mesa-pvr-vf2-22.1.3-1-riscv64.pkg.tar.zst (9.3 MB)
Mesa 22.1.3 supporting DDK 1.19
https://aur.archlinux.org/packages/mesa-pvr-vf2
Tested to work with
- weston
- sway
- hyprland
- wayfire
Tested to work with
Thanks, GTK4 applications now fail to crash. Excellent.
Your gist guide still recommends mesa-pvr-vf2-21.2.5-1-riscv64.pkg.tar.zst. Would you now recommend mesa-pvr-vf2-22.1.3-1-riscv64.pkg.tar.zst?
Iāve not tried your guide or cwt14 yet. I wonder if hw video decoding works?
Thanks, I will update the notes.
Just release the cwt15 image.
Thank you again.
Will there be a kernel package (otherwise, I donāt mind scraping the image; qemu-nbd makes this painless) ?
Update: OK, I discovered them in the image.
You can download the latest packages from the release pages from these repo:
Iām learning on how to make them available together on a single GitHub repo and be able to upgrade them just by pacman -Syu command.
Irrespective to the binary packages, why not put the three PKGBUILDs in the aur?
The GPU stuff is already in AUR under @trissylegsā ownership, but she hasnāt merged my pull request for the last two releases. So, I went ahead and updated it myself and put up the binary package on GitHub.
Mesa is also on AUR, but Iām just hosting the binary package on GitHub.
As for the original kernel package in AUR owned by @saeziae, my patches and building method are quite different from the original one. Iāve always considered it highly experimental, so Iām not sure if itās a good fit for AUR (though that might just be my gut feeling).
Or may be I should give them all a rebrand and list them on AUR with my unique names? However, I have a feeling (again) that it is against the AUR recommendation.
I looked into packing the hardware decoding / encoding stack for Arch.
The Debian build script and the provided patch files are the best reference so far.
https://github.com/starfive-tech/Debian/blob/20221225T084846Z/multimedia/build.sh
wave420l does compile on Arch with the patchesffmpeg -f lavfi -i yuvtestsrc -t 1 -r 30 -s 1920x1080 -f rawvideo -pix_fmt yuv420p wave420l/code/yuv/mix_1920x1080_8b_9frm.yuv
sudo wave420l/code/script/enc_1920x1080_8b.sh
wave511 builds on Arch with patchesomx-il builds on Arch with patchesgst-omx builds on Arch with patches but only v1.18.5, nothing aboveSo far partial decoding support in gstreamer.
gst-inspect-1.0 omx
Plugin Details:
Name omx
Description GStreamer OpenMAX Plug-ins
Filename /home/user/repos/soft_3rdpart/target/usr/lib/gstreamer-1.0/libgstomx.so
Version 1.18.5
License LGPL
Source module gst-omx
Source release date 2021-09-08
Binary package GStreamer OpenMAX Plug-ins
Origin URL Unknown package origin
omxh264dec: OpenMAX H.264 Video Decoder
omxmp3dec: OpenMAX MP3 Audio Decoder
omxmpeg2dec: OpenMAX MPEG2 Video Decoder
The run_env.sh test script also lists omxh265dec.
Havenāt tried building the patched ffmpeg or gstreamer, yet. That might be the reason why no encoders are buildā¦
Main blockers
/dev/venc /dev/jpu /dev/vdec requires rootstarfive-tech/soft_3rdpart really needs to be split into individual repositories for easier packaging (and PRās). git clone --filter might be a work-aroundor proper Makefiles that donāt require patchesā¦
⦠to be continued
We should allow all to read/write them (666), right?
matching /dev/dri/card0 might be the best practice? Change group to video or render with 0660.
yeah, will change group to video with mode 660
WIP PKGBUILD for ācodaj12ā āwave420lā āwave511ā and āomx-ilā
https://github.com/leuc/vf2-soft_3rdpart-aur
Please check if it builds with /etc/makepkg.conf settings.
I cloned your repo and built the kernel.
Booting it, fstab handling for LABEL=linux-home (my /home) times out.
It is encrypted with LUKS2, and the device (via crypttab) opens correctly. But the contents of the opened device arenāt the decrypted data, but high entropy garbage i.e. encrypted data as-is or decoded with the wrong key.
This should never happen, as if LUKS2 manages to open the device, it means that the needed cryptography support is available, and the entered passphrase is correct.
āānvme0n1p7 259:7 0 867.7G 0 part
āālinux-home 254:1 0 867.7G 0 crypt
[root@starfive ~]# cryptsetup status linux-home
/dev/mapper/linux-home is active.
type: LUKS2
cipher: aes-xts-plain64
keysize: 512 bits
key location: keyring
device: /dev/nvme0n1p7
sector size: 512
offset: 32768 sectors
mode: read/write
[root@starfive ~]# file /dev/mapper/linux-home
/dev/mapper/linux-home: symbolic link to ../dm-1
[root@starfive ~]# file /dev/dm-1
/dev/dm-1: block special (254/1)
[root@starfive ~]# file -s /dev/dm-1
/dev/dm-1: data
[root@starfive ~]# uname -a
Linux starfive 5.15.2-cwt-3.4.5-2 #1 SMP PREEMPT Thu Aug 31 04:18:49 UTC 2023 riscv64 GNU/Linux
u-boot and spl are from v3.6.1⦠as I boot from newest debian image sdcard with added extlinux.conf options for my Arch Linux. DIP switches set to use sdcard.
edit: I installed your binary package, to exclude issues specific to my build environment. It behaves the same way.
Do you have any clue what could be going on?
Seems like weāre both tackling the same thing at the same time. Should I go ahead and split out the building package for āsoft3dpartā from my PKGBUILD?
Sometime in the past, I tried to do that, but it turned out I had to provide the whole kernel source instead of just the header package. That kind of made the whole building process a bit more complicated.
Right now, the deal is that āsoft3rdpartā gets built alongside the kernel, and then we divide it into three separate packages. You can check out how itās done in my PKGBUILD.
Iām up for adding the stuff I missed from your PKGBUILD too. But I have to see if I can get it to build separately first.
The last time I use LUKS (and it was only LUKS not LUKS2) was ages ago!
Iād love to assist, but honestly, I have no clue.
All it means is that the kernelās cryptography support is broken, at least for aes-xts-plain64. Old kernel was fine.
Iād like to try and build your kernel with gcc instead of llvm, to see if this changes anything. Is this easy to achieve?
In that case, just change all lines with:
LLVM=1 CC="clang -mcpu=sifive-u74 -mtune=sifive-7-series"
to:
CC="gcc -mcpu=sifive-u74 -mtune=sifive-7-series"
and then makepkg again.
By the way, which kernel was good and which kernel was bad? I want to see if there was anything related to crypto added or removed.
