How to use external gpu on VisionFive v2
Hi bro, I just enabled the radeon module in the kernel, but I had to download firmware files from the console first while the card was plugged in, and then put them in the right places, also I had to rename files in /lib/firmware/SomeFolders for it to match depending on DMESG message logs. Then it worked by itself, I could get GUI, not just console :slight_smile:
That’s great to hear! I’ll have to do some experimentation then… also, have you seen whether the card can work for ffmpeg video accelerated encoding? I am considering seeing whether I could compile it that way so I could use it for better encoding (if it’s hard to get H.264 encode working on the onboard GPU especially).
Sorry, no I didn’t try ffmpeg encoding yet.
Regarding the Mesa packages — can you be more specific? I have been trying to get my Radeon HD 7450 running and need the AMD firmware, but firmware-amd-graphics doesn’t seem to be available. Should I just copy the firmware files (in my case radeon/CAICOS_pfp.bin) from another system? (Not sure if they’re arch-specific).
Edit: Nevermind, just ran the following to grab the firmware:
git clone --depth 1 --filter=blob:none --sparse https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
cd linux-firmware
git sparse-checkout set radeon
sudo cp -R radeon /lib/firmware
Just wondering, since I’ve never set this up… did you follow these instructions or something like user-mode linux?
From the JH7110 datasheet the VPU hardware supports H.265 encoding 1080p@30fps, the JH7100 on the VisionFive 1 supports both. The VisionFive 2 does not have the hardware to support H.264 encoding.
This block diagram of the multimedia features confused me, until I realised that the same block diagram was used for both SoC’s.
There are example commands of video encoding using the custom starfive build of ffmpeg but some of the commands still mention h264 in this documentation, which at a guess is because some of the information in that document was migrated from the VisionFive 1 board.
When it comes to video encoding, the JH7100 must have licensed more expensive IP for the VPU than the JH7110. Form the two chips datasheets:
JH7100: Video Decoder(H264/H265): up to 1 channel 4K@60fps or 8 channel 1080p30fps
JH7100: Video Encoder(H264/H265): up to 1 channel 4K@60fps or 8 channel 1080p30fps
JH7110: Video Decoder(H264/H265): up to 1 channel 4K@60fps or 8-channel 1080p30fps
JH7110: Video Encoder(H265): 1080p@30fps
The GPU (IMG BXE-4-32 mc1) does not naively support video encoding, and if someone did write code for it to do so, I’m guessing that it would be really really really slow.
Video encoding/decoding happens in dedicated VPU blocks inside the SoC:
JH7110: Chips and Media WAVE420L IP (encode)
JH7110: Chips and Media WAVE511 IP (decode)
JH7100: Chips and Media WAVE521 IP (encode)
JH7100: Chips and Media WAVE511 IP (decode)
In my mind the future will be AV1 for computers and streaming services and H.266 for satellite and terrestrial TV services.
I have my Radeon HD 7470 working, and I get console output, but after boot it starts flashing the screen and over and over I get these logs for like a minute:
[  144.420246] Allocated coherent memory, vaddr: 0xFFFFFFE1F97BAB60, paddr: 0x8010C000
[  144.427903] ====> vs_gem_alloc_buf, 162.vs_obj->get_pages = 0
[  145.648363] PVR_K:  1035: X disconnected - (devID = 0)
[  145.946836] vs_gem_dumb_create size = 1000
[  145.950986] Allocated coherent memory, vaddr: 0xFFFFFFE1FB3FF388, paddr: 0x10149F000
[  145.958755] ====> vs_gem_alloc_buf, 162.vs_obj->get_pages = 0
[  146.008825] PVR_K:  1044: X connected - (devID = 0)
[  146.362182] vs_gem_dumb_create size = 300000
[  146.368724] Allocated coherent memory, vaddr: 0xFFFFFFE1F97BE0C0, paddr: 0x80200000
[  146.376446] ====> vs_gem_alloc_buf, 162.vs_obj->get_pages = 0
[  146.395626] vs_gem_dumb_create size = 4000
[  146.399871] Allocated coherent memory, vaddr: 0xFFFFFFE1F97BAA80, paddr: 0x80108000
[  146.407528] ====> vs_gem_alloc_buf, 162.vs_obj->get_pages = 0
[  146.413293] vs_gem_dumb_create size = 4000
[  146.417462] Allocated coherent memory, vaddr: 0xFFFFFFE1F97BAB60, paddr: 0x8010C000
[  146.425137] ====> vs_gem_alloc_buf, 162.vs_obj->get_pages = 0
[  147.626145] PVR_K:  1044: X disconnected - (devID = 0)
It seems to be the PVR GPU driver conflict mentioned earlier. I can’t seem to use the console display with keyboard and mouse—only the internal HDMI port with its much slower performance (and no support for OpenGL it seems right now).
AV1 software support could be made that uses the cpu/gpu to make it happen.
In fact, I’m certain there are packages already built for this for the cpu, albeit not the fastest as you mentioned, it still already exists.
GPU support for AV1 yet? I don’t know if anybody has invested effort here. If it did, it wouldn’t be so slow.
Most limiting factor at hand for the VF2 is the pcie 2.0 with access to only one lane for storage. That really slows everything down with respect to processing data everywhere because data wants to be stored.
I think there will need to be an VF3 sooner rather than later with better/more recent pcie storage. Consumers of course would pay for this. The form-factor is what’s most attractive. The power envelope to support pcie3/4/5 and the attached devices is the big question mark. It would also require reflection how the SBC case would be made to handle all such attached devices for pcie3/4/5. Even USB needs faster pcie 3/4/5 and the question of power usage would need to be clearly answered as well.
All these subtleties are that the VF2 capabilities are honestly compared to what users usual requirements which are the average desktop/laptop, but in a mini-pc form factor.
When you add up all the little accessories one buys to make the VF2 work, it adds up to a intel x86_64 mini-pc’s cost or a used x86_64 laptop. Yet even a used x86_64 mini-pc/laptop still provides more capability than the VF2 to be quite honest. One needs to be truly dedicated to the fruition of the riscv ecosystem to commit to using VF2 hardware at the moment.
One should not be needing to be dedicated to use such hardware. Rather the hardware should be designed to compete with and exceed the users’ requirements/expectations and the consumers will be willing to pay for that.
It’s a lot like that movie ā€œField of Dreamsā€, ā€œBuild it and they will come.ā€ X-window had a spin-off saying as well when it surfaced: ā€œBuild the software and the hardware will come.ā€ Hifive unmatched has met a great deal of the requirements since they have a board that supports more recent pcie, but the core count is still very low considering the price of the hifive unmatched is 7 to 10 times the price of the VF2, but the core for the Hifive unmatched is the price of a mid-range pc that has more cores available.
Are there plans to offer a new Vision Five board that has more cores, newer pcie, more powerful gpu equivalent to a professional workstation?
Why? Because to be taken seriously, we need something that can provide for the required workstation tasks. All users have different requirements, but by the existence of gaming desktops, graphics/engineering workstations and such in x86_64 land, it should nudge Starfive to consider offering matching features at a matching price point to be taken more seriously.
I’m honest when I say VF2 at present is still very much a toy. I wish it were more than that.
It has the potential to be much more than that. I mean this in a good way. I am a backer after all. I would back another more powerful version of the VisionFive that would match and exceed high-end graphics workstations. I certainly can’t even recommend this as a replacement for an existing graphics workstation when I would like to, but I can’t because I would be laughed out of the room with the VF2’s existing capabilities compared to AMD’s/Intel’s latest x86_64 offerings and price points.
For the next version of Starfive VisionFive, make a survey and ask consumers what they really want. Let the consumers make the decisions as to the hardware specs.
 # ./target/release/freshfetch
                   ..                   blah@blahcantsay
                 .PLTJ.
                <><><><>                OS: CentOS Linux 7 (Core) x86_64
       KKSSV' 4KKK LJ KKKL.'VSSKK       Host: HP Z4 G4 Workstation
       KKV' 4KKKKK LJ KKKKAL 'VKK       Kernel: Linux 3.10.0-1160.81.1.el7.x86_64
       V' ' 'VKKKK LJ KKKKV' ' 'V       Uptime: 4 days, 18 hours, 56 minutes
       .4MA.' 'VKK LJ KKV' '.4Mb.       Packages: 1697 (rpm)
     . KKKKKA.' 'V LJ V' '.4KKKKK .     Shell: bash
   .4D KKKKKKKA.'' LJ ''.4KKKKKKK FA.   Resolution: 1920x1080
  <QDD ++++++++++++  ++++++++++++ GFD>  CPU: Intel Core i9-10980XE  @ 3.00GHz (36) @ 4.8GHz
   'VD KKKKKKKK'.. LJ ..'KKKKKKKK FV    Board: HP 81C5
     ' VKKKKK'. .4 LJ K. .'KKKKKV '     Memory: 2692MB / 131639MB
        'VK'. .4KK LJ KKA. .'KV'
       A. . .4KKKK LJ KKKKA. . .4
       KKA. 'KKKKK LJ KKKKK' .4KK
       KKSSA. VKKK LJ KKKV .4SSKK
                 'MKKM'
PCIE 3.0 CPU/Motherboard I just got last week. it has lots of cores, lots of RAM, but honestly the pcie 3.0 was a savings measure and I have no decision making power to buy the hardware. Both AMD/Intel offer PCIE 5.0 CPU’s and motherboards along with Supermicro. If it were up to me, I would go pcie5.0 with as many lanes in the cpu/gpu/storage as possible. That’s what Starfive should be aiming for.
Why are we still talking PCIE 2 on a new RISC-V CPU and only offering one pcie lane to get to the storage and graphics? Starfive please offer something much better on the next SBC.
I heard that JH8100 might have pcie3.0x8, if that’s true, it would be interesting.(Though there might be some PHY sharing between other peripherals)
Hi Bro,Can you share the steps?
I rebuild the kernel source code,but the display-monitor is not lit up.I’m sure the radeon module is M and firmwares are also loaded in menuconfig.
Successfully used a GT 710 with nouveau driver on Debian Trixie, I needed to blacklist snd_hda_intel module otherwise it would cause kernel task hangs during startup and freeze the system.
$ uname -a
Linux visionfive-debian 6.12.48+deb13-riscv64 #1 SMP Debian 6.12.48-1 (2025-09-20) riscv64 GNU/Linux
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux 13 (trixie)
Release:	13
Codename:	trixie
$ lsmod
Module                  Size  Used by
snd_usb_audio        2101248  1
snd_usbmidi_lib       212992  1 snd_usb_audio
snd_hwdep              69632  1 snd_usb_audio
snd_ctl_led            98304  0
snd_rawmidi           339968  1 snd_usbmidi_lib
mc                    425984  1 snd_usb_audio
hid_jabra              20480  0
nls_ascii              16384  1
nls_cp437              20480  1
vfat                  135168  1
fat                   602112  1 vfat
snd_seq_dummy          16384  0
snd_hrtimer            32768  1
snd_seq               659456  7 snd_seq_dummy
snd_seq_device         32768  2 snd_seq,snd_rawmidi
cfg80211             9011200  0
rfkill                188416  3 cfg80211
8021q                 253952  0
garp                   69632  1 8021q
stp                    24576  1 garp
mrp                   106496  1 8021q
llc                    49152  2 stp,garp
evdev                 151552  8
joydev                131072  0
snd_soc_simple_card    61440  1
jh7110_pwmdac          53248  2
snd_soc_simple_card_utils   106496  1 snd_soc_simple_card
snd_soc_spdif_tx       16384  1
cdns3                 942080  0
snd_soc_core         1703936  4 snd_soc_spdif_tx,snd_soc_simple_card_utils,snd_soc_simple_card,jh7110_pwmdac
udc_core              299008  1 cdns3
snd_compress          110592  1 snd_soc_core
cdns_usb_common       135168  1 cdns3
snd_pcm_dmaengine      40960  1 snd_soc_core
roles                  40960  1 cdns_usb_common
snd_pcm               978944  5 snd_usb_audio,snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine
ofpart                 36864  0
spi_nor               626688  0
snd_timer             356352  3 snd_seq,snd_hrtimer,snd_pcm
cdns3_starfive         28672  0
snd                   749568  17 snd_ctl_led,snd_seq,snd_seq_device,snd_hwdep,snd_usb_audio,snd_usbmidi_lib,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi
mtd                   479232  5 spi_nor,ofpart
jh7110_trng            61440  0
sfctemp                36864  0
soundcore              57344  2 snd_ctl_led,snd
cpufreq_dt             45056  0
binfmt_misc           122880  1
nvme_fabrics          143360  0
nvme_keyring           36864  1 nvme_fabrics
nvme_core            1261568  1 nvme_fabrics
nvme_auth              73728  1 nvme_core
configfs              462848  1
nfnetlink             118784  1
ip_tables             131072  0
x_tables              237568  1 ip_tables
autofs4               438272  2
ext4                 7385088  1
crc16                  12288  1 ext4
mbcache                81920  1 ext4
jbd2                 1351680  1 ext4
crc32c_generic         20480  2
nouveau             17698816  5
hid_generic            16384  0
usbhid                495616  0
hid                   909312  3 usbhid,hid_generic,hid_jabra
drm_gpuvm             274432  1 nouveau
drm_exec               40960  2 drm_gpuvm,nouveau
gpu_sched             389120  1 nouveau
i2c_algo_bit           49152  1 nouveau
drm_display_helper    950272  1 nouveau
xhci_pci               98304  0
drm_ttm_helper         49152  2 nouveau
xhci_hcd             2080768  1 xhci_pci
ttm                   614400  2 drm_ttm_helper,nouveau
motorcomm             204800  1
drm_kms_helper       1011712  3 drm_display_helper,drm_ttm_helper,nouveau
dwmac_starfive         20480  0
stmmac_platform        90112  1 dwmac_starfive
usbcore              2232320  6 xhci_hcd,snd_usb_audio,usbhid,snd_usbmidi_lib,cdns_usb_common,xhci_pci
stmmac               2613248  4 dwmac_starfive,stmmac_platform
axp20x_regulator       94208  6
drm                  3620864  11 gpu_sched,drm_kms_helper,drm_exec,drm_gpuvm,drm_display_helper,drm_ttm_helper,ttm,nouveau
mmc_block             319488  2
axp20x_i2c             16384  0
axp20x                 61440  1 axp20x_i2c
usb_common             49152  6 xhci_hcd,cdns3_starfive,cdns_usb_common,usbcore,cdns3,udc_core
pcs_xpcs              188416  1 stmmac
mfd_core               40960  1 axp20x
dw_mmc_starfive        32768  0
regmap_i2c             36864  1 axp20x_i2c
dw_mmc_pltfm           20480  1 dw_mmc_starfive
mdio_devres            20480  1 pcs_xpcs
of_mdio                45056  3 mdio_devres,stmmac_platform,stmmac
dw_mmc                397312  1 dw_mmc_pltfm
fixed_phy              40960  1 of_mdio
phylink               348160  2 stmmac,pcs_xpcs
mmc_core             1183744  3 dw_mmc,mmc_block,dw_mmc_starfive
fwnode_mdio            28672  1 of_mdio
libphy                815104  9 mdio_devres,fwnode_mdio,of_mdio,stmmac,fixed_phy,motorcomm,phylink,pcs_xpcs
starfive_wdt           81920  0
phy_jh7110_dphy_rx     45056  0
spi_cadence_quadspi   241664  0
dw_axi_dmac_platform   282624  1
watchdog              229376  1 starfive_wdt
clk_starfive_jh7110_vout    24576  0
clk_starfive_jh7110_isp    24576  3
clk_starfive_jh7110_aon    20480  3
virt_dma               49152  1 dw_axi_dmac_platform
clk_starfive_jh7110_stg    20480  16
phy_jh7110_pcie        32768  2
phy_jh7110_usb         32768  1
i2c_designware_platform    32768  0
$ glxinfo | grep OpenGL
OpenGL vendor string: Mesa
OpenGL renderer string: NV106
OpenGL core profile version string: 4.3 (Core Profile) Mesa 25.0.7-2
OpenGL core profile shading language version string: 4.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.3 (Compatibility Profile) Mesa 25.0.7-2
OpenGL shading language version string: 4.30
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 25.0.7-2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
