Case for VF2 lite with adequate cooling
If you are using NVME, it is recommended to use active cooling. NVME is installed at the bottom of VF2 Lite, which increases heat and accumulates on the CPU.
The Raspberry Pi 4B does not have a built-in SSD, so it can use passive cooling. Raspberry Pi 5, The dealer suggested using active cooling.
The power consumption and heat of RISCV are higher than those of ARM.
:blush:
