Mara, thanks a lot for fixing this so quickly.
I just tested the xfce build with kernel 6.6.97.
I changed the dtb to 1.2a in uEnv.txt and it boots up the desktop.
installation README.TXT
kernel 6.15.6
HDMI output not working
irradium-3.8-riscv64-core-visionfive_2-6.15.6-build-20250712.img.zst
irradium-3.8-riscv64-core-visionfive_2-6.15.6-build-20250712.img.zst.sha256
mara
My uboot continues to use StarFive and irradium starts normally.
Excuse me, does irradium have mirror sites in China? When I update irradium in China, the download speed is very slow.
I found mirrors, but they did not answer
Okay, thank you, Mara。
Perhaps you can tell us about those mirrors, and we will try in China to see if there is a response. We are on the Chinese network.
To install binary packages you need to use pkg-get
Now that I have Irradium working on my VF2, I installed chrony to automatically set the clock. I also followed the guide for fakeroot, but I changed the last step from create user to add user to group.
sudo usermod -m -G wheel,pkgmk -s /bin/bash user_name
@mara hi , mara ,
Will irradium support GRUB boot system in the future? Just like after the official release of Debian 13 Trixie.
Be sure to set the DIP switches correctly for your boot medium. Boot methods SD and eMMC directly from StarFive JH7110 CPU loader are deprecated and should not be used as they have been removed from vendor documentation and are incompatible to GUID Partition Table disk representation. Remaining valid boot methods are UART for recovery action and SPI NOR flash for U-Boot bootloader (which can then itself correctly boot from SD and eMMC).
https://wiki.debian.org/InstallingDebianOn/StarFive/VisionFiveV2
I don’t have any such intentions yet, but I’ll keep an eye on it.
I respect your choice.
performance testing on lichee pi 4a T-Head th1520 and banana pi f3 SpacemiT k1, mesa package compilation:
time prt-get update mesa
prt-get: updated successfully
real 65m2.670s
user 231m38.567s
sys 14m14.824s
real 48m32.365s
user 342m27.137s
sys 14m44.450s
visionfive 2 JH7110
real 69m52.519s
user 248m33.483s
sys 11m3.013s
StarPro64 EIC7700X
real 42m27.966s
user 154m0.664s
sys 8m11.515s
kernel 6.12.44
mirror 1, mirror 2, mirror 3, mirror 4, mirror 5
irradium-3.8-riscv64-core-visionfive_2-6.12.44-build-20250830.img.zst
irradium-3.8-riscv64-core-visionfive_2-6.12.44-build-20250830.img.zst.sha256
irradium-3.8-riscv64-xfce-visionfive_2-6.12.44-build-20250830.img.zst
irradium-3.8-riscv64-xfce-visionfive_2-6.12.44-build-20250830.img.zst.sha256
HI,mara. ![]()
irradium for vf2, Can I install the system from compiling the kernel like CRUX Linux?
yes
kernel 6.12.46
irradium-3.8-riscv64-core-visionfive_2-6.12.46-build-20250910.img.zst
irradium-3.8-riscv64-core-visionfive_2-6.12.46-build-20250910.img.zst.sha256
irradium-3.8-riscv64-xfce-visionfive_2-6.12.46-build-20250910.img.zst
irradium-3.8-riscv64-xfce-visionfive_2-6.12.46-build-20250910.img.zst.sha256
kernel 6.12.47
irradium-3.8-riscv64-core-visionfive_2-6.12.47-build-20250911.img.zst
irradium-3.8-riscv64-core-visionfive_2-6.12.47-build-20250911.img.zst.sha256
irradium-3.8-riscv64-xfce-visionfive_2-6.12.47-build-20250911.img.zst
irradium-3.8-riscv64-xfce-visionfive_2-6.12.47-build-20250911.img.zst.sha256
kernel 6.12.49
irradium-3.8-riscv64-core-visionfive_2-6.12.49-build-20250926.img.zst
irradium-3.8-riscv64-core-visionfive_2-6.12.49-build-20250926.img.zst.sha256
irradium-3.8-riscv64-xfce-visionfive_2-6.12.49-build-20250926.img.zst
irradium-3.8-riscv64-xfce-visionfive_2-6.12.49-build-20250926.img.zst.sha256
kernel 6.12.57
irradium-3.8-riscv64-core-visionfive_2-6.12.57-build-20251111.img.zst
irradium-3.8-riscv64-core-visionfive_2-6.12.57-build-20251111.img.zst.sha256
irradium-3.8-riscv64-xfce-visionfive_2-6.12.57-build-20251111.img.zst
irradium-3.8-riscv64-xfce-visionfive_2-6.12.57-build-20251111.img.zst.sha256
