I do know where I can get the original config file. I asking, because the standard config file does not include the amdgpu driver, and I’m not sure if it’s just “enable the amdgpu driver”, or if other config settings need to be changed aswell.
You will need to change it to use the compressed firmware in the firmware folder. I was using the uncompressed firmware. You can use the below link to figure out what firmware you need.
I have a strange bootloop. I wrote the latest image from github Release cwt17 · cwt/Arch-VF2-Image · GitHub to the TF card and the DIP switch is set to SDIO mode with rgpio_1 low and rgpio_0 high. I get this message on the UART:
U-Boot SPL 2021.10 (Sep 26 2023 - 22:53:52 +0800)
Trying to boot from MMC2
OpenSBI v1.2
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
Platform Features : medeleg
Platform HART Count : 5
Platform HSM Device : ---
Platform PMU Device : ---
Platform Suspend Device : ---
Firmware Base : 0x40000000
Firmware Size : 392 KB
Firmware RW Offset : 0x40000
Runtime SBI Version : 1.0
Domain0 Name : root
Domain0 Boot HART : 1
Domain0 Next Mode : S-mode
Domain0 SysReset : yes
Domain0 SysSuspend : yes
Boot HART ID : 1
Boot HART Domain : root
Boot HART PMP Count : 8
Boot HART MHPM Count : 2
U-Boot 2021.10 (Sep 26 2023 - 22:53:52 +0800), Build: jenkins-github_visionfive2-18
CPU: rv64imacu_zba_zbb
Model: StarFive VisionFive V2
DRAM: 8 GiB
Product full SN: VF7110B1-2253-D008E000-00006943
PCB revision: 0xb2
Ethernet MAC0 address: 6c:cf:39:00:69:3a
Ethernet MAC1 address: 6c:cf:39:00:69:3d
In: serial
Out: serial
Err: serial
switch to partitions #0, OK
mmc1 is current device
Try booting from MMC1 ...
Failed to load 'vf2_uEnv.txt'
## Info: input data size = 482 = 0x1E2
## Error: "boot2" not defined
Tring booting distro ...
406 bytes read in 6 ms (65.4 KiB/s)
52402 bytes read in 11 ms (4.5 MiB/s)
52402 bytes written in 11 ms (4.5 MiB/s)
520 bytes read in 8 ms (63.5 KiB/s)
1: Arch Linux
Retrieving file: /initramfs-linux.img
7804480 bytes read in 343 ms (21.7 MiB/s)
Retrieving file: /vmlinuz
10765880 bytes read in 471 ms (21.8 MiB/s)
append: root="LABEL=VF2" rw console=tty1 console=ttyS0,115200 earlycon rootwait stmmaceth=chain_mode:1 selinux=0 rootflags=defaults,discard=async,compress=lzo,user_subvol_rm_allowed,subvol=@
Uncompressing Kernel Image
Moving Image from 0x44000000 to 0x40200000, end=41efd000
Using Device Tree in place at 0000000048000000, end 000000004800fcb1
Starting kernel ...
clk u2_dw_i2c_clk_core already disabled
clk u2_dw_i2c_clk_apb already disabled
[ 0.591609] L2CACHE: DataError @ 0x00000000.08040270
[ 0.597099] L2CACHE: DataFail @ 0x00000000.08040140
[ 1.431411] jh7110-sec 16000000.crypto: Unable to request sec_m dma channel in DMA channel
[ 1.440576] jh7110-sec 16000000.crypto: Cannot initial dma chan
[ 1.561345] debugfs: Directory '16008000.sec_dma' with parent 'dmaengine' already present!
[ 1.573982] seeed_panel 2-0045: Unknown Atmel firmware revision: 0x00
[ 1.613623] imx219 6-0010: failed to read chip id 219
[ 1.621005] ov4689 6-0036: ov4689_read_reg: error: reg=300a
[ 1.627216] ov4689 6-0036: ov4689_check_chip_id: failed to read chip identifier
[ 2.034227] usb usb2-port1: over-current condition
[ 2.177129] mailbox_test mailbox_client: invalid resource
[ 2.182598] mailbox_test mailbox_client: invalid resource
[ 2.188692] starfive-i2s 120b0000.i2stx_4ch0: designware: i2s master mode supported
[ 2.197027] cdns-dsi 295d0000.mipi: starfive dsi bind end
:: running early hook [udev]
Starting systemd-udevd version 254.4-1-arch
:: running hook [udev]
:: Triggering uevents...
And at this point it seems to crash and loops back to the start with OpenSBI.
Turns out it was a power quality issue. My USB-to-serial adapter couldn’t supply enough power for that stage in the boot process. Switching to USB-C power fixed the issue.
For anyone that has weird color with the built-in HDMI output, I have appeared to fix it with this Xorg configuration file. Here it is running xfce4 with the correct blue mouse color. gist
You should upgrade the onboard firmware (SPL and U-boot) to the latest version first.
Make sure you are going to write the firmware to the right MTD partition.
In this case, spl is mtd0, and uboot is mtd1. Please note that in the latest StarFive kernel, the MTD partitions have been rearranged so that uboot is now on mtd2. Therefore, it’s important to always check with cat /proc/mtd.
What if one has a dual boot setup, having Arch and Debian on two different NVME-Partitions, sharing the same Partitions for Booting (nvme0n1p{1-3})?
What is the path to update debian and arch with the same partition order then?
I have not seen a possible package upgrade for the debian part at all!?
The debian image is really a “developer” image and not suitable for any long term desktop or server use. Its based on a debian snapshot release and the custom packaging conflicts with base packages, specifically mesa. Upgrading between releases isn’t really “supported” either.
Well…so I’ll download the image, copy the new debian kernel to boot partition, apply extlinux.conf changes, boot back to arch, update firmware an install cwt’s new Archlinux kernel packages and off I go.
While I am capable of building a new image remotely, I prefer not to release an image without physically testing it on a real SD card. Therefore, the cwt20 image should be ready after the new year.
