Experimental Gentoo Image
After copying the GPU files to my Gentoo install and installing opencl and pyopencl I ran a python benchmark below to see the difference in speed between the CPU and GPU
# example provided by Roger Pau Monn'e
import pyopencl as cl
import numpy
import numpy.linalg as la
import datetime
from time import time
a = numpy.random.rand(1000).astype(numpy.float32)
b = numpy.random.rand(1000).astype(numpy.float32)
c_result = numpy.empty_like(a)
# Speed in normal CPU usage
time1 = time()
for i in range(1000):
        for j in range(1000):
                c_result[i] = a[i] + b[i]
                c_result[i] = c_result[i] * (a[i] + b[i])
                c_result[i] = c_result[i] * (a[i] / 2.0)
time2 = time()
print ("Execution time of test without OpenCL: ", time2 - time1, "s")
for platform in cl.get_platforms():
    for device in platform.get_devices():
        print ("===============================================================")
        print ("Platform name:", platform.name)
        print ("Platform profile:", platform.profile)
        print ("Platform vendor:", platform.vendor)
        print ("Platform version:", platform.version)
        print ("---------------------------------------------------------------")
        print ("Device name:", device.name)
        print ("Device type:", cl.device_type.to_string(device.type))
        print ("Device memory: ", device.global_mem_size//1024//1024, 'MB')
        print ("Device max clock speed:", device.max_clock_frequency, 'MHz')
        print ("Device compute units:", device.max_compute_units)
        # Simnple speed test
        ctx = cl.Context([device])
        queue = cl.CommandQueue(ctx,
                properties=cl.command_queue_properties.PROFILING_ENABLE)
        mf = cl.mem_flags
        a_buf = cl.Buffer(ctx, mf.READ_ONLY | mf.COPY_HOST_PTR, hostbuf=a)
        b_buf = cl.Buffer(ctx, mf.READ_ONLY | mf.COPY_HOST_PTR, hostbuf=b)
        dest_buf = cl.Buffer(ctx, mf.WRITE_ONLY, b.nbytes)
        prg = cl.Program(ctx, """
            __kernel void sum(__global const float *a,
            __global const float *b, __global float *c)
                        int loop;
                        int gid = get_global_id(0);
                        for(loop=0; loop<1000;loop++)
                                c[gid] = a[gid] + b[gid];
                                c[gid] = c[gid] * (a[gid] + b[gid]);
                                c[gid] = c[gid] * (a[gid] / 2.0);
                """).build()
        exec_evt = prg.sum(queue, a.shape, None, a_buf, b_buf, dest_buf)
        exec_evt.wait()
        elapsed = 1e-9*(exec_evt.profile.end - exec_evt.profile.start)
        print ("Execution time of test: %g s" % elapsed)
        c = numpy.empty_like(a)
        cl._enqueue_read_buffer(queue, dest_buf, c).wait()
        error = 0
                if c[i] != c_result[i]:
                        error = 1
        if error:
                print ("Results doesn't match!!")
        else:
                print ("Results OK")
Here is the result
StarFive ~ # python test.py
Execution time of test without OpenCL:  34.012295722961426 s
Platform name: PowerVR
Platform profile: EMBEDDED_PROFILE
Platform vendor: Imagination Technologies
Platform version: OpenCL 3.0
Device name: PowerVR B-Series BXE-4-32
Device type: ALL | GPU
Device memory:  7927 MB
Device max clock speed: 594 MHz
Device compute units: 1
Execution time of test: 0.014952 s
Results OK
In case someone want to use GUI with gentoo on StarFive 2, I created gentoo overlay for building mesa-21.3.9 with img-gpu-powervr-bin-1.17.6210866 in bing c / gentoo-overlay Ā· GitLab
@bing Thank you.
NOTE: You may want to review the directories you install to.
EG
src_install() {
cd ${S}/target/usr/lib
insinto /usr/lib
doins *
On my system they are installed in /usr/lib64
cd ${S}/target/etc/vulkan/icd.d
insinto /usr/share/vulkan/icd.d
newins icdconf.json pvr_icd.json
On my system they are installed in /etc/vulkan/icd.d
yeah I think /usr/lib64 is the default path, I just use the ddk’s path
I prefer to put icd file in /usr/share so update won’t overwrite user’s custom conf
We should stick to the Gentoo Standards or it may cause problems later down the road with mergeusr and other changes.
See https://projects.gentoo.org/qa/policy-guide/filesystem.html
good point, I’ve updated ebuild for img-gpu-powervr-bin to use /usr/lib64
Here are the results from the clpeak benchmark running under Gentoo on my VisionFive 2
The Source code is located here GitHub - krrishnarraj/clpeak: A tool which profiles OpenCL devices to find their peak capacities
Platform: PowerVR
  Device: PowerVR B-Series BXE-4-32
    Driver version  : 1.17@6210866 (Linux unknown)
    Compute units   : 1
    Clock frequency : 594 MHz
    Global memory bandwidth (GBPS)
      float   : 1.29
      float2  : 2.34
      float4  : 7.01
      float8  : 3.02
      float16 : 4.69
    Single-precision compute (GFLOPS)
      float   : 8.92
      float2  : 17.53
      float4  : 17.08
      float8  : 10.61
      float16 : 12.29
    Half-precision compute (GFLOPS)
      half   : 8.43
      half2  : 17.52
      half4  : 17.07
      half8  : 10.59
      half16 : 12.29
    No double precision support! Skipped
    Integer compute (GIOPS)
      int   : 8.90
      int2  : 8.93
      int4  : 8.99
      int8  : 9.27
      int16 : 9.19
    Integer compute Fast 24bit (GIOPS)
      int   : 8.90
      int2  : 8.93
      int4  : 8.99
      int8  : 9.27
      int16 : 9.19
      int   : 8.90
      int2  : 8.93
      int4  : 8.99
      int8  : 9.27
      int16 : 9.19
    Transfer bandwidth (GBPS)
      enqueueWriteBuffer              : 0.52
      enqueueReadBuffer               : 0.13
      enqueueWriteBuffer non-blocking : 0.52
      enqueueReadBuffer non-blocking  : 0.13
      enqueueMapBuffer(for read)      : 4977.81
        memcpy from mapped ptr        : 0.13
      enqueueUnmap(after write)       : 14166.56
        memcpy to mapped ptr          : 0.51
    Kernel launch latency : 71.72 us
Platform: Clover
clCreateContextFromType (-1)
If you want to try one of the latest version of Chromium on your VisionFive 2 running Gentoo I have created a Pull Request on the riscv Gentoo Overlay. It is for www-client/chromium: 123.0.6312.58 and takes 3-4 days to emerge.
I have it running and it seems faster than Firefox on my VisionFive 2.
If it works for you please comment on the PR and let them know that you have successfully emerged and it.
My Pull request has been merged and is now available on the riscv Gentoo Overlay.
Hi Andrew!
Thanks for sharing your work with us! But whenever I try to download the file it is corrupted. The size is 6203585782 bytes. Is this correct? I’m downloading with Ubuntu and Brave browser.
Cheers,
Martin
Are you using the latest link in the thread?
That will give you this file that needs to be extracted.
-rw-rw-r-- 1 andrew andrew 3000602281 May 25 17:36 gentoo.img.bz2
@martin.wozenilek
The Extracted file looks like this
-rw-rw-r-- 1 andrew andrew 6442450944 May 25 17:36 gentoo.img
So the size you have is incorrect.
Let me know if you have any more questions.
See My Post on March 12 2023 for more details on this image.
Hi Andrew! The updated link and image works fine. Some things I’ve to change after initial boot (please let me know if this is completely stupid as I’m totally new to gentoo):
  • after selecting profile ā€œ8ā€ which is ā€œdefault/linux/riscv/20.0/rv64gc/lp64d/desktop/plasma/systemd/merged-usrā€ I’ve to execute merge-usr. To install ā€œmerge-usrā€ I’ve to copy the relevant bin files from /bin to /usr/bin before.
  • I’ve made a ā€œemerge --update --newuse --deep --with-bdeps=y @worldā€. Which worked for most of the packages. But I needed to add a swap space, otherwise the cc runs out of memory.
After all your image helped me a lot to get startet with gentoo and I already like it a lot on the VisionFive2! :smile:
Hi Martin, I am glad to hear that you were able to start your journey with Gentoo.
You can find some riscv specific ebuilds here GitHub - gentoo/riscv: [MIRROR] gentoo riscv overlay
and some more here including specific ones for the VisionFive2 bing c / gentoo-overlay Ā· GitLab
If you run into Gentoo specific bugs file a report here https://bugs.gentoo.org/
Here is a link to installing Gentoo from scratch on the VisionFive2 StarFive VisionFive 2 - Gentoo wiki However you already have Gentoo installed :slight_smile:
Feel free to ask questions here or on the Gentoo forums.
For a longer list of Gentoo Overlays look at https://overlays.gentoo.org/
FYI You may want to Update your profiles to the 23 branch.
https://wiki.gentoo.org/wiki/Profile_(Portage)
https://wiki.gentoo.org/wiki/Project:Toolchain/23.0_update_table
Fantastic! :smiley: Started this process two hours ago … is this life a simulation? :smiley:
Have you a step by step guide !!! I try the gentoo image but it’s not working…
boot_log.txt (33.7 KB)
@ioasiodf The last image I posted should bootup fine unless the image or SDCARD is corrupted. Have you tried to download it again and use a different SDCARD?
Have you tried the standard debian image to see if that works?
The standard debian image is working fine. 202405 was installed before in the micro sd card. I’ll try to download again the gentoo image
