hi, I’m in China. You could contact me via darkgeekyang AT foxmail DOT com. Any help is appreciated.
We will contact you via email.
Hello! Same issue here. Tried 3 cards:
Kingston SDC10/8GB N0538-002.A02LF
Samsung 16G (Serial number covered by sticker, sorry, it’s a C10 microSDHC card)
Samsung Evo Plus 128G UHS3 card MBMCDGVGQAFW-T
Here is the boot log:
bootloader version:211102-0b86f96
ddr 0x00000000, 1M test
ddr 0x00100000, 2M test
DDR clk 2133M,Version: 211102-d086aee
0 crc flash: c08c9d08, crc ddr: c08c9d08
crc check PASSED
bootloader.
OpenSBI v1.0
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Name : StarFive VisionFive V1
Platform Features : medeleg
Platform HART Count : 2
Platform Timer Device : aclint-mtimer @ 6250000Hz
Platform HSM Device : ---
Platform Reboot Device : ---
Firmware Base : 0x80000000
Firmware Size : 296 KB
Runtime SBI Version : 0.3
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 HARTs : 0*,1*
Domain0 Region01 : 0x0000000080000000-0x000000008007ffff ()
Domain0 Next Address : 0x0000000080200000
Domain0 Next Arg1 : 0x0000000082200000
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART ISA : rv64imafdcsux
Boot HART Features : scounteren,mcounteren
Boot HART PMP Count : 16
Boot HART PMP Address Bits: 36
Boot HART MHPM Count : 2
U-Boot 2022.01-rc4-VisionFive-g0c08d335c5 (Dec 30 2021 - 20:05:04 +0800)StarFive
CPU: rv64imafdc
Model: StarFive VisionFive V1
DRAM: 8 GiB
MMC: mmc@10000000: 0, mmc@10010000: 1
StarFive EEPROM format v1
Product full SN: VF7100A1-2204-D008E000-000000B0
data version: 0x1
PCB revision: 0x1
Ethernet MAC address: 6c:cf:39:00:00:af
In: serial@12440000
Out: serial@12440000
Err: serial@12440000
Net: dwmac.10020000
MMC CD is 0x1, force to True.
Autoboot in 2 seconds
dwmac.10020000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY dwmac.10020000
VisionFive #
Faulty controller in the same batch maybe? @Michael.Zhu @julie
Kingston SDC10/8GB capacity is too small to flash fedora image, we recommend at least 16G TF card.
Can you take a picture of two Samsung TF cards(front and back)?
I understand the 8GB is too small, just wanted to test whether it can be detected or not. These cards can’t be detected at all.
As for the images, I can not get my images to upload at all. One of them is 1MB and another is 800KB. Do you have emails so I can send them that way?
Please send email to sales at starfivetech dot com.
I have had the same problem, with a new VisionFive… I tried Samsung EVO 128GB U3, Samsung PRO 64GB U1, and Samsung EVO 32GB U1 cards, and none were recognised.
Samsung are on the ‘supported’ list mentioned elsewhere…
After more tests, I received an updated version of u-boot from StarFive, and can confirm that this fixed the problem, and MicroSD Cards are now detected correctly:
U-Boot 2022.04-rc2-VisionFive (Mar 07 2022 - 21:12:22 +0800)StarFive
VisionFive #mmc info
MMC CD is 0x0, force to True.
Device: mmc@10000000
Manufacturer ID: 1b
OEM: 534d
Bus Speed: 10000000
Mode: SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 59.6 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
Can you share the new u-boot? I get the same problem, it is impossible to start the system (the SD card is not recognized).
@balbes150 check out New u-boot binary for TF card compatibility
Was posted just a couple of days ago ![]()
