The fastboot option makes it possible to create a bootable emmc, but is there also an option to boot from NVME? Or can I just copy the filesystem from SD-card to the NVME, remove te SD-card and then restart?
VisionFive 2 Lite / VisionFive support booting from NVMe, provided that your QSPI bootloader needs to support NVMe. Not required to remove SD card if your U-Boot bootcmd points to NVMe.
you can use this command to set the bootup sequence under the uboot.
setenv boot_devs “nvme mmc”
saveenv
After you have connected once using a serial cable and saved the default environment to /dev/mtd1 using saveenv then you can update the variables stored in the QSPI flash from an OS:
$ cat /proc/mtd
dev: size erasesize name
mtd0: 000f0000 00001000 "spl"
mtd1: 00010000 00001000 "uboot-env"
mtd2: 00f00000 00001000 "uboot"
$ sudo apt install libubootenv-tool
$ sudo cat > /etc/fw_env.config
# MTD device name Device offset Env. size Flash sector size Number of sectors
/dev/mtd1 0x0 0x10000 0x1000
^D
$ sudo fw_printenv bootcmd
$ sudo fw_printenv boot_targets
$ sudo fw_printenv boot_devs
$ sudo fw_printenv
But of course if you make a bad enough typo using fw_setenv you will need to use a USB to 3.3v TTL serial cable to fix up the variables in your Das U-Boot environment.
I have installed the nvme in the M.2 M key, but I see nothing in lsblk.
Is this the problem of the wrong QSPI bootloader? And how do I install the right one (in a visionfive 2 lite board)?
Make sure your USB power supply is providing enough power. I have two different power supplies, with the one, I can see (lspci) and use (hdparm/dd) the NVMe, with the other, I can see the drive (lspci) but can’t access it with some strange error (can’t remember, something about drive not having any actual storage capacity).
1、The power adapter is greater than 5V3A.
2、Replace the NVME with a different brand and model.
I replaced the NVME and then I could see the device and I could copy /dev/sda to /dev/nvme0n1.
But after setting the boot_devs to “nvme mmc” I got the following respons:
StarFive # setenv boot_devs “nvme mmc”
StarFive # saveenv
Saving Environment to SPIFlash… Erasing SPI flash…Writing to SPI flash…done
OK
StarFive # boot
starfive_pcie pcie@2C000000: Port link up.
PCI: Failed autoconfig bar 10
Device 0: Vendor: 0x144d Rev: 7L1QFXM7 Prod: S65ENX0T235204
Type: Hard Disk
Capacity: 244198.3 MB = 238.4 GB (500118192 x 512)
… is now current device
Try booting from NVME0 …
Type: Hard Disk
MMC Device 1 not found
no mmc device at slot 1
switch to partitions #0, OK
mmc0 is current device
Try booting from MMC0 …
Tring booting distro …
Type: Hard Disk
419 bytes read in 1 ms (409.2 KiB/s)
806 bytes read in 1 ms (787.1 KiB/s)
U-Boot menu
1: Ubuntu 24.04.3 LTS 6.12.5-starfive
2: Ubuntu 24.04.3 LTS 6.12.5-starfive (rescue target)
Enter choice: 1
Retrieving file: /initrd.img-6.12.5-starfive
Unhandled exception: Load access fault
EPC: 00000000f7f2beb2 RA: 00000000f7f2bb0a TVAL: ffffffbd2f0ded05
EPC: 000000004022eeb2 RA: 000000004022eb0a reloc adjusted
SP: 00000000f76dd560 GP: 00000000f76ecdd0 TP: 0000000000000001
T0: 00000000f771a080 T1: 57c7473d2f0ded05 T2: 0000b9f00000b9ef
S0: 00000000f76fd0d0 S1: 0000000000000001 A0: 00000000f76dd6c0
A1: 0000000000000000 A2: ffffffffd0362cd6 A3: 0000000000000001
A4: 0000000000000200 A5: 00000000f770b1f0 A6: 57c7473d2f0ded05
A7: 0000000000010468 S2: 0000000000010468 S3: 00000000f76fd030
S4: 00000000f76dd6c0 S5: 00000000f7fcdec0 S6: 00000000f7723200
S7: 000000000ffffff0 S8: 000000000000fff0 S9: 0000000000000ff0
S10: 0000000000c2fa00 S11: 0000000000000020 T3: 00000000f7fcd950
T4: 000000000000000a T5: 00000000f7fcd950 T6: 0000000000010469
Code: 8eaa 853e 3783 000e 88b2 8f72 833e 881a (3303 0003)
resetting …
U-Boot SPL 2021.10 (Sep 15 2025 - 16:03:04 +0800)
Trying to boot from SPI
OpenSBI v1.2
What did I wrong?
What kind of nvme did you use?
maybe it is compatibility problems.
I tried Zhiti Kingston Netac and WD, all of them is ok; but KIOXIA can not boot up.
And i use command is
time dd if=ubuntu-24.03-preinstalled-desktop-riscv64-vf2-lite.img of=/dev/nvm
e0n1 bs=4M conv=fsync
