Hi @andrew and @bing ! Thank you for your help! I guess you have better things to do rather to help a newbie take his first gentoo/vf2 steps
FEATURES="-sandbox -usersandbox" emerge media-video/vf2vpudev
Results in the same errors:
>>> Compiling source in /var/tmp/portage/media-video/vf2vpudev-5.11.3/work/soft_3rdpart-JH7110_VF2_6.1_v5.11.3 ...
 * Preparing jpu module
make -j4 HOSTCC=riscv64-unknown-linux-gnu-gcc 'LDFLAGS=-m elf64lriscv' KERNELDIR=/usr/src/linux clean default
make	-C /usr/src/linux	M=/var/tmp/portage/media-video/vf2vpudev-5.11.3/work/soft_3rdpart-JH7110_VF2_6.1_v5.11.3/codaj12/jdi/linux/driver LDDINCDIR=/var/tmp/portage/media-video/vf2vpudev-5.11.3/work/soft_3rdpart-JH7110_VF2_6.1_v5.11.3/codaj12/jdi/linux/driver/../include modules
rm -rf *.o *~ core .depend .*.cmd *.ko *.mod.c .tmp_versions
cc1: fatal error: opening output file arch/riscv/kernel/vdso/vdso.lds: Permission denied
compilation terminated.
The info from
emerge --info '=media-video/vf2vpudev-5.11.3::bingch'
shows
Portage 3.0.64 (python 3.12.3-final-0, default/linux/riscv/23.0/rv64/lp64d/desktop/plasma/systemd, gcc-14, glibc-2.39-r7, 5.15.0-starfive riscv64)
                         System Settings
System uname: Linux-5.15.0-starfive-riscv64-with-glibc2.39
KiB Mem:     8118100 total,   1580960 free
KiB Swap:    8388604 total,   8388604 free
Timestamp of repository gentoo: Sun, 02 Jun 2024 08:00:00 +0000
Head commit of repository gentoo: 9f3ccf216b8999d9b48b2e7e68d70476e65fdb25
Head commit of repository bingch: 8ae251ece2c0e2f4ffb641135e9ef84faf7697ba
sh bash 5.2_p26-r3
ld GNU ld (Gentoo 2.42 p3) 2.42.0
app-misc/pax-utils:        1.3.7::gentoo
app-shells/bash:           5.2_p26-r3::gentoo
dev-build/autoconf:        2.72-r1::gentoo
dev-build/automake:        1.16.5-r2::gentoo
dev-build/cmake:           3.29.3::gentoo
dev-build/libtool:         2.4.7-r4::gentoo
dev-build/make:            4.4.1-r1::gentoo
dev-build/meson:           1.4.1::gentoo
dev-lang/perl:             5.38.2-r6::gentoo
dev-lang/python:           3.11.9-r1::gentoo, 3.12.3-r1::gentoo, 3.13.0_beta1_p3::gentoo
dev-lang/rust-bin:         1.78.0::gentoo
sys-apps/baselayout:       2.15::gentoo
sys-apps/sandbox:          2.38::gentoo
sys-apps/systemd:          255.7::gentoo
sys-devel/binutils:        2.42-r1::gentoo
sys-devel/binutils-config: 5.5::gentoo
sys-devel/gcc:             14.1.1_p20240518::gentoo
sys-devel/gcc-config:      2.11::gentoo
sys-devel/llvm:            17.0.6::gentoo, 18.1.6::gentoo
sys-kernel/linux-headers:  6.9::gentoo (virtual/os-headers)
sys-libs/glibc:            2.39-r7::gentoo
Repositories:
gentoo
    sync-type: rsync
    sync-uri: rsync://rsync.gentoo.org/gentoo-portage
    priority: -1000
    volatile: False
    sync-rsync-extra-opts:
    sync-rsync-verify-jobs: 1
    sync-rsync-verify-metamanifest: yes
    sync-rsync-verify-max-age: 24
bingch
    sync-type: git
    sync-uri: https://gitlab.com/bingch/gentoo-overlay.git
    masters: gentoo
    volatile: True
ACCEPT_KEYWORDS="riscv ~riscv"
ACCEPT_LICENSE="@FREE"
CBUILD="riscv64-unknown-linux-gnu"
CFLAGS="-march=rv64imafdc_zicsr_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -O2 -pipe"
CHOST="riscv64-unknown-linux-gnu"
CONFIG_PROTECT="/etc /usr/share/config /usr/share/gnupg/qualified.txt"
CONFIG_PROTECT_MASK="/etc/ca-certificates.conf /etc/dconf /etc/env.d /etc/fonts/fonts.conf /etc/gconf /etc/gentoo-release /etc/sandbox.d"
CXXFLAGS="-march=rv64imafdc_zicsr_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -O2 -pipe"
DISTDIR="/var/cache/distfiles"
ENV_UNSET="CARGO_HOME DBUS_SESSION_BUS_ADDRESS DISPLAY GDK_PIXBUF_MODULE_FILE GOBIN GOPATH PERL5LIB PERL5OPT PERLPREFIX PERL_CORE PERL_MB_OPT PERL_MM_OPT XAUTHORITY XDG_CACHE_HOME XDG_CONFIG_HOME XDG_DATA_HOME XDG_RUNTIME_DIR XDG_STATE_HOME"
FCFLAGS="-march=rv64imafdc_zicsr_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -O2 -pipe"
FEATURES="assume-digests binpkg-docompress binpkg-dostrip binpkg-logs binpkg-multi-instance buildpkg-live config-protect-if-modified distlocks ebuild-locks fixlafiles merge-sync merge-wait multilib-strict news parallel-fetch pkgdir-index-trusted preserve-libs protect-owned qa-unresolved-soname-deps sandbox sfperms strict unknown-features-warn unmerge-logs unmerge-orphans userfetch userpriv usersandbox usersync xattr"
FFLAGS="-march=rv64imafdc_zicsr_zba_zbb -mcpu=sifive-u74 -mtune=sifive-7-series -O2 -pipe"
GENTOO_MIRRORS="http://distfiles.gentoo.org"
LANG="C.UTF8"
LC_ALL="C"
LDFLAGS="-Wl,-O1 -Wl,--as-needed"
LEX="flex"
PKGDIR="/var/cache/binpkgs"
PORTAGE_CONFIGROOT="/"
PORTAGE_RSYNC_OPTS="--recursive --links --safe-links --perms --times --omit-dir-times --compress --force --whole-file --delete --stats --human-readable --timeout=180 --exclude=/distfiles --exclude=/local --exclude=/packages --exclude=/.git"
PORTAGE_TMPDIR="/var/tmp"
SHELL="/bin/bash"
USE="X a52 aac acl acpi activities alsa bluetooth branding bzip2 cairo cdda cdr crypt cups dbus declarative dri dts dvd dvdr encode exif flac gdbm gif gpm gtk gui iconv icu ipv6 jpeg kde kwallet lcms libnotify mad mng mp3 mp4 mpeg ncurses networkmanager nls ogg opengl openmp pam pango pcre pdf pipewire plasma png policykit ppds pulseaudio qml qt5 readline riscv screencast sdl seccomp semantic-desktop sound spell ssl startup-notification svg systemd test-rust tiff truetype udev udisks unicode upower usb vorbis vulkan wayland widgets wxwidgets x264 xattr xcb xft xml xv xvid zlib" ADA_TARGET="gcc_12" APACHE2_MODULES="authn_core authz_core socache_shmcb unixd actions alias auth_basic authn_anon authn_dbm authn_file authz_dbm authz_groupfile authz_host authz_owner authz_user autoindex cache cgi cgid dav dav_fs dav_lock deflate dir env expires ext_filter file_cache filter headers include info log_config logio mime mime_magic negotiation rewrite setenvif speling status unique_id userdir usertrack vhost_alias" CALLIGRA_FEATURES="karbon sheets words" COLLECTD_PLUGINS="df interface irq load memory rrdtool swap syslog" ELIBC="glibc" GPSD_PROTOCOLS="ashtech aivdm earthmate evermore fv18 garmin garmintxt gpsclock greis isync itrax mtk3301 ntrip navcom oceanserver oncore rtcm104v2 rtcm104v3 sirf skytraq superstar2 tsip tripmate tnt ublox" INPUT_DEVICES="libinput" KERNEL="linux" LCD_DEVICES="bayrad cfontz glk hd44780 lb216 lcdm001 mtxorb text" LUA_SINGLE_TARGET="lua5-1" LUA_TARGETS="lua5-1" OFFICE_IMPLEMENTATION="libreoffice" PHP_TARGETS="php8-2" POSTGRES_TARGETS="postgres15" PYTHON_SINGLE_TARGET="python3_12" PYTHON_TARGETS="python3_12" RUBY_TARGETS="ruby31 ruby32" VIDEO_CARDS="fbdev" XTABLES_ADDONS="quota2 psd pknock lscan length2 ipv4options ipp2p iface geoip fuzzy condition tarpit sysrq proto logmark ipmark dhcpmac delude chaos account"
Unset:  ADDR2LINE, AR, ARFLAGS, AS, ASFLAGS, CC, CCLD, CONFIG_SHELL, CPP, CPPFLAGS, CTARGET, CXX, CXXFILT, ELFEDIT, EMERGE_DEFAULT_OPTS, EXTRA_ECONF, F77FLAGS, FC, GCOV, GPROF, INSTALL_MASK, LD, LFLAGS, LIBTOOL, LINGUAS, MAKE, MAKEFLAGS, MAKEOPTS, NM, OBJCOPY, OBJDUMP, PORTAGE_BINHOST, PORTAGE_BUNZIP2_COMMAND, PORTAGE_COMPRESS, PORTAGE_COMPRESS_FLAGS, PORTAGE_RSYNC_EXTRA_OPTS, PYTHONPATH, RANLIB, READELF, RUSTFLAGS, SIZE, STRINGS, STRIP, YACC, YFLAGS
Also I’m not able to compile the kernel from @bing repo. When I try to make the kernel (/usr/src/linux-JH7110_VF2_6.6_v5.12.0) I get
AR      drivers/gpu/drm/img/built-in.a
make[7]: *** .NOTINTERMEDIATE and .SECONDARY are mutually exclusive.  Stop.
make[6]: *** [scripts/Makefile.build:480: drivers/gpu/drm/img/img-rogue] Error 2
make[5]: *** [scripts/Makefile.build:480: drivers/gpu/drm/img] Error 2
make[4]: *** [scripts/Makefile.build:480: drivers/gpu/drm] Error 2
make[3]: *** [scripts/Makefile.build:480: drivers/gpu] Error 2
make[3]: *** Waiting for unfinished jobs....
Seems to me this problem?
https://lists.yoctoproject.org/g/meta-ti/message/17220
After all I’m currently in doubt if the VF2 is the appropriate board to get started with Gentoo as it is quite hard to find a complete documentation
