FYI: You may also be able to access the running kernel config on a system (but only if the kernel was compiled with CONFIG_IKCONFIG and CONFIG_IKCONFIG_PROC), by using something like the following:
mzs@tock:~ $ zcat /proc/config.gz | grep PPS
gzip: /proc/config.gz: No such file or directory
mzs@tock:~ $ sudo modprobe configs
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
CONFIG_PPS_CLIENT_LDISC=m
CONFIG_PPS_CLIENT_GPIO=m
# PPS generators support
mzs@tock:~ $ sudo modprobe -r configs
(can also be accessed as /proc/.config)
Some distributions put copy of the config used in /boot
