Daily Ubuntu Kernel Builds - Now With 100% More APT Repo!
All kernels are available in the releases area on GitHub Releases · agreenbhm/linux · GitHub
Yes thanks @agreenbhm. I saw them I was just wondering whether there is some built in way (like apt). Anyway I was able to boot from sdcard and recognize nvme with 6.5. Unfortunately with that one network interfaces does not seem to work :pensive: Any chance new kernel may work with newer SPI image (v3)? Anyway I will try some time toom. And the 6.4 as well. Hopefully I find some setup where both network and nvme works
I haven’t had time to really be working with my VF2 lately so all the builds are being done automatically and I haven’t tested them. I did have to resolve a bunch of merge conflicts from mainline to my branch a week or so ago which may have resulted in some booting issues, even though the build is successful. It’s possible that’s what you’ve run into, but I am just speculating.
Yea so I tried latest 6.4, 6.5 and 6.6. With these results:
6.4 - no nvme
6.5 - no network interface (btw I have 1.3B)
6.6 - no boot
Unfortunately I am out of time for now. So now I wait either to get more time to tackle with this or until we get more feature complete ubuntu release.
Anyway thank you @agreenbhm. It is great to have rolling kernels to experiment :+1:
Im pretty sure I’ve had working NVME and ethernet (very slow about 50mbits. but working).
However 6.6 also didn’t boot for me.
New Ubuntu 23.10 with NVME support on VF2:
https://wiki.ubuntu.com/RISC-V/StarFive%20VisionFive%202
These look to be 23.04 releases.
Also, I assume I can dd the image to a nvme also. Am I wrong?
But the 23.10 release directory is here: https://cdimage.ubuntu.com/releases/23.10/release/
Sorry if this is trolling, but I think similar enough to the thread. The Ubuntu wiki referenced above provides this sequence for booting:
pci enum
nvme scan
load mmc 0:1 $fdt_addr_r dtb/starfive/jh7110-starfive-visionfive-2-v1.3b.dtb
load mmc 0:1 $kernel_addr_r EFI/boot/bootriscv64.efi
bootefi $kernel_addr_r $fdt_addr_r
I am close to converting that to the nvme device. I assume that the bootefi command will boot the linux kernel. How does this process tell the linux kernel where the root filesystem is?
I have formatted my NVMe and put EFI on partition 1 and Ubuntu on partition 2. Where do I tell the system that my root is /dev/nvme0n1p2?
It is all boot loaders chained to other boot loaders.
My assumption is EFI/boot/bootriscv64.efi then calls EFI/ubuntu/grubriscv64.efi the efi version of grub.
grub then looks for the grub.cfg config file in the boot file system to give you a menu for things to boot.
I’ve used the installer sd card image and done a clean install to nvme and it’s worked well.
It works well. However, for reasons unknown to me, I had to change load mmc 0:1 to load mmc 1:1 .
