet: Failed to reset the dma
starfive-dwmac 16030000.ethernet end0: stmmac_hw_setup: DMA engine initialization failed
starfive-dwmac 16030000.ethernet end0: __stmmac_open: Hw setup failed
starfive-dwmac 16040000.ethernet end1: Register MEM_TYPE_PAGE_POOL RxQ-0
starfive-dwmac 16040000.ethernet end1: PHY [stmmac-1:00] driver [Generic PHY] (irq=POLL)
dwmac4: Master AXI performs fixed burst length
starfive-dwmac 16040000.ethernet end1: No Safety Features support found
starfive-dwmac 16040000.ethernet end1: IEEE 1588-2008 Advanced Timestamp supported
I’ve tried the 1.3B board and it seems both Gbit ports work out of the box but on the 1.2A only the 100Mb port works.
Where is /dev/mtd1? If I load the mtd modules in /lib/modules/6.2.0-19-generic/kernel/drivers/mtd I can get /dev/mtd0, /dev/mtd0ro, and mtdblock0 but not /dev/mtd1.
ubuntu@ubuntu:~$ cat /proc/mtd
dev: size erasesize name
mtd0: 00400000 00020000 “mtdram test device”
ubuntu@ubuntu:~$
Due to a clock issue, QSPI controller won’t work and fix patches are under review: [v1,0/3] Add initialization of clock for StarFive JH7110 SoC - Patchwork
Presumably this hasn’t been merged yet? I just tried the daily kernel build and still have no mtd devices.
root@ubuntu:~# cat /proc/mtd
root@ubuntu:~# ls /dev/mtd*
ls: cannot access ‘/dev/mtd*’: No such file or directory
root@ubuntu:~#
I have no idea why nobody else provided this before, but here’s the exact commands I used to bring the 1.2a DTB back to the Ubuntu Server image I used. Note: you’ll need to use the serial or HDMI port for this.
cd /boot
sudo mv dtb dtb.old
sudo mv dtb-6.11.0-8-generic dtb-6.11.0-8-generic.old
sudo ln -s /usr/lib/firmware/6.11.0-8-generic/device-tree/starfive/jh7110-starfive-visionfive-2-v1.2a.dtb dtb
sudo ln -s /usr/lib/firmware/6.11.0-8-generic/device-tree/starfive/jh7110-starfive-visionfive-2-v1.2a.dtb dtb-6.11.0-8-generic
