Now it’s officially supported, just installed it today.
Does this have HDMI output? Are there GPU and VPU drivers?
Limitations (the usual)
The on-board GPU is not supported
PCIe support is incomplete: an NVMe drive can be used, but Wi-Fi cards and external GPUs don’t work
So, the StarFive customised Ubuntu is still more user-friendly than the official Ubuntu system. ![]()
I wish I could find something fully functional for this miserable board.
debian202510, ubuntu2404-202510, Arch Linux Image for VisionFive 2 lite, VisionFive 2 Lite - irradium, All of these can support vf2l very well; they all have HDMI, or support GPU, or both GPU and VPU are supported.
How about Batocera?
https://updates.batocera.org/visionfive2/stable/last/batocera-riscv-visionfive2-41-20241218.img.gz
This 2024 version of Batocera might not fully support VF2L. At that time, VF2L hadn’t been produced yet, and some hardware is incompatible. USB WIFI…
I can only speak to my use case but I’m using it as a headless home lab server for VPN (Wireguard) and DNS (Pi-hole/BIND) with containers, and it’s been running smoothly. I’ve also added a PoE hat, and it’s booting from an NVMe drive.
batocera 2024 won’t properly support the StarFive VisionFive 2 Lite — it was built before the Lite variant existed, so the device tree doesn’t match. that’s why USB WiFi and some peripherals act flaky.
if you want stable Ubuntu on VF2L, use a recent 24.04 (2025 build) that explicitly mentions VF2L support and ships with the correct dtb + updated u-boot. kernel 6.6+ is basically the safe zone.
older images = wrong dtb = weird hardware issues. simple as that.
