Graphics show many glitches tho…other than that it seems to work.
added most firefox, libreoffice packages
ports -u
pkg-get -di firefox
pkg-get -di libreoffice
yes, so far such a driver
Good job getting that to run. Congratulations!
installation README.TXT
kernel 6.10.2
HDMI output works after loading X
irradium-3.7-riscv64-core-visionfive_2-6.10.2-build-20240801.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.10.2-build-20240801.img.zst.sha256
irradium-3.7-riscv64-xfce-visionfive_2-6.10.2-build-20240801.img.zst
irradium-3.7-riscv64-xfce-visionfive_2-6.10.2-build-20240801.img.zst.sha256
kernel 6.10.3
pcie driver updated v16 also updated HDMI/DC8200 v4, in the original there is no device tree.
irradium-3.7-riscv64-core-visionfive_2-6.10.3-build-20240804.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.10.3-build-20240804.img.zst.sha256
kernel 6.6.20
irradium-3.7-riscv64-core-visionfive_2-6.6.20-build-20240907.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.6.20-build-20240907.img.zst.sha256
irradium-3.7-riscv64-xfce-visionfive_2-6.6.20-build-20240907.img.zst
irradium-3.7-riscv64-xfce-visionfive_2-6.6.20-build-20240907.img.zst.sha256
kernel 6.12.1
updated HDMI/DC8200 v5, but initialization with errors
i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
irradium-3.7-riscv64-core-visionfive_2-6.12.1-build-20241125.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.12.1-build-20241125.img.zst.sha256
YES, No HDMI display, VF2 cannot start。
kernel 6.6.63
irradium-3.7-riscv64-core-visionfive_2-6.6.63-build-20241126.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.6.63-build-20241126.img.zst.sha256
irradium-3.7-riscv64-xfce-visionfive_2-6.6.63-build-20241126.img.zst
irradium-3.7-riscv64-xfce-visionfive_2-6.6.63-build-20241126.img.zst.sha256
kernel 6.6.68
irradium-3.7-riscv64-core-visionfive_2-6.6.68-build-20241227.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.6.68-build-20241227.img.zst.sha256
irradium-3.7-riscv64-xfce-visionfive_2-6.6.68-build-20241227.img.zst
irradium-3.7-riscv64-xfce-visionfive_2-6.6.68-build-20241227.img.zst.sha256
Thank you, it will synchronize during the day.
kernel 6.13.1
[ 0.117739] /soc/lcd-controller@29400000: Fixed dependency cycle(s) with /soc/hdmi@29590000
[ 0.117809] /soc/hdmi@29590000: Fixed dependency cycle(s) with /soc/lcd-controller@29400000
[ 0.124693] /soc/lcd-controller@29400000: Fixed dependency cycle(s) with /soc/hdmi@29590000
[ 0.124928] /soc/lcd-controller@29400000: Fixed dependency cycle(s) with /soc/hdmi@29590000
[ 0.124995] /soc/hdmi@29590000: Fixed dependency cycle(s) with /soc/lcd-controller@29400000
[ 0.126704] /soc/hdmi@29590000: Fixed dependency cycle(s) with /hdmi-con
[ 0.126773] /hdmi-con: Fixed dependency cycle(s) with /soc/hdmi@29590000
[ 2.042367] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 2.048093] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
[ 2.063850] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 2.069573] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
[ 2.080725] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 2.086486] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
[ 2.093590] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 2.099314] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
[ 2.466070] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 2.471749] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
[ 2.486563] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 2.492295] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
[ 2.541127] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 2.546940] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
[ 12.254207] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 12.259922] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
[ 12.475602] i2c i2c-7: of_i2c: modalias failure on /soc/hdmi@29590000/ports
[ 12.481346] i2c i2c-7: Failed to create I2C device for /soc/hdmi@29590000/ports
U-Boot SPL 2025.01-jh7110 (Feb 07 2025 - 20:55:10 +0200)
DDR version: dc2e84f0.
Trying to boot from MMC2
OpenSBI v1.6
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Name : StarFive VisionFive 2 v1.3B
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Platform CPPC Device : ---
Firmware Base : 0x40000000
Firmware Size : 373 KB
Firmware RW Offset : 0x40000
Firmware RW Size : 117 KB
Firmware Heap Offset : 0x50000
Firmware Heap Size : 53 KB (total), 3 KB (reserved), 13 KB (used), 36 KB (free)
Firmware Scratch Size : 4096 B (total), 440 B (used), 3656 B (free)
Runtime SBI Version : 2.0
Standard SBI Extensions : time,rfnc,ipi,base,hsm,srst,pmu,dbcn,legacy
Experimental SBI Extensions : fwft,dbtr,sse
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Region00 : 0x0000000010000000-0x0000000010000fff M: (I,R,W) S/U: (R,W)
Domain0 Region01 : 0x0000000002000000-0x000000000200ffff M: (I,R,W) S/U: ()
Domain0 Region02 : 0x0000000040040000-0x000000004005ffff M: (R,W) S/U: ()
Domain0 Region03 : 0x0000000040000000-0x000000004003ffff M: (R,X) S/U: ()
Domain0 Region04 : 0x000000000c000000-0x000000000fffffff M: (I,R,W) S/U: (R,W)
Domain0 Region05 : 0x0000000000000000-0xffffffffffffffff M: () S/U: (R,W,X)
Domain0 Next Arg1 : 0x0000000040400000
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART ISA Extensions : zihpm,sdtrig
Boot HART PMP Count : 8
Boot HART PMP Granularity : 12 bits
Boot HART PMP Address Bits : 34
Boot HART MHPM Info : 2 (0x00000018)
Boot HART Debug Triggers : 8 triggers
U-Boot 2025.01-jh7110 (Feb 07 2025 - 20:55:10 +0200)
CPU: sifive,u74-mc
Model: StarFive VisionFive 2 v1.3B
DRAM: 4 GiB
Core: 136 devices, 26 uclasses, devicetree: board
WDT: Not starting watchdog@13070000
MMC: mmc@16010000: 0, mmc@16020000: 1
Product full SN: VF7110B1-2310-D004E000-00001219
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:26:e3
Ethernet MAC1 address: 6c:cf:39:00:26:e4
starfive_7110_pcie pcie@2b000000: Starfive PCIe bus probed.
starfive_7110_pcie pcie@2c000000: Starfive PCIe bus probed.
In: serial@10000000
Out: serial@10000000
Err: serial@10000000
starting USB...
Bus xhci_pci: Register 5000420 NbrPorts 5
Starting the controller
USB XHCI 1.00
scanning bus xhci_pci for devices... 2 USB Device(s) found
Working FDT set to ff72aa10
** File not found ubootefi.var **
Failed to load EFI variables
** Unable to write file ubootefi.var **
Failed to persist EFI variables
** Booting bootflow '<NULL>' with efi_mgr
Loading Boot0000 'mmc 1' failed
EFI boot manager: Cannot load any image
Boot failed (err=-14)
** File not found /boot.bmp **
** Booting bootflow 'mmc@16020000.bootdev.part_3' with script
Boot script loaded from mmc 1:3
155 bytes read in 1 ms (151.4 KiB/s)
41171 bytes read in 8 ms (4.9 MiB/s)
26292136 bytes read in 1119 ms (22.4 MiB/s)
Working FDT set to 46000000
Failed to load '/dtb/starfive/overlay/starfive-fixup.scr'
6224553 bytes read in 380 ms (15.6 MiB/s)
## Loading init Ramdisk from Legacy Image at 46100000 ...
Image Name: uInitrd
Image Type: RISC-V Linux RAMDisk Image (gzip compressed)
Data Size: 6224489 Bytes = 5.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 46000000
Booting using the fdt blob at 0x46000000
Loading Ramdisk to fe105000, end fe6f4a69 ... OK
Loading Device Tree to 00000000fe092000, end 00000000fe104fff ... OK
Working FDT set to fe092000
Starting kernel ...
CCACHE: DataError @ 0x00000000.080243F8
CCACHE: DataFail @ 0x00000000.080243DC
debugfs: Directory '16008000.dma-controller' with parent 'dmaengine' already present!
udevd[114]: failed to execute '/usr/sbin/nfsrahead' '/usr/sbin/nfsrahead 179:0': No such file or directory
udevd[164]: specified group 'netdev' unknown
irradium (visionfive-2) (ttyS0)
visionfive-2 login:
irradium-3.7-riscv64-core-visionfive_2-6.13.1-build-20250208.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.13.1-build-20250208.img.zst.sha256
HI, mara.
I tested this system. HDMI no display, The green breathing light of VF2 is flashing. Several indicator lights on the keyboard can be turned on and off normally.
kernel 6.6.75
irradium-3.7-riscv64-core-visionfive_2-6.6.75-build-20250208.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.6.75-build-20250208.img.zst.sha256
irradium-3.7-riscv64-xfce-visionfive_2-6.6.75-build-20250208.img.zst
irradium-3.7-riscv64-xfce-visionfive_2-6.6.75-build-20250208.img.zst.sha256
kernel 6.12.21
irradium-3.7-riscv64-core-visionfive_2-6.12.21-build-20250329.img.zst
irradium-3.7-riscv64-core-visionfive_2-6.12.21-build-20250329.img.zst.sha256
irradium-3.7-riscv64-xfce-visionfive_2-6.12.21-build-20250329.img.zst
irradium-3.7-riscv64-xfce-visionfive_2-6.12.21-build-20250329.img.zst.sha256
