@cwt Thanks for your great work! I’m learning image building. Could you open source your scripts to build this image or point to some reference materials? Thanks!
Guys, I think I found the issue with my cwt6 image. The DTB files saved to /boot/boot/dtbs are reverting to the previous version every time I reboot. I believe my SD card has failed! Please wait while I verify this.
Update: It is verified. I’m switching to a new SD card.
Updat2: Somehow, my dtb file on the new SD also got changed. Something must overwrite my dtb. U-Boot?
@majortom Hi, I do not have a script, I did it almost manually. My initial idea was trying to use the btrfs on Debian Image 69, but then I realized that the Debian image is fixed to a snapshot version of debian which is pretty old. So I tried to use my custom kernel on Arch Linux which already published the rootfs on https://riscv.mirror.pkgbuild.com/.
By the way, there are some more details before the Arch’s rootfs can boot for the first time on VF2. I will document it later on my blog, and will post the link here.
I was told u-boot-update does something with the dtb file.
extlinux.conf is generated by u-boot-update. extlinux.conf points to the dtb file.
I just upload the hot fix cwt6.1 to my Google Drive, and Naver MYBOX.
You can just download the Kernel file and then extract it somewhere, and copy only boot/* to a flash drive then copy it over your /boot/ in cwt6 image.
Please post a comment if this fix your ethernet problem.
Thank you.
cwt6.1 fixes the ethernet for me.
Thanks!
Just installed arch to my new m2 ssd.
I partitioned and unpacked arch’s risc-v tarball using starfive’s debian image, then chrooted into it and updated it.
Then I copied and set up cwt’s kernel.
However, my usual encrypted swap setup doesn’t work:
Feb 09 12:51:40 StarFive systemd[1]: Starting Cryptography Setup for swap...
Feb 09 12:51:40 StarFive systemd-cryptsetup[279]: Cannot initialize device-mapper. Is dm_mod kernel module loaded?
Feb 09 12:51:40 StarFive systemd-cryptsetup[279]: Set cipher aes, mode cbc-essiv:sha256, key size 256 bits for device /dev/nvme0n1p1.
Feb 09 12:51:40 StarFive systemd-cryptsetup[279]: Cannot use device swap, name is invalid or still in use.
Feb 09 12:51:40 StarFive systemd-cryptsetup[279]: Failed to activate with key file '/dev/urandom': Operation not supported
Feb 09 12:51:40 StarFive systemd[1]: systemd-cryptsetup@swap.service: Main process exited, code=exited, status=1/FAILURE
Feb 09 12:51:40 StarFive systemd[1]: systemd-cryptsetup@swap.service: Failed with result 'exit-code'.
Feb 09 12:51:40 StarFive systemd[1]: Failed to start Cryptography Setup for swap.
The kernel seems to have been built w/o device manager support (or something related is broken), and thus I can have no encrypted swap (or encrypted anything).
@cwt could you look into this for new release?
My intent, besides encrypting swap, was to set up LUKS for my /home partition. Any serious use is gated on having this working.
I didn’t enable device manager, I can enable it and build a new kernel.
It’s no hurry, but it’d be nice to have it enabled for the next one ![]()
Somehow, I expected X to just work via modesetting or fbdev drivers. But it does not.
What did you do to get X working? I would like to try and do it myself, to understand the steps.
I did get weston working on wayland. I never tried X. I don’t think it will working out of the box without Starfive patches. It may required binary blob too, which I don’t expected it to work because the glibc on Arch is newer than Debian.
Installing the xf86-video-fbdev driver wasn’t enough.
Section "Device"
Identifier "Screen0"
Driver "fbdev"
Option "fbdev" "/dev/fb0"
EndSection
It needed to be told this much.
So now I have X. Unaccelerated, slow, but X nevertheless.
@rvalles I just uploaded an experimental kernel that I’ve been working on. It’s quite stable and I’ve been using it as my daily driver for a week now (24x7). DM, DM_CRYPT, and other DM_* modules are enabled.
The kernel was built with LLVM:
$ make -j4 LLVM=1 CC="clang -mcpu=sifive-u74 -mtune=sifive-7-series"
So if you want to build any external module or driver, please add LLVM=1 to your make command.
Google Drive: Experimental - Google 云端硬盘
Naver MYBOX: 네이버 MYBOX
Extract them to / and then edit your /boot/boot/extlinux/extlinux.conf
Grabbed your sources, gave menuconfig a once-over and I’m now building them on the VisionFive 2 itself.
It was about time I tried building a kernel on this thing. We’ll see how it goes.
At 40m, 56.3C CPU, 43.9C SSD.
@cwt The latest image ArchLinux-VF2_515_v2.8.0-cwt6.1.img (not experimental image) has two flaws…
The extracted image is 15GB. Even though most of it is empty,
ddwill still write additional 12-ish GBs to the disk and cause extra wear and tear. It is also very time consuming. Please trim the image down, 15 GB is too much. I guess you can get away with 1200MB only
The device tree is still being corrupted somehow… The
reboot +0command does not work. I can see on UART that the board is stuck and the last kernel message is:reboot: Restarting system with command '+0'. Edit: The reset button doesn’t work either
Can you share your build scripts? Maybe I can chip in, I too prefer Arch over Debian ![]()
It wasn’t ready. Something actually failed.
Now I see why salsa20 was disabled
I didn’t even write down the image.
With losetup and some parameter, you get subdevices for each partition. I mounted and took what I needed from /boot, and used the official root tarball from the arch risc-v port website.
Disk images are the problem. Just use tarballs instead.
There is no build script, I did everything manually as described in this post.
Unfortunately, the corruption of the DTB file is something beyond my control. I recently discovered that the file was being overwritten by the u-Boot. I hope Starfive will address this issue in future releases of their Debian image.
I am currently waiting for the delivery of the revision B board so that I can test my image on both revisions. Until then, I do not plan on releasing any new images.
I have a 1.3B (or is it 8?) board and I’ll try making a script to build an image
My kernel boots, but a long time was spent in udev (see timeout below) and there’s some bizarre libbpf errors.
[ 3.067694] cdns-dsi 295d0000.mipi: starfive dsi bind end
:: running early hook [udev]
Starting systemd-udevd version 252.5-1-arch
:: running hook [udev]
:: Triggering uevents...
Timed out for waiting the udev queue being empty.
:: running hook [keymap]
:: Loading keymap...kbd_mode: KDSKBMODE: Inappropriate ioctl for device
done.
:: performing fsck on '/dev/nvme0n1p2'
arch-root: clean, 232667/8388608 files, 3116201/33554432 blocks
:: mounting '/dev/nvme0n1p2' on real root
:: running cleanup hook [udev]
libbpf: failed to find valid kernel BTF
libbpf: Error loading vmlinux BTF: -3
libbpf: failed to load object 'iterators_bpf'
libbpf: failed to load BPF skeleton 'iterators_bpf': -3
Failed load could be due to wrong endianness
Welcome to Arch Linux!
[ 127.637574] systemd[1]: bpf-lsm: Failed to load BPF object: No such process
[ OK ] Created slice Slice /system/getty.
@cwt How do you generate your initramfs?
On my end, all I did was a crude mkinitcpio -k 5.15.2-rt20-cwt9-rvalles -g myinitrd.
