I downloaded starfive-jh7110-202302-eMMC-minimal-desktop.img.bz2 as described and linked here:
Unfortunately, it seems that my new eMMC died and my eMMC to Micro-SD adapter got lost before I could test the current image. But over the course of today, two eMMC should arrive, as well as an eMMC to Micro-SD adapter and a USB 3.1 to eMMC adapter. I have to work a night shift tonight and will probably not be able to report until tomorrow morning.
UPS was here 40 minutes ago and unfortunately I donât have good results to show. starfive-jh7110-202302-eMMC-minimal-desktop.img.bz2 was quickly written using USB to eMMC adapter. eMMC inserted into VF2 v1.3B, boot mode set to eMMC, my headless terminal (Raspberry Zero W with USB to UART adapter) started, logged in and Minicom started, then VF2 switched on. Red LED comes on, green LED doesnât even blink and not a single character arrives in Minicom!
VF2 switched off, boot mode set to SDIO and VF2 switched on again. System starts normally, so I start tightvncserver so that I can comfortably start gparted on the headless VF2. eMMC is recognised and expanding the / partition happens without problems. VF2 switched off, boot mode set to eMMC, green LED does not flash again, but at least something arrives in the Minicom, five lines are written with each new power on.
Ăżdwmci_d: DATA ERROR!
dwmci_s: Timeout.
BOOT fail,Error is 0xffffffff
dwmci_s: Response Timeout.
Tomorrow, after the night shift, I will first do a firmware upgrade of the QSPI flash to v2.10.4 to try to boot the eMMC in QSPI flash boot mode and then put the VF2 v1.3B aside and try my VF2 v1.2A with an eMMC instead.
Let me just introduce a little bit about how I do it.
Switch boot mode to SDIO, then power up and boot it from TF card;
Transfer eMMC image into system (either over ethernet or USB etc.) ;
Use dd command to flash eMMC image into eMMC(mmcblk0), such as dd if=starfive-jh7110-202302-eMMC-minimal-desktop.img of=/dev/mmcblk0 bs=4M status=progress
Input sync command and power down;
Switch boot mode to eMMC mode and power up;
Note:
Please make sure you press&hold the reset button for more than 3 seconds if you need reset the system.
I have repeated all the steps again using your method. Unfortunately, I can only very rarely boot an eMMC on my Kickstarter Early Bird - 4GB VF2 v1.3B after many resets.
I just remembered, at first the boot from eMMC worked, I was able to install openssh-server with keyboard and screen, change the passwords of root and user and after a reboot I was able to install headless my favourite editor, setup using apt-cacher-ng as proxy, as well as set up my bash environment for my liking. later I take a break shut down the system and hours later could only boot it with difficulty sometimes.
On my 8GB VF2 v1.2A from Waveshare I then carried out all the steps with a second 64GB eMMC and so far everything works here.
I will test the two ânon-functioningâ eMMC 32GB and 64GB with the VF2 v1.2A later.
I get these bus speed messages on the debug terminal very rarely with the VF2 v1.2A and very often with the VF2 v1.3B.
[ 12.935725] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ )
[ 13.192614] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 100000000Hz, actual 990000)
[ 13.768426] starfive-eth-plat 16030000.ethernet end0: Link is Up - 1Gbps/Full - flow control rx/x
Debian GNU/Linux
Debian GNU/Linux bookworm/sid vfive2-8 hvc0
vfive2-8 login: bookworm/sid vfive2-8 ttyS0
vfive2-8 login: [ 34.486172] mipi_0p9: disabling
[ 39.445859] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ )
[ 39.712463] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 100000000Hz, actual 990000)
I use the same PD power supply on both boards and have also installed the same cooler/fan combination.
Most often, I get this message when I connect the power supply or do a reset:
I must correct myself, in the meantime I can do a cold start as often as I want, no other message comes up.
For clarity, I have attached my boot mode settings as a photo.
By the way, after setting up the eMMC using your method, I did not change anything on my 4GB VF2 v1.3B except the boot mode. Now I will boot from SD again.
For clarification, I have attached my, now changed, boot mode settings again as a photo.
Now the log, from the boot from the SD, while the eMMC is still inserted.
It gave me no peace and I tried to boot from eMMC a few more times, this time again with success. Here is the boot log:
After a few minutes, these messages were recorded.
vfive2-4 login: [ 34.484858] mipi_0p9: disabling
[ 40.054464] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ div = 248)
[ 40.297621] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 100000000Hz, actual 99000000HZ div = 1)
[ 52.405321] mmc0: cache flush error -110
[ 52.624411] mmc_host mmc0: Bus speed (slot 0) = 198000000Hz (slot req 400000Hz, actual 399193HZ div = 248)
[ 54.136729] mmc0: tried to HW reset card, got error -110
[ 54.142093] mmcblk0: recovery failed!
[ 54.145897] blk_update_request: I/O error, dev mmcblk0, sector 2321376 op 0x1:(WRITE) flags 0x800 phys_seg 3 prio class 0
[ 54.157129] Aborting journal on device mmcblk0p4-8.
[ 54.164594] EXT4-fs error (device mmcblk0p4): ext4_journal_check_start:83: comm systemd-journal: Detected aborted journal
[ 54.172669] mmcblk0: recovery failed!
[ 54.179324] blk_update_request: I/O error, dev mmcblk0, sector 2318336 op 0x1:(WRITE) flags 0x20800 phys_seg 1 prio class 0
[ 54.190472] Buffer I/O error on dev mmcblk0p4, logical block 262144, lost sync page write
[ 54.198667] JBD2: Error -5 detected when updating journal superblock for mmcblk0p4-8.
[ 54.216911] mmcblk0: recovery failed!
[ 54.220578] blk_update_request: I/O error, dev mmcblk0, sector 221184 op 0x1:(WRITE) flags 0x23800 phys_seg 1 prio class 0
[ 54.231648] Buffer I/O error on dev mmcblk0p4, logical block 0, lost sync page write
[ 54.239531] EXT4-fs (mmcblk0p4): I/O error while writing superblock
[ 54.245851] EXT4-fs (mmcblk0p4): Remounting filesystem read-only
[ 58.416492] mmcblk0: recovery failed!
[ 58.420267] blk_update_request: I/O error, dev mmcblk0, sector 221192 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 58.431605] Buffer I/O error on dev mmcblk0p4, logical block 1, lost async page write
[ 58.449277] mmcblk0: recovery failed!
[ 58.452983] blk_update_request: I/O error, dev mmcblk0, sector 223320 op 0x1:(WRITE) flags 0x103000 phys_seg 2 prio class 0
[ 58.464138] Buffer I/O error on dev mmcblk0p4, logical block 267, lost async page write
[ 58.472162] Buffer I/O error on dev mmcblk0p4, logical block 268, lost async page write
[ 58.489946] mmcblk0: recovery failed!
[ 58.493641] blk_update_request: I/O error, dev mmcblk0, sector 223352 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 58.504798] Buffer I/O error on dev mmcblk0p4, logical block 271, lost async page write
[ 58.522432] mmcblk0: recovery failed!
[ 58.526143] blk_update_request: I/O error, dev mmcblk0, sector 223488 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 58.537298] Buffer I/O error on dev mmcblk0p4, logical block 288, lost async page write
[ 58.555078] mmcblk0: recovery failed!
[ 58.558760] blk_update_request: I/O error, dev mmcblk0, sector 223552 op 0x1:(WRITE) flags 0x103000 phys_seg 4 prio class 0
[ 58.569920] Buffer I/O error on dev mmcblk0p4, logical block 296, lost async page write
[ 58.577943] Buffer I/O error on dev mmcblk0p4, logical block 297, lost async page write
[ 58.585966] Buffer I/O error on dev mmcblk0p4, logical block 298, lost async page write
[ 58.603610] mmcblk0: recovery failed!
[ 58.607300] blk_update_request: I/O error, dev mmcblk0, sector 223608 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 58.628226] mmcblk0: recovery failed!
[ 58.631932] blk_update_request: I/O error, dev mmcblk0, sector 223760 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 58.652853] mmcblk0: recovery failed!
[ 58.667104] mmcblk0: recovery failed!
[ 58.681367] mmcblk0: recovery failed!
[ 58.695599] mmcblk0: recovery failed!
[ 58.709935] mmcblk0: recovery failed!
[ 58.724180] mmcblk0: recovery failed!
[ 58.738478] mmcblk0: recovery failed!
[ 58.752809] mmcblk0: recovery failed!
[ 58.767069] mmcblk0: recovery failed!
[ 58.781352] mmcblk0: recovery failed!
[ 58.795728] mmcblk0: recovery failed!
[ 58.809922] mmcblk0: recovery failed!
[ 58.824215] mmcblk0: recovery failed!
[ 58.838599] mmcblk0: recovery failed!
[ 58.852796] mmcblk0: recovery failed!
[ 58.867110] mmcblk0: recovery failed!
[ 58.881448] mmcblk0: recovery failed!
[ 58.895696] mmcblk0: recovery failed!
[ 58.909968] mmcblk0: recovery failed!
[ 58.924302] mmcblk0: recovery failed!
[ 58.938543] mmcblk0: recovery failed!
[ 58.952812] mmcblk0: recovery failed!
[ 58.967184] mmcblk0: recovery failed!
[ 58.981378] mmcblk0: recovery failed!
[ 58.995686] mmcblk0: recovery failed!
[ 59.010022] mmcblk0: recovery failed!
[ 59.024217] mmcblk0: recovery failed!
[ 59.038488] mmcblk0: recovery failed!
[ 59.052819] mmcblk0: recovery failed!
[ 59.067079] mmcblk0: recovery failed!
[ 59.081334] mmcblk0: recovery failed!
[ 59.095706] mmcblk0: recovery failed!
[ 59.109900] mmcblk0: recovery failed!
[ 59.124148] mmcblk0: recovery failed!
[ 59.138526] mmcblk0: recovery failed!
[ 59.152718] mmcblk0: recovery failed!
[ 59.156479] print_req_error: 35 callbacks suppressed
[ 59.156493] blk_update_request: I/O error, dev mmcblk0, sector 4415488 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 59.182453] mmcblk0: recovery failed!
[ 59.186206] blk_update_request: I/O error, dev mmcblk0, sector 4415616 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 59.197487] buffer_io_error: 50 callbacks suppressed
[ 59.197501] Buffer I/O error on dev mmcblk0p4, logical block 524304, lost async page write
[ 59.220413] mmcblk0: recovery failed!
[ 59.224090] blk_update_request: I/O error, dev mmcblk0, sector 4415744 op 0x1:(WRITE) flags 0x103000 phys_seg 2 prio class 0
[ 59.234503] mmcblk0: recovery failed!
[ 59.235332] Buffer I/O error on dev mmcblk0p4, logical block 524320, lost async page write
[ 59.247282] Buffer I/O error on dev mmcblk0p4, logical block 524321, lost async page write
[ 59.255615] blk_update_request: I/O error, dev mmcblk0, sector 4677648 op 0x1:(WRITE) flags 0x103000 phys_seg 1 prio class 0
[ 59.266874] Buffer I/O error on dev mmcblk0p4, logical block 557058, lost async page write
[ 172.271745] mmc0: cache flush error -110
[ 172.718977] mmc0: tried to HW reset card, got error -110
[ 172.724409] mmcblk0: recovery failed!
[ 172.728221] blk_update_request: I/O error, dev mmcblk0, sector 1540072 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
[ 172.750250] mmcblk0: recovery failed!
[ 172.753988] blk_update_request: I/O error, dev mmcblk0, sector 1540072 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 293.514518] mmcblk0: recovery failed!
[ 293.518227] blk_update_request: I/O error, dev mmcblk0, sector 1540072 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 414.264491] mmcblk0: recovery failed!
[ 414.268268] blk_update_request: I/O error, dev mmcblk0, sector 1540072 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 535.013142] mmcblk0: recovery failed!
[ 535.016927] blk_update_request: I/O error, dev mmcblk0, sector 1540072 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
I also thought of a connection issue with the module last time. Before the last attempt on the 20th, I had pressed the module firmly onto the board, but as careful as I always am, not firmly enough. After you expressed your suspicions, I took another close look at the board from the side and saw that the eMMC module was sitting very slightly crooked. It looks like the module was not pressed into J99 properly, which means that J9 is not making good contact. So I pressed the module into J99 with a lot of force and now it works perfectly.
