How to install Debian directly onto the SSD?
As topic, I am looking for help or guide regarding a direct installation of Debian.
I have tried:
Recovering the Bootloader: Recovering the Bootloader : that is to update the firmware;
Updated to U-Boot following that > : StarFive VisionFive2 — Das U-Boot unknown version documentation : I was not able to locate the latest U-Boot; I downloaded the debian file (u-boot-starfive_2025.01-3+deb13u1_riscv64.deb), break it open, and then upload via serial, it was successful.
I also followed the Debian wiki : InstallingDebianOn StarFive VisionFiveV2 : That was where I got the prompt to update U-Boot.
I do all the update via the serial port connection. I was not able to complete two of the steps from the Debian wiki.
  1. Prepare .dtb file (e.g. for variant Pine64 Star64) from Debian daily-images. It ended in error. I can upload the file from serial, but won’t install.
    https://d-i.debian.org/daily-images/riscv64/daily/device-tree/starfive/jh7110-pine64-star64.dtb
  2. uploading the mini.efi but cannot install or load. I believe it was error and ended.
https://deb.debian.org/debian/dists/trixie/main/installer-riscv64/current/images/netboot/mini.efi
I urgently need some helps. Please if someone has any clues, please share! Thank you!
The debian wiki is correct. I have installed debian13 2-3 times according to the wiki within a year, and all of them were successful.
Which Version of Debian are you trying to install?
I successfully installed trixie long ago, upgraded to forky, and since some kernel releases, it no longer boots with the new kernel, but I haven’t tried to figure out the reason yet. Last working kernel for me is 7.0.13+deb14-riscv64
To follow up on my own post, Debian seems to work again with kernel 7.2.12+deb14-riscv64 and boots fine on my VisionFive V2 from the following SSD:
KXG50ZNV256G TOSHIBA (Toshiba Corporation XG5)
